How to use a meter in non-contact mode with a plasma? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 05-06-2013, 01:53 AM
HDTVChallenged's Avatar
Liked: 215
Originally Posted by PlasmaPZ80U View Post
if you're going to check a few things out, ...
not sure if you are willing to do all that, but doing even 2-3 of those could shed some useful insights for those wondering how important the dark cals are and how they should be done in terms of balancing convenience vs. ideal practices... at least for an EEFL LCD
Unfortunately, my DVR backlog is probably going to keep me busy past the end of the season. I'll be lucky to find time to do a regular calibration, but I will check to see if using the black cap will work ... I suspect it will either work or it will throw an error.
To be honest, I'd just as soon use the i1Pro to profile something that doesn't need the periodic dark calibrations, but I haven't gotten that far ...
HDTVChallenged is offline
Old 05-06-2013, 01:55 AM
Liked: 215
Originally Posted by JimP View Post
On the i1pro2 it definitely does matter that you use the white tile.
Did I read somewhere that the Pro2 actually has the tile attached to the meter, or am I hallucinating again?
Old 05-06-2013, 03:12 AM
ConnecTEDDD's Avatar
Quoted: 1055 Post(s)
Liked: 1518
No, it's not attached.
For i1PRO1 the original base plate was required for reflectance measurements, or for running the X-Rite Diagnistics Software, but for emissive measurements, only an opaque surface that don't let light through was required.
Now i1PRO2 features a Built-in wavelength calibration technology and it's using the white tile to automatically self diagnose and correct for small shifts doing a mechanical alignment (of the 41 10nm increments binned from 128 sensors) based on that white's tile reflectance reading.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
Old 05-06-2013, 08:54 AM
PlasmaPZ80U's Avatar
Quoted: 1964 Post(s)
Liked: 560
that's what I remember reading a while back
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
Old 05-06-2013, 11:42 AM
Liked: 215
Thanks for clearing that up. Upon further reflection, I believe it's the ColorMunki spectro that has the target built in.
Old 05-06-2013, 12:53 PM
Quoted: 1393 Post(s)
Liked: 587
Would you happen to know if the self calibration is internal to the i1pro2 or does it rely on either drivers or code in the user software. In other words, if used in legacy mode, you don't get the benefit of this self calibration.
JimP is online now
Old 05-06-2013, 01:08 PM
Liked: 1518
You loose the mechanical alignment using Legacy Drivers.
