MadVR - ArgyllCMS - Page 115 - AVS Forum | Home Theater Discussions And Reviews
 491Likes
post #3421 of 4593 Old 04-28-2015, 11:16 AM
madshi's Avatar
Quoted: 571 Post(s)
Liked: 539
Originally Posted by fhoech View Post
Hmm. So is this an issue with this particular projector and high bitdepth signals? Does the image also degrade with the AMD card?
I believe it's an issue with this specific projector. The image degrades in a similar way with both NVidia and AMD.
I wish I could figure out if my graphics card is sending a higher than 8 bit signal to the TV. I'm certain it's not the case for my desktop monitor as over DVI it would require a dual-link connection AFAIK, and I think the monitor does only support 8-bit input.
I think most GPU DVI outputs are dual-link these days. E.g. I've got 1080p60 with RGB 12bit out of the DVI port of my NVidia GPU, using a DVI->HDMI adapter (according to my projector). But to be honest, I've no idea which computer monitors support more than 8bit RGB input and which don't. My computer monitors are pretty old, so I didn't think they would support it. But they both show a nicely banding free gray ramp with 10bit output, with dithering turned off in madVR, with all Intel, NVidia and AMD. So I'm not sure what to think.
Well, a new madVR version with 10bit output will be available soon, then we'll get some more feedback from users...
anta1974 and fhoech like this.
madshi is offline
post #3422 of 4593 Old 04-28-2015, 04:11 PM
mightyhuhn's Avatar
Quoted: 770 Post(s)
Liked: 263
madshi you are aware of this new option in the AMD driver:
http://abload.de/img/amdbitdeepcontrol43u54.png
was added in one of the 14.x driver.
mightyhuhn is online now
post #3423 of 4593 Old 04-28-2015, 04:28 PM
baii's Avatar
Quoted: 25 Post(s)
There was a discussion on GPU ability to output certain bit depth. I remembered it kind of concluded PRO cards are only needed for OPENGL 30bit.
yea, and that AMD CCC thingy that added last year. It is a total different option from the pro card 10bit option page.
baii is offline
post #3424 of 4593 Old 04-29-2015, 12:22 AM
madshi's Avatar
Quoted: 571 Post(s)
Liked: 539
Ah yes, I remember that option. Maybe I should update my driver...
madshi is offline
post #3425 of 4593 Old 04-29-2015, 02:19 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Maybe you add in new madVR version and 12bit output?
anta1974 is offline
post #3426 of 4593 Old 04-29-2015, 02:37 AM
madshi's Avatar
Quoted: 571 Post(s)
Liked: 539
Windows doesn't know/support 12bit output. It only supports 10bit or 16bit. And 16bit support is very weird, and broken in most drivers. So I won't support that (for now).
anta1974 likes this.
madshi is offline
post #3427 of 4593 Old 04-29-2015, 10:02 AM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
I have an AMD video card for my laptop. I can confirm that my video card can for a fact output 8,10,12 bit video levels. However what you need to be careful of is that the AMD video card(well at least mine anyways) is not bit perfect. I have verified this with my DVDO TPG with its colorchecker feature.
What is interesting though is that I now use a usb to HDMI converter box instead of using the HDMI output on my laptop. This setup does in fact produce dead on bit perfect levels.
I guess it could be something specific to my laptop too, but I just wanted to throw it out there.
1forsnow is offline
post #3428 of 4593 Old 04-30-2015, 02:16 AM
petoulachi's Avatar
Quoted: 22 Post(s)
Hello,
I'm new to calibration, and I'm trying to create my first 3DLUT for MadVR using a i1-Pro, on my Panasonic Plasma P55ST60. I've set both TV and video card (Intel HD5000) for 0-255.
Here is the result I get after calibration :
The calibration curve seems odd ?
And the result text :
Size 399300 Bytes (389.94 KiB)
Preferred CMM 0x6172676C 'argl' Argyll CMS
ICC version 2.2
Profile class Display device profile
Color model RGB
Profile connection space (PCS) XYZ
Created 2015-04-30 02:39:25
Platform Microsoft
Is embedded No
Can be used independently Yes
Device
Manufacturer 0x00000000
Model 0x00000000
Attributes Reflective
Glossy
Positive
Color
Default rendering intent Media-relative colorimetric
PCS illuminant XYZ 96.42 100.00 82.49 (xy 0.3457 0.3585, CCT 5000K)
Creator 0x6172676C 'argl' Argyll CMS
Checksum 0xCA8BF27F329BE52ED9471C3BFBE248C2
Checksum OK Yes
Description (ASCII) madVR 2015-04-29 0.3127x 0.329y Rec. 1886 S XYZLUT
Copyright No copyright. Created with dispcalGUI 2.6.0.0 and
Argyll CMS 1.6.3
Device model name (ASCII) madVR
Luminance 42.82 cd/m²
Media white point
Is illuminant Yes
Illuminant-relative XYZ 95.26 100.00 109.40 (xy 0.3127 0.3282)
Illuminant-relative CCT 6511K
ΔE 2000 to daylight locus 0.44
ΔE 2000 to blackbody locus 2.66
Media black point
Illuminant-relative XYZ 0.0168 0.0153 0.0320 (xy 0.2619 0.2381)
Illuminant-relative CCT 30606K
Colorants (PCS-relative)
Red XYZ 107.14 55.10 3.19 (xy 0.6476 0.3331)
Green XYZ 77.63 142.15 19.01 (xy 0.3251 0.5953)
Blue XYZ 40.68 18.38 198.98 (xy 0.1576 0.0712)
Video card gamma table
Bitdepth 16
Channels 3
Number of entries per channel 256
Channel 1 gamma at 50% input 1.70
Channel 1 minimum 0.1694%
Channel 1 maximum 93.66%
Channel 1 unique values 168 @ 8 Bit
Channel 1 is linear No
Channel 2 gamma at 50% input 1.70
Channel 2 minimum 0.1953%
Channel 2 maximum 94.71%
Channel 2 unique values 170 @ 8 Bit
Channel 2 is linear No
Channel 3 gamma at 50% input 1.69
Channel 3 minimum 0.7843%
Channel 3 maximum 95.19%
Channel 3 unique values 168 @ 8 Bit
Channel 3 is linear No
Device to PCS: Intent 0
Matrix 1.0000 0.0000 0.0000
0.0000 1.0000 0.0000
0.0000 0.0000 1.0000
Input Table
Channels 3
Number of entries per channel 2048
Color Look Up Table
Grid Steps 33
Entries 35937
Output Table
Channels 3
PCS to device: Intent 0
Input Table
Channels 3
Number of entries per channel 512
Color Look Up Table
Grid Steps 9
Entries 729
Output Table
Channels 3
Red matrix column
Illuminant-relative XYZ 18.13 7.24 95.53 (xy 0.1500 0.0599)
PCS-relative XYZ 14.31 6.06 71.41 (xy 0.1559 0.0660)
Green matrix column
Illuminant-relative XYZ 41.29 21.28 1.94 (xy 0.6400 0.3299)
PCS-relative XYZ 43.61 22.25 1.39 (xy 0.6485 0.3309)
Blue matrix column
Illuminant-relative XYZ 35.84 71.47 11.96 (xy 0.3005 0.5992)
PCS-relative XYZ 38.51 71.69 9.71 (xy 0.3212 0.5978)
Red tone response curve
Number of entries 256
Transfer function sRGB
Minimum Y 0.0000
Maximum Y 100.00
Green tone response curve
Minimum Y 0.0000
Maximum Y 100.00
Blue tone response curve
Minimum Y 0.0000
Maximum Y 100.00
Characterization target [144316 Bytes]
Characterization device values [144316 Bytes]
Characterization measurement values [144316 Bytes]
Chromaticity (illuminant-relative)
Channel 1 (R) xy 0.6395 0.3323
Channel 2 (G) xy 0.3041 0.5968
Channel 3 (B) xy 0.1511 0.0638
Metadata
CMF_binary dispcalGUI
CMF_version 2.6.0.0
CMF_product dispcalGUI
License Public Domain
Quality high
OPENICC_automatic_generated 0
DATA_source calib
MEASUREMENT_device i1 displaypro, colormunki display
prefix CMF_
DATA_
MEASUREMENT_
OPENICC_
ACCURACY_
GAMUT_
ACCURACY_dE76_avg 1.079490
ACCURACY_dE76_max 9.718158
ACCURACY_dE76_rms 1.806122
GAMUT_volume 1.83057427865
GAMUT_coverage(srgb) 0.9931
GAMUT_coverage(adobe-rgb) 0.8209
My main concern is when saving the 3DLUT :
Why Input and Output encoding are set to 16-235 instead of 0-255 ?
Also, What should I do on my TV before calibration with settings like contrast, luminosity ? I know that on computer screen we usually set the contrast to the maximum before doing calibration, do I need to do the same here ?
Thanks for your help !
petoulachi is offline
post #3429 of 4593 Old 04-30-2015, 04:25 AM
monvo's Avatar
Is there somewhere one can see how much of the target garmut the display covers? E.g. 97% of sRGB or something like that.
monvo is offline
post #3430 of 4593 Old 04-30-2015, 06:39 AM
fhoech's Avatar
Quoted: 425 Post(s)
Liked: 281
Originally Posted by petoulachi View Post
Looks like a problem with ABL. Enable white level drift compensation and use small pattern size e.g. 8% with 22-25% background level.
Because that's the (only) correct setting for madVR 3D LUTs. As a side note, this has nothing to do with 0..255 / 16..235 in madVR or video driver settings.
Just make sure none of the channels clip (seems to be fine already). You can adjust the whitepoint during interactive display adjustment.
anta1974 and petoulachi like this.
DisplayCAL - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 3.3.2 released 2017-06-29
Previous development snapshot (OUTDATED): 3.2.9 Beta (Windows/0install) released 2017-05-23 | Standalone | Changelog
DisplayCAL on Facebook
fhoech is offline
post #3431 of 4593 Old 04-30-2015, 06:41 AM
fhoech's Avatar
Quoted: 425 Post(s)
Liked: 281
Click the "Install profile" button next to settings, or bring up the profile information window (the left pane contains an entry GAMUT_coverage(sRGB) which gives the percentage when multiplied by 100.
fhoech is offline
post #3432 of 4593 Old 04-30-2015, 07:14 AM
petoulachi's Avatar
Quoted: 22 Post(s)
What is "small pattern size" and "background level" ? Sorry for newbe question, I guess it's in the testchart but can't find where :
Ok, so nothing to worry. I keep my 0-255 settings then.
In fact I've already have set my TV for best possible color and luminosity. But I was thinking that maybe it's better to set a big contrast and luminosity and then let the 3DLUT adjust color&luminosity. Guess I was wrong then
post #3433 of 4593 Old 04-30-2015, 07:32 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
[17:36:13] WARN: Falling back to secondary solver for http://dispcalgui.hoech.net/0install/dispcalGUI.xml. Primary solver reported:
[17:36:13] WARN: Dependency graph too complex
Zero install
Why?
anta1974 is offline
post #3434 of 4593 Old 04-30-2015, 08:25 AM
fhoech's Avatar
Quoted: 425 Post(s)
Liked: 281
No, in madTPG (the two sliders).
petoulachi likes this.
fhoech is offline
post #3435 of 4593 Old 04-30-2015, 08:28 AM
petoulachi's Avatar
Quoted: 22 Post(s)
Oh ok I see !! Thanks, I'll try that and post result here !
post #3436 of 4593 Old 04-30-2015, 08:32 AM
fhoech's Avatar
Quoted: 425 Post(s)
Liked: 281
Zero install
Why?
Please use the "Select version" entry in the start menu (just click OK on the window). Should work using the normal shortcuts as well after that.
fhoech is offline
post #3437 of 4593 Old 04-30-2015, 02:43 PM
sillysally's Avatar
Quoted: 917 Post(s)
Liked: 904
It seems the latest version of madVR/TPG is 0.87.21.
Is this correct?
ss
"Don't worry be happy"
sillysally is offline
post #3438 of 4593 Old 04-30-2015, 03:00 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
zoyd is offline
post #3439 of 4593 Old 05-02-2015, 06:21 AM
Quoted: 13 Post(s)
Liked: 1
Hello guys, just maybe a stupid question but could it be possible to launch a screen saver a the end of the calibration?? Indeed, I would like to launch a large testchart but I can only do it during the night so I will not be present when it will be over and my plasma screen don t like static pictures
yokbob is offline
post #3440 of 4593 Old 05-02-2015, 08:03 AM
fhoech's Avatar
Quoted: 425 Post(s)
Liked: 281
I may be wrong, but I believe this should already work, i.e. you simply setup the screensaver and while measurements are running it will automatically be disabled. I would definitely test this if I were you though, by setting the screensaver delay to a low value (e.g. 2 minutes) and then starting a longer measurement. If it doesn't go into screen saver mode after a couple minutes, you're probably good to go. If you're using "automatic" mode of DCG 2.9.x beta make sure to set a long enough delay to allow for a gap between measurements, e.g. 10-15 minutes or so should suffice.
fhoech is offline
post #3441 of 4593 Old 05-02-2015, 03:45 PM
sillysally's Avatar
Quoted: 917 Post(s)
Liked: 904
@fhoech
I ran a calibration (slow), auto test chart (11120) using DispcalGUI (2.9.1.3)
ArgyllCMS (1.7.0 final version) and madVR (87.21).
All worked well with NP.
My question is when I open up testchart builder, adding up the different points there should only be 10278 patches. However total patches says 11120, were are the extra patches coming from?
ss
post #3442 of 4593 Old 05-02-2015, 04:06 PM
fhoech's Avatar
Quoted: 425 Post(s)
Liked: 281
The 154 preconditioning patches are added back in (in total it may be less than the sum of the two patchsets because duplicates from the 154 patch preconditioner are discarded).
fhoech is offline
post #3443 of 4593 Old 05-03-2015, 04:35 AM
petoulachi's Avatar
Quoted: 22 Post(s)
Screensaver won't launch. I suspect MadTPG to disable it, so it's not on your side !
post #3444 of 4593 Old 05-03-2015, 11:14 AM
fhoech's Avatar
Quoted: 425 Post(s)
Liked: 281
As you may have already noticed, I've released DCG 3.0 - link to the website with download & changelog in the signature. Only minor changes from the previous beta snapshot (2.9.1.3), mainly added support for the Spyder 5 in conjunction with Argyll CMS 1.7.
fhoech is offline
post #3445 of 4593 Old 05-04-2015, 07:22 AM
petoulachi's Avatar
Quoted: 22 Post(s)
I'm still having problem with white after calibration (using a test video for white pattern, the 240-255 range blinks in a pink color ?!). After looking at the settings (now on the new 3.0 using argyII 1.7), I think the problem come from the "calibration" settings.
What am I supposed to do with whitepoint setting ? in fact I had stupidly take the screenshot values with x and y but I'm pretty sure I have to set my own value ?
Sorry for the noob question
post #3446 of 4593 Old 05-04-2015, 07:43 AM
mightyhuhn's Avatar
Quoted: 770 Post(s)
Liked: 263
what white test did you used?
post #3447 of 4593 Old 05-04-2015, 07:45 AM
petoulachi's Avatar
Quoted: 22 Post(s)
a MKV called "MadVR.adjust.TV-PC.levels". It is usually used to be sure you have the complete video setup correctly set in 0-255.
post #3448 of 4593 Old 05-04-2015, 08:10 AM
mightyhuhn's Avatar
Quoted: 770 Post(s)
Liked: 263
after some googleing it looks like it is the same file as 3-white clipping from this source:
AVS HD 709 - Blu-ray & MP4 Calibration
If this is the case. what do you see with a disabled 3D LUT.
does 235 and below look normal with a active 3d LUT?
because 240+ looks pink i guess your screen is white clipping and the things you see there shouldn't be in any source. so everything is fine.
Last edited by mightyhuhn; 05-04-2015 at 08:11 AM. Reason: didn't linked the source...
post #3449 of 4593 Old 05-04-2015, 10:24 AM
fhoech's Avatar
Quoted: 425 Post(s)
Liked: 281
The 3D LUT will try to hue correct WTW if present I think, but it might be that one or several of the channels are already clipping at that point, which can lead to color casts in the WTW range like you've observed. The only way around that is to clip WTW entirely. Argyll 1.7 introduced an option for this, and in DCG it can be used by setting 3D LUT input encoding to "TV RGB 16-235 (clip WTW)".
If you've used the madVR preset, the whitepoint chromaticity coordinates will be set for D65 white, so there's no need to change those. If you've already adjusted the display you may want to uncheck "Interactive display adjustment" to skip that step.
fhoech is offline
post #3450 of 4593 Old 05-04-2015, 01:01 PM
transendance's Avatar
Sorry about the repost from eecolor, thought perhaps I was in the wrong forum there to answer this noob question.
When I adjust the patch size to 10% for plasma calibration in madtpg and start calman calibration the patch on the extended screen......resizes immediately to 100%.
What am I doing wrong?
Help much appreciated, T.
transendance is offline
Reply Display Calibration
