MadVR - ArgyllCMS - Page 117 - AVS | Home Theater Discussions And Reviews
 205Likes
post #3481 of 3485 Old Today, 01:45 AM
anta1974's Avatar
Quoted: 25 Post(s)
Dear Florian!
Thank you very much for your answers.
Please help to understand -
what is the difference calibration speed?
High, medium, low ?
Number of measurements?
Smoothing method - mean or median?
With great respect and gratitude, Andrei.
anta1974 is online now
post #3482 of 3485 Old Today, 01:49 AM
anta1974's Avatar
Quoted: 25 Post(s)
What is best for my 3DLUT -
1) XYZ LUT+ matrix
or
2) XYZ LUT+swapped matrix ?
More help me understand please in edit teschart.
1) What is add saturation sweeps 2-255? by changes nothing changes.
2) Where you can select the number of points gamma?
3) Where you can select the number of points grayscale?
I found - neutral patches best 121, maximum for 8 bit and 20% dark emphasis -129. True?
post #3483 of 3485 Old Today, 01:52 AM
anta1974's Avatar
Quoted: 25 Post(s)
Originally Posted by fhoech View Post
Not sure if I understand the question, but Rec. 1886 is defined by three parameters: Gamma exponent (2.4), how input is mapped to output ("Absolute" or technical gamma), and the amount of output offset (0%).
Note that on the "Verification" tab, you can only choose settings other than exponent if the profile blackpoint is not zero (because with a zero blackpoint, only exponent will affect the result). On the "Calibration" and "3D LUT" tabs (if not creating a 3D LUT from an existing profile), black point is not yet known so all controls are available, but may not make a difference depending on measured black point.
Why it was previously a function ? Point 4
Measurement report=Verification in new dispcalgui - is not it ?
post #3484 of 3485 Old Today, 06:36 AM
baii's Avatar
Lower calibration speed will try to achieve a lower delta e in the calibration phase. Swapped matrix is there so that it expose if certain software using the profile incorrectly. You can refer to the documentation on argyllcms and DCG for a better explanation.
Verification is the same as the generate measurement report if I am not mistaken.
Unless you have special need, the default testcharts will give you the "best" result.
Sent from my 306SH
anta1974 likes this.
baii is online now
post #3485 of 3485 Old Today, 11:59 AM
fhoech's Avatar
Quoted: 220 Post(s)
Liked: 140
1) XYZ LUT+ matrix
or
XYZ LUT+swapped matrix (which is the default for all 3D LUT presets) because it saves a bit of processing time (the matrix is not used when generating the 3D LUT).
You have to click one of the R, G, B, C, M, Y buttons after generating a testchart. It'll add the sweeps after the selected patch in the spreadsheet.
Those would be neutral patches.
129 is the maximum still resolving to individual steps in 8-bit, with 20% dark region emphasis.
DCG (dispcalGUI) - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 3.0
fhoech is online now
Reply Display Calibration
