MadVR - ArgyllCMS - Page 113 - AVS | Home Theater Discussions And Reviews
 180Likes
post #3361 of 3378 Old 04-20-2015, 05:49 AM
Quoted: 78 Post(s)
Liked: 5
Just a correction: I checked my madVR settings and I found that I had set "16-235" (only on madVR, in all other places it is 0-255).
Pepelegal is online now
post #3362 of 3378 Old 04-20-2015, 09:37 AM
MarcusSwe's Avatar
Pepelegal: Thank you very much for all the guidance - I will try it now!
On another note, I'd thought I'd give it a go and calibrate my iMac (in target display mode using the PC) with DCG. The strange thing is that I got odd results here as well, once again at low IREs. No artifacts though. Here's all the files: http://s000.tinyupload.com/?file_id=...23385901054840
Low level gamma becomes way too "high" (comes out of black too fast). The calibrated 2.2-profile displays gamma 5 IRE@1,9, 10@2.0 and then it finishes at 2.2 from IRE 40 and onwards. This has me thinking: either the readings are wrong at low IRE (which seems strange since the reader measures correctly (and confirms what I am seeing) in Chromapure) or the applied gamma curve is set wrongly in DCG (it creates a 2.2-gamma at high IRE, but the curve resembles a 1886-gamma that is set "0,2 steps too low", so to say).
Are there any hidden gamma settings in DCG that I can enable? (now I can only choose 2.2, 2.4 and absolute or 1886 (though the absolute or 1886 seems to give the same results (1886-"slope"), i.e. when I choose 2.4, it doesn't matter if I select absolute or 1886, it gives the same results). Because if I could just manually force another gamma response, that would probably take care of the problem.
In the meantime, I will get back to the OLED
And huge thanks for creating such awesome software and all input from everyone else here at the forum!
MarcusSwe is offline
post #3363 of 3378 Old 04-20-2015, 12:09 PM
fhoech's Avatar
Quoted: 191 Post(s)
Liked: 123
A DCG beta snapshot update is available.
Changes in 2.9.1.0 beta:
  • When using madTPG during interactive display adjustment, automatically leave fullscreen, and re-enter fullscreen for non-interactive display measurements. Also, if the OSD is disabled, temporarily re-enable it for "put the instrument on screen" messages.
  • Fixed minor quirk of log messages being repeated multiple times in session logfiles (bug introduced in 2.9.0.9).
Changes in 2.9.0.9 beta (never announced, thus FYI):
  • Added a button to create a compressed archive (7z or ZIP) of the currently selected profile and related files.
  • When using Resolve, fixed the possibility of APL pattern background RGB values getting negative (and thus rejected by Resolve, leading to the displayed pattern not being updated) if the test color is bright and the chosen test patch area is large.
anta1974 likes this.
DCG (dispcalGUI) - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 2.6
Current development snapshot 2.9.1.0 beta (2015-04-20) - via 0install or standalone
fhoech is offline
post #3364 of 3378 Old 04-20-2015, 01:41 PM
fhoech's Avatar
Quoted: 191 Post(s)
Liked: 123
Always start from a preset that's appropriate for the job. The profile you uploaded doesn't contain high-quality tables that are needed for a display profile. You can fix this by going into the "Options" menu, selecting "Enhance effective resolution of PCS to device tables" and choosing the existing profile.
[...] i.e. when I choose 2.4, it doesn't matter if I select absolute or 1886, it gives the same results).
Rec. BT 1886 is equivalent to 2.4 absolute with 0% black output offset.
fhoech is offline
post #3365 of 3378 Old 04-21-2015, 01:01 AM
sillysally's Avatar
Quoted: 247 Post(s)
Liked: 325
[LIST][*]When using madTPG during interactive display adjustment, automatically leave fullscreen, and re-enter fullscreen for non-interactive display measurements. Also, if the OSD is disabled, temporarily re-enable it for "put the instrument on screen" messages.[*]Fixed minor quirk of log messages being repeated multiple times in session logfiles (bug introduced in 2.9.0.9).<<<snip>>>
Once I re-enter fullscreen display when running interactive display measurements, and OSD is enabled, a pup up comes up on the left top of the screen that says argyllCMS patches, no count down.
However all seems to work if OSD is disabled except for place meter on the screen patch and no count down.
When running a verification, I don't have to re-enter fullscreen display. The message for place K10 on screen come up and the count down starts.
Works as I would think it should.
btw, why are you asking to place meter on the patch/screen, when using meter in off screen mode?
ss
sillysally is offline
post #3366 of 3378 Old 04-21-2015, 03:21 AM
fhoech's Avatar
Quoted: 191 Post(s)
Liked: 123
The count-down only appears in fullscreen when not doing interactive adjustment. It's meant as a work-around for a single-screen situation where both madTPG and the interactive adjustment window have to be on at the same time, i.e. you'd do the interactive adjustment while not in fullscreen.
Because there's no way to detect if the meter is used in contact mode or not.
fhoech is offline
post #3367 of 3378 Old 04-21-2015, 11:48 AM
sillysally's Avatar
Quoted: 247 Post(s)
Liked: 325
Yes I know there is no way of detecting on or off screen mode, just wanted to make sure that gwgill didn't make some more magic and need the meter to be on screen.
Tried auto mode (9200+) with calibration (slow), worked very well.
Can you extend the number of patches for auto mode?
ss
post #3368 of 3378 Old 04-21-2015, 12:24 PM
fhoech's Avatar
Quoted: 191 Post(s)
Liked: 123
Sure. How many patches would you like (roughly)? The next step up would be 11140.
sillysally likes this.
fhoech is offline
post #3369 of 3378 Old 04-21-2015, 12:43 PM
sillysally's Avatar
Quoted: 247 Post(s)
Liked: 325
11140 should work.
I am trying to compare with my custom built testcharts. The largest testchart I have used is about 13200.
After viewing the log on the auto mode run, I like how it seems to work.
Is this and the black hack what gwgill was refering to when he said he was making argyllCMS "a little smater".
ss
post #3370 of 3378 Old 04-21-2015, 01:14 PM
fhoech's Avatar
Quoted: 191 Post(s)
Liked: 123
11140 should work.
Ok, I've updated (only) the DCG 0install Windows feed with 2.9.1.1 to unlock this, so you need to update manually.
I tried to choose sensible parameters. Glad to hear it seems to work well for you.
There are many detail improvements, and some new features like this.
sillysally and anta1974 like this.
fhoech is offline
post #3371 of 3378 Old 04-21-2015, 01:28 PM
anta1974's Avatar
Quoted: 20 Post(s)
Where i can download this new version argyllCMS?
anta1974 is online now
post #3372 of 3378 Old 04-21-2015, 01:38 PM
fhoech's Avatar
Quoted: 191 Post(s)
Liked: 123
There is currently no official release, but Graeme is working on it.
fhoech is offline
post #3373 of 3378 Old 04-22-2015, 12:53 AM
anta1974's Avatar
Quoted: 20 Post(s)
and it is possible to receive the test this version argylcms?
post #3374 of 3378 Old 04-22-2015, 04:46 AM
fhoech's Avatar
Quoted: 191 Post(s)
Liked: 123
Instructions here: MadVR - ArgyllCMS
fhoech is offline
post #3375 of 3378 Unread Today, 03:27 AM
anta1974's Avatar
Quoted: 20 Post(s)
Originally Posted by zoyd View Post
I ran the normal sequence I use of about 2500 patches, DispcalGUI 2.9.0.2, madVR 0.87.14, ArgyllCMS 1.7.1b(mar6) - no problems detected
Zoyd!
Where is i can download ArgyllCMS 1.7.1b(mar6)?
post #3376 of 3378 Unread Today, 03:32 AM
zoyd's Avatar
Quoted: 737 Post(s)
Liked: 633
There is no difference in LUT profiling or gamut mapping between the march 6 build and the current build.
zoyd is online now
post #3377 of 3378 Unread Today, 03:55 AM
anta1974's Avatar
Quoted: 20 Post(s)
Ok, but current build 1.7.0!
Where i can find 1.7.1 ?
post #3378 of 3378 Unread Today, 04:27 AM
zoyd's Avatar
Quoted: 737 Post(s)
Liked: 633
zoyd is online now
Reply Display Calibration
