Colormunki smile - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-30-2013, 02:35 PM - Thread Starter
sillycargt4cs's Avatar
Hi would this budget meter be any good for calibrating a LCD TV.
In particular a 8000 series samsung.
Would hcfr have support for this or would it be better to purchase the colormunki display
sillycargt4cs is offline
post #2 of 7 Old 04-30-2013, 03:12 PM
derekjsmith's Avatar
Liked: 116
If you are looking for basic software and meter here is the SpectraCal C3 with CalMAN tutorial.
http://store.spectracal.com/consumer/meters/spectracal-c3.html
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #3 of 7 Old 04-30-2013, 03:16 PM - Thread Starter
Thanks Derek I really like the look of that package but living in the uk I worry I would get hammered with import duties tax etc
The c3 was my 1st choice but I'm looking elsewhere because of customs
post #4 of 7 Old 04-30-2013, 04:49 PM
Liked: 116
An option would be to find a X-Rite D3 retail for cheap in the UK and then use it with CalMAN.
Derek
post #5 of 7 Old 05-01-2013, 01:16 PM - Thread Starter
Do the colormunki meters not work with calman5 then?
post #6 of 7 Old 05-01-2013, 01:18 PM - Thread Starter
Also would it be better to buy a brand new colormunki display or a used i1 display pro
post #7 of 7 Old 05-04-2013, 03:55 PM
buttonsw's Avatar
Quoted: 40 Post(s)
I'm from the uk and have just got a Colormunki Display which is absolutely fantastic. I have had a quick go at Calibrating my 51D8000 plasma and the results are night and day, so easy with the Display and it's quick at reading.
Can't recommend it enough and from the UK as myself it's the best value option out there
Cheers, Steve
Pioneer KRP-500A | Sony STR-DH810 Receiver | Tannoy HTS101 Speakers
buttonsw is offline
Reply Display Calibration
