Bias lighting for your wall mounted display for only $16 - AVS Forum | Home Theater Discussions And Reviews
Old 04-21-2013, 09:20 AM - Thread Starter
ovexi's Avatar
Just finished my bias lighting project for my LG 60LM7200 and I’m quite pleased with the results and therefore like to share a few pictures here for whoever may be interested.
All parts were bought on E-Bay (led strip + power adapter + dimmer with remote) for a total of about $16.00.
I even programmed my Harmony One to turn on/off the LEDs and increase/decrease the brightness.
Hope this helps somebody looking for a cheap bias lighting solution
ovexi is offline
Old 04-21-2013, 09:59 AM
GeorgeAB's Avatar
Quoted: 136 Post(s)
Liked: 240
They look too blue for general video use. What is the claimed and verified color temperature?
GeorgeAB is offline
Old 04-21-2013, 10:11 AM
kingpin748's Avatar
Lol, its $16 kit cobbled together from eBay parts. There's nothing to verify. I did something like this for a bedroom TV and it was significantly better than nothing. Good job OP.
kingpin748 is offline
Old 04-21-2013, 10:12 AM - Thread Starter
ovexi's Avatar
They don't look too blue for me at all however you can experiment with different colors. The E-bay vendor does not post the color temp and I have no means to measure that either
ovexi is offline
Old 04-21-2013, 01:07 PM
nodixe's Avatar
If I remember correctly I read about reference or lab quality led lights at consumer prices...at blurbuster com I think....?....on that site he was using those led strips to construct a full aray strobing backlight for use with pc v-sync signal. I guess it blacks out a few frames every refresh (if the monitor is 2ms or faster) mitigating the 'sample and hold' effect. I can't verify any of this. Just relating what I read on the internet....lol
Sent from my DROIDX using Tapatalk 2
nodixe is offline
Old 04-21-2013, 01:53 PM
Otto Pylot's Avatar
Quoted: 1364 Post(s)
Liked: 854
They look ok but the color temp should be as close to 6500k as is possible and reflected off of a neutral wall. My bias light is around 5800k (CFL, not LED) according to the package but that is not certified and the CFI is not given either so it is at best approximate. I find the lack of light uniformity around the panel distracting but my opinion is just that, an opinion, and it's up to the OP as to what is best for him not what anyone else says. I saw an almost identical kit at Costco yesterday. BTW, using different colors, IMO, sort of defeats the purpose of a bias light.
Otto Pylot is offline
Old 04-21-2013, 02:47 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Generally bias lighting serves a few purposes.
1. Reduce eye fatigue
2. Make blacks look blacker
Even non d65 lights can do this ...
The downside of non d65 lights is that the color of the environment affects how we see color. Wrong lighting can prevent us from seeing what a calibrated display actually looks like regardless of how perfectly calibrated the display is. The viewer will never see it as a result of the environmental effects.
Now if the TV isn't really calibrated either, then it is all moot. No one died as a result of this.
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
Old 04-21-2013, 03:04 PM
N3W813's Avatar
Quoted: 23 Post(s)
Liked: 70
Nice! I did the same for my Sharp Elite 70" but the LED lights I purchased said it was rated at 6500k white and does not allow change of colors. Although I know it's not going to be as correct as the Idea-Lume (I have 2 for my other TVs), it is very close. I bought an ultra slim rack mount for my Elite and it is only 0.5" away from the wall. It would have been difficult for me to squeeze the Ideal-Lume behind the TV and also to run the power wire. smile.gif
For anyone else who is interested, this is what I bought...
LEDwholesalers 5050,30leds/m, Purewhite:6000-6500k,10mm white PCB,DC12V,5m/roll,Wires on one end,DC female connector on another end,2031PW
http://www.amazon.com/gp/product/B006OVUNCE/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
Dimmer with RF remote
http://www.amazon.com/gp/product/B004X4O1NG/ref=oh_details_o01_s00_i01?ie=UTF8&psc=1
PS. You will also need to purchase an AC/DC transformer power source for LED strips.
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is offline
Old 04-21-2013, 03:24 PM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
question: if the wall is not neutral colored, is there still a benefit to using D65 bias lighting in terms of color perception?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
Old 04-21-2013, 04:32 PM
GeorgeAB's Avatar
Quoted: 136 Post(s)
Liked: 240
As a general recommendation, the correct color temperature is going to align with video industry standards and best practices. Since we are in the calibration section of the forum, where picture accuracy is the dominant objective, one could assume that participants have or plan to provide the recommended neutral colored surrounding surface for the ambient lighting to reflect from. It's the illumination reflected by the wall that determines how a viewer's color perception of the display's image will be affected. These video fundamentals are discussed in the "sticky" thread section at the beginning of this area of the forum.
Education in video fundamentals is sorely lacking in the consumer video arena. Most consumers rely on a haphazard accumulation of video knowledge or just grope their way through designing their entertainment system by intuition. If intuition (what an individual viewer decides they "like") is the rule, AV science remains a foreign interest. When imaging science is the focus, a viewing experience approaching reference quality becomes attainable. Generally speaking, most consumers never get there. Their enjoyment of the beautiful images our advanced state of HDTV has enabled is minimized.
Only a cursory awareness of the purpose of video bias lighting for many hobbyists has resulted in the frequent focus on alleviating eye strain alone. When the video industry recommended practice documents are studied, it is found that the prevailing focus deals with preserving correct color perception, much more than viewing comfort. Seeing the image correctly has the profoundly greater emphasis. Seeing an authentic picture is the priority for those interested in display system calibration and proper equipment setup. Whether someone has ever died in the process rarely comes up, in my experience.
Best regards and beautiful pictures,
G. Alan Brown, President
CinemaQuest, Inc.
A Lion AV Consultants affiliate
"Advancing the art and science of electronic imaging"
turls likes this.
GeorgeAB is offline
