MadVR - ArgyllCMS - Page 100 - AVS Forum | Home Theater Discussions And Reviews
 480Likes
Old 03-19-2015, 02:49 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
Originally Posted by fhoech View Post
Which OS are you using? Can I have a screenshot?
Can't reproduce it, I'll grab a screenshot if I see it again.
zoyd is offline
Old 03-19-2015, 02:54 PM
Evanesco's Avatar
Quoted: 48 Post(s)
Liked: 31
Thanks. Argyll CMS seems to be working, so I assume the problem is with madTPG/madVR. Try resetting madVR settings (using "restore default settings.bat"), then un-installing/re-installing madVR. Are you using the latest madVR version (0.87.14 as of today)?
Thanks alot!!!
It helped with; restore default settings.bat and un-install/reinstall madvr. Now I'm getting patches in the madTPG window.
And now it's bedtime.
BR Gerard ;-)
PANASONIC TX-58AX800E ULTRA HD 4K LED TV
i1 Display Pro + CalMAN+ madVR Control Calibrated
YAMAHA RX-A2050 9.2 DOLBY ATMOS/DTS:X
ROTEL RB-1572
DALI MENTOR
NVIDIA Shield Android TV 500GB 4K/60Hz
Evanesco is offline
Old 03-19-2015, 03:06 PM
-Hitman-'s Avatar
Quoted: 134 Post(s)
Liked: 106
No, I'm not an eeColor owner. The only real issue back then as far as I can see from the archived mails was that one time, the 3D LUT wasn't uploaded to the eeColor completely.
No it was before that minor issue, you said - quote : "so unless an updated collink is available which fixes the eeColor scaling issue".
I'll dig out the emails and send you them via email tomorrow.
-Hitman- is offline
Old 03-19-2015, 03:15 PM
fhoech's Avatar
Quoted: 413 Post(s)
Liked: 275
Not necessary, I have them all archived.
fhoech is offline
Old 03-19-2015, 04:39 PM
sillysally's Avatar
Quoted: 856 Post(s)
Liked: 858
Using dispcalGUI 2901, argyll CMS 17b, madVR latest.
When I ran a calibration or profile the background color of madTPG set at 0, would always default back to about 57%.
Re-installed argyll 1.6.3 and 1.7 beta from last may, then the background stayed at 0%.
Also using argyll 1.7b, in my log file I would see error1 dispread or dispwin. One of those two.
ss
"Don't worry be happy"
sillysally is offline
Old 03-19-2015, 05:07 PM
fhoech's Avatar
Quoted: 413 Post(s)
Liked: 275
Confirmed, I need to make a small update to DCG so it works correctly with the current Argyll 1.7b. The update will be available in the next days, until then, please use the older Argyll CMS.
Can you attach the logfile? Thanks.
fhoech is offline
Old 03-19-2015, 05:56 PM
sillysally's Avatar
Quoted: 856 Post(s)
Liked: 858
Here is the log file.
ss
I installed the 3DLUT into my eecolor, results are not good after running a 493 measurement report.
Avg dE 1.78, high 4.31
Old 03-20-2015, 02:43 AM
Francois76l's Avatar
Quoted: 77 Post(s)
By older you mean argyllCMS 1.6.3 + 1.7 beta binary files dated from 2014-05-21?
Just to be sure. I will test this new version of dispcalgui after work
HiFi:Nad C320BEE+Marantz CD-63 MkII-Ki Signature+Boston VR2+DIY cabling
HC:Onkyo TX-SR875+Boston VR2+CR8+VRC+Subwoofer MJ Acoustic Ref1 MKII
DISPLAYS:Panasonic P50ST50E/JVC DLA-X35 + HTPC (LAV+ffdshow+Avisynth+MPC-BE+MadVr)
SCREEN: Lumene Movie Palace Premium 240C + Dedicated room
Francois76l is offline
Old 03-20-2015, 03:14 AM
Quoted: 102 Post(s)
Liked: 26
If you create a ZIP or 7Z archive of the profile folder, I can take a look.
fhoech,
Thank you for your help.
Last evening I did another session with DispcalGui (using your new beta version on installzero).
This time I prepared the session first:
- I reset "Cinema" mode on TV and set Contrast=54 and Brigthness=100 (I need this to ensure calibration controls work, otherwise they don't work as they supposed to);
- Did a new calibration with Chromapure using only 2-Point controls (Low=IRE20 and High=IRE100). I first profiled the i1D3 using my I1Pro;
- On DispcalGui:
- Created a "Colorimeter correction" with my i1Pro for the i1D3;
- Set the Whitepoint with the Chromacity coordinates x0.3127 and y0.329;
- Set Tone Curve for "Rec.1886";
- Used 6489 patches as the Testchart;
I noticed after +/-30 min of the process started that I got an error "inverting Jacobian failed (3) - falling back". I tried to search on google but found nothing meaningful.
This morning I tested the result and I found the same artefacts. This time I took a screenshot:
I created a Measurement Report too and the results were not very good:LINK
The Zip folder of the project is HERE if you can have a look and let me know what can I do to improve this results.
Thank you.
Pepelegal is offline
Old 03-20-2015, 05:52 AM
fhoech's Avatar
Quoted: 413 Post(s)
Liked: 275
Calibration and tone response don't look right:
Name:	Calibration curves madVR 2015-03-20 0.3127x 0.329y Rec. 1886 M-S XYZLUT.png
ID:	614017 Click image for larger version
Name:	Tone response curves madVR 2015-03-20 0.3127x 0.329y Rec. 1886 M-S XYZLUT.png
Profile self check also seems to indicate there's something off:
Code:
Profile check complete, peak err = 23.750742, avg err = 1.473592, RMS = 2.667376
(Peak should be < 5, avg < 1)
Is this a plasma? If so, make sure to use white level drift compensation and "Refresh" measurement mode (also, you can usually skip calibration i.e. set calibration tone curve to "as measured").
Pepelegal likes this.
fhoech is offline
Old 03-20-2015, 05:54 AM
fhoech's Avatar
Quoted: 413 Post(s)
Liked: 275
Only if you need the black background (i.e. for plasma), although there is also an issue with the patch size not sticking if it's not already the desired size when madTPG is launched.
fhoech is offline
Old 03-20-2015, 06:07 AM
Quoted: 102 Post(s)
Liked: 26
Attachment 614017 Attachment 614025
Is this a plasma? If so, make sure to use white level drift compensation and "Refresh" measurement mode.
This is an OLED. I usually with calibration SW use it like an LCD.
But I will do another session with those options enabled.
Old 03-20-2015, 06:13 AM
fhoech's Avatar
Quoted: 413 Post(s)
Liked: 275
Seems like it's the wrong file, as it contains no measurement progress and the other usual things.
fhoech is offline
Old 03-20-2015, 06:22 AM
Quoted: 77 Post(s)
Not clear for me sorry...
For a projector (fullscreen patch size) I can use the last beta version or should I downgrade to Argyll 1.6.3 + 1.7 beta binary files dated from 2014-05-21?
Old 03-20-2015, 06:29 AM
zoyd's Avatar
Liked: 1055
I would also suggest starting with a smaller patch set, something like 1500, to test the workflow. After you get decent results from that then "go for the gold". It certainly looks like there were some severe misreads from your last run - you should use windowed patterns on OLED because they have brightness limiters like plasma.
zoyd is offline
Old 03-20-2015, 06:34 AM
Quoted: 102 Post(s)
Liked: 26
Code:
...also, you can usually skip calibration i.e. set calibration tone curve to "as measured").
Do you think that peak error may be due to the calibration problem? I noted on the Measurement Report that 20% gray (r51,g51,b51) is way off for some reason...
If I understand you correctly that means I can use the TV greyscale calibration as it is (done using manual calibration) and just create the 3D LUT on top of that for MadVR, am I right ?
Doesn't the calibration done by dispcal wouldn't be much better than what is possible to do using just the TV controls? wouldn't that be preferably ?
Thank you
Old 03-20-2015, 07:03 AM
fhoech's Avatar
Quoted: 413 Post(s)
Liked: 275
DCG 2.9.0.2 beta is now live which should fix the madTPG issue aswell as saving 3D LUTs in non-madVR format now correctly remembers the chosen location the next time. These are the only two changes from 2.9.0.1.
fhoech is offline
Old 03-20-2015, 07:05 AM
fhoech's Avatar
Quoted: 413 Post(s)
Liked: 275
It certainly looks like it's influenced by that.
Yes.
In theory yes, in practice the 3D LUT often does the job nicely regardless if 1D LUT calibration was used or not.
fhoech is offline
Old 03-20-2015, 07:06 AM
Quoted: 77 Post(s)
ok fhoech, thanks
Old 03-20-2015, 08:23 AM
Kukulcan's Avatar
Quoted: 21 Post(s)
Liked: 25
Hi guys, about Pepelegal issue, please note that the LG Oleds have a brightness limiter that strongly kicks in as soon as the TV "sees" a fix geometry pattern for a long time period.
This is an issue experienced by ChadB and described in its first review of an LG Oled. I can remember that he found it pretty annoying even for a calibration. I fear that without any trick for sidestepping it, this limiter can severely compromise any attempt to make a good profile.
So my first idea is trying the "as measured" tone curve, and let's say, 500 patches. White drift compensation may not help, because that limiter probably acts rapidly and between very few patches.
Kukulcan is offline
Old 03-20-2015, 08:35 AM
Quoted: 102 Post(s)
Liked: 26
I found it difficulty to use a window size on MadTPG.
Each time I set the internal area to (for example) 15%, DispCal patches always change it and use 100% FullScreen...
Is there any setting to change this inside Dispcal ?
Old 03-20-2015, 08:39 AM
Quoted: 102 Post(s)
Liked: 26
I remember Chad mentioned that but I would assume that a change in color patch would deny the ABL...
I'm not noticing ABL kicking in for what I see..only when I let the same pattern on for some time.
Old 03-20-2015, 08:54 AM
fhoech's Avatar
Quoted: 413 Post(s)
Liked: 275
If you adjust patch size before the countdown reaches zero, all should be fine.
fhoech is offline
Old 03-20-2015, 09:13 AM
Quoted: 102 Post(s)
Liked: 26
Well.. I was able to Pause and set the window to 15% and it works for some time, but then when a new set of patches start, it turns to fullscreen again.
I suppose it would be nice to have some knob to choose between using full fields or a window size on dispcal or at least to let use the user's window setting on madTPG.
Btw, "refresh" mode and turning on white compensation did not work...I did a quick test and the same problem happened
I'm currently creating just the 3DLUT using tone curve "as measure" and see if it works.
Old 03-20-2015, 09:27 AM
zoyd's Avatar
Liked: 1055
For me using 2.9.0.2 the madVR window size stays where I want it but the background switches to 50% regardless of the setting. I know ArgyllCMS has 50% hardwired unless you use the -F switch, I get around this in HCFR by exposing these settings to the user via the madVR api.
Did a quick test of the PCS->device profiling and LUT mapping flow and it worked well. The amount of time in colprof was ~doubled but collink was super fast. Measured results were very close to the normal flow.
zoyd is offline
Old 03-20-2015, 09:40 AM
Quoted: 102 Post(s)
Liked: 26
Interesting...I'm able to set background to 100% black (APL linear gama) and it retains the setting but window size turns to full screen each time a set of patches begin. I have to Pause and set the size of the window to 15% each time ...
Edit: btw I'm using also 2.9.0.2
Old 03-20-2015, 10:00 AM
fhoech's Avatar
Quoted: 413 Post(s)
Liked: 275
Which exact version of DCG, Argyll and madVR are you using?
As soon as Argyll's dispcal/dispread takes over, there's nothing that I can influence anymore. So the way it works currently is DCG grabs patch area size and background level % off of madTPG using the madVR_GetPatternConfig() API, and uses that to set the -P parameter for the Argyll tools and adds the -F switch (black background) if the background level is zero.
fhoech is offline
Old 03-20-2015, 10:16 AM
zoyd's Avatar
Liked: 1055
ok right, you don't have control of it at that point. So we should request that Graeme change ArgyllCMS to keep the background level as set by the user.
zoyd is offline
Old 03-20-2015, 10:17 AM
Quoted: 102 Post(s)
Liked: 26
I'm using:
DispcalGui: 2.9.0.2
Pygame:1.9.1
Python:2.7.6.1
wxPython:3.0.1.0
NumPy:1.8.0
WMI:1.4.7
7-zip Command Line: 9.20
Argyll CMS: 1.6.3
madVR: v0.87.14
Old 03-20-2015, 10:35 AM
zoyd's Avatar
Liked: 1055
LUTs will be tricky for any device that does this, probably requiring some way to periodically change window size. The other problem is that a display pro can't read the black and very near black on these devices so some XYZ channels will return 0 for some number of patches and I don't know if this is problem for the fitting routines.
zoyd is offline
