MadVR - ArgyllCMS - Page 118 - AVS Forum | Home Theater Discussions And Reviews
 482Likes
Old 05-12-2015, 11:00 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Choosing levels madTPG in HCFR I change output levels in madVR?
Maybe?
anta1974 is offline
Old 05-12-2015, 11:14 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
Maybe?
no, the madTPG output levels are determined by the madVR settings. HCFR 16-235 or 0-255 don't matter when using madTPG.
anta1974 likes this.
zoyd is offline
Old 05-13-2015, 12:40 AM
petoulachi's Avatar
Quoted: 22 Post(s)
Originally Posted by petoulachi View Post
Ok, just done that, and choose "Spectral: Plasma (EDR for Plasma created with primaries R, G, B and White)" for correction.
I'll do a new calibration tonight to see what's the result, hope this time it will be ok !
Thanks again !
A bit late, but I've made a new calibration this night, with interactive display adjustement, no tone curve calibration (as mesured), White level drift compensation and Spectral : Plasma correction. Also, I've used the testchart given by N3W813. The result is very bad :
Code:
 Size	928060 Bytes (906.31 KiB)
 Preferred CMM	0x6172676C 'argl' Argyll CMS
 ICC version	2.2
 Profile class	Display device profile
 Color model	RGB
 Profile connection space (PCS)	XYZ
 Created	2015-05-13 07:15:49
 Platform	Microsoft
 Is embedded	No
 Can be used independently	Yes
 Device
     Manufacturer	0x00000000
     Model	0x00000000
     Attributes	Reflective
 	Glossy
 	Positive
 	Color
 Default rendering intent	Media-relative colorimetric
 PCS illuminant XYZ	96.42 100.00  82.49 (xy 0.3457 0.3585, CCT 5000K)
 Creator	0x6172676C 'argl' Argyll CMS
 Checksum	0x24F726358AEF664B3FB96D89940CF0FB
     Checksum OK	Yes
 Description (ASCII)	madVR 2015-05-12 0.3127x 0.329y S XYZLUT
 Copyright	No copyright. Created with dispcalGUI 3.0.0.0 and
 	Argyll CMS 1.7.0
 Device model name (ASCII)	madVR
 Luminance	32.10 cd/m²
 Media white point
     Is illuminant	Yes
     Illuminant-relative XYZ	94.85 100.00 107.97 (xy 0.3132 0.3302)
     Illuminant-relative CCT	6466K
         ΔE 2000 to daylight locus	0.32
         ΔE 2000 to blackbody locus	3.49
 Media black point
     Illuminant-relative XYZ	0.0168 0.0168 0.0275 (xy 0.2750 0.2750)
     Illuminant-relative CCT	11765K
         ΔE 2000 to daylight locus	3.84
         ΔE 2000 to blackbody locus	2.02
 Colorants (PCS-relative)
     Red XYZ	80.03  40.60   3.15 (xy 0.6466 0.3280)
     Green XYZ	77.67 139.45  20.48 (xy 0.3269 0.5869)
     Blue XYZ	26.31  11.47 131.49 (xy 0.1554 0.0678)
 Video card gamma table
     Bitdepth	16
     Channels	3
     Number of entries per channel	256
     Channel 1 gamma at 50% input	1.00
     Channel 1 minimum	0.0000%
     Channel 1 maximum	100.00%
     Channel 1 unique values	256 @ 8 Bit
     Channel 1 is linear	Yes
     Channel 2 gamma at 50% input	1.00
     Channel 2 minimum	0.0000%
     Channel 2 maximum	100.00%
     Channel 2 unique values	256 @ 8 Bit
     Channel 2 is linear	Yes
     Channel 3 gamma at 50% input	1.00
     Channel 3 minimum	0.0000%
     Channel 3 maximum	100.00%
     Channel 3 unique values	256 @ 8 Bit
     Channel 3 is linear	Yes
 Device to PCS: Intent 0
     Matrix	1.0000 0.0000 0.0000
         	0.0000 1.0000 0.0000
         	0.0000 0.0000 1.0000
     Input Table
         Channels	3
         Number of entries per channel	2048
     Color Look Up Table
         Grid Steps	33
         Entries	35937
     Output Table
         Channels	3
 PCS to device: Intent 0
     Input Table
         Channels	3
         Number of entries per channel	512
     Color Look Up Table
         Grid Steps	9
         Entries	729
     Output Table
         Channels	3
 Red matrix column
     Illuminant-relative XYZ	17.91   7.18  94.23 (xy 0.1501 0.0602)
     PCS-relative XYZ	14.31   6.06  71.41 (xy 0.1559 0.0660)
 Green matrix column
     Illuminant-relative XYZ	41.23  21.26   1.91 (xy 0.6401 0.3301)
     PCS-relative XYZ	43.61  22.25   1.39 (xy 0.6485 0.3309)
 Blue matrix column
     Illuminant-relative XYZ	35.72  71.56  11.85 (xy 0.2999 0.6007)
     PCS-relative XYZ	38.51  71.69   9.71 (xy 0.3212 0.5978)
 Red tone response curve
     Number of entries	256
     Transfer function	sRGB
     Minimum Y	0.0000
     Maximum Y	100.00
 Green tone response curve
     Minimum Y	0.0000
     Maximum Y	100.00
 Blue tone response curve
     Minimum Y	0.0000
     Maximum Y	100.00
 Characterization target	[673023 Bytes]
 Characterization device values	[673023 Bytes]
 Characterization measurement values	[673023 Bytes]
 Absolute to media relative transform	Bradford
     Matrix	0.8951 0.2664 -0.1614
         	-0.7502 1.7135 0.0367
         	0.0389 -0.0685 1.0296
 Chromaticity (illuminant-relative)
     Channel 1 (R) xy	0.6369 0.3268
     Channel 2 (G) xy	0.3054 0.5876
     Channel 3 (B) xy	0.1499 0.0617
 Metadata
     CMF_binary	dispcalGUI
     CMF_version	3.0.0.0
     CMF_product	dispcalGUI
     License	Public Domain
     Quality	high
     OPENICC_automatic_generated	0
     DATA_source	calib
     MEASUREMENT_device	i1 displaypro, colormunki display
     prefix	CMF_
 	DATA_
 	MEASUREMENT_
 	OPENICC_
 	ACCURACY_
 	GAMUT_
     ACCURACY_dE76_avg	11.011392
     ACCURACY_dE76_max	22.269976
     ACCURACY_dE76_rms	11.702433
     GAMUT_volume	1.66425358454
     GAMUT_coverage(srgb)	0.9967
     GAMUT_coverage(adobe-rgb)	0.8073
I don't understand what is so wrong... I'm desesperate, this should be quite easy
petoulachi is offline
Old 05-13-2015, 02:04 AM
3ll3d00d's Avatar
Quoted: 1597 Post(s)
Liked: 578
Is it possible to make dispcalgui/madtpg prevent windows from going to sleep?
I have my htpc set to sleep over some time of inactivity and this always trips me up whenever I run dispcal (so I come down in the morning to the sight of a sleeping computer)
3ll3d00d is offline
Old 05-13-2015, 02:05 AM
petoulachi's Avatar
Quoted: 22 Post(s)
Have you set up MadTPG to be in fullscreen maybe ?
Old 05-13-2015, 02:38 AM
fhoech's Avatar
Quoted: 414 Post(s)
Liked: 275
It seems your plasma is behaving weirdly near white. Have you looked at actual video material through the 3D LUT?
DisplayCAL - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 3.2.4 released 2017-02-19
Previous development snapshot (OUTDATED): 3.1.3.2 Beta (Windows/0install) released 2016-04-23 | Standalone | Changelog
DisplayCAL on Facebook
fhoech is offline
Old 05-13-2015, 02:39 AM
petoulachi's Avatar
Quoted: 22 Post(s)
What do you mean ? I'm sorry my english kind of sucks
fhoech's Avatar
Quoted: 414 Post(s)
Liked: 275
Sleep mode will be prevented during measurements.
fhoech is offline
Old 05-13-2015, 02:40 AM
fhoech's Avatar
Quoted: 414 Post(s)
Liked: 275
I mean have you used the 3D LUT to watch videos.
fhoech is offline
Old 05-13-2015, 02:42 AM
3ll3d00d's Avatar
Liked: 578
it doesn't on my system. It was actively measuring for sure as when i wake it up then the measurement window is sitting there (and if I turn off sleep then it completes the measurement ok). Is there some setting I might be missing that influences this?
3ll3d00d is offline
Old 05-13-2015, 02:43 AM
petoulachi's Avatar
Quoted: 22 Post(s)
Not yet, as the calibration process as taken 12h (!), I've just used remote desktop at work to see the result.
Also it's the average dE, 11, that worried me ?! I don't know if it's the correction, or the test pattern (I've used the test pattern given by N3W813 in his last post), but 11 is way to much ?!
Old 05-13-2015, 03:31 AM
Quoted: 1474 Post(s)
Liked: 608
What are you using for a colorimeter?
Is there some reason that you don't turn off the going to sleep things in power management?
Display model name and number?
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is offline
Old 05-13-2015, 04:06 AM
fhoech's Avatar
Quoted: 414 Post(s)
Liked: 275
When it goes to sleep in between measurements that might be a problem. What's the sleep delay set at in Windows?
fhoech is offline
Old 05-13-2015, 04:17 AM
fhoech's Avatar
Quoted: 414 Post(s)
Liked: 275
Neither. The problem is with your TV, and possibly influenced by the pattern size/background set in madTPG. Near white the luminance seems to increase at a reduced rate, so I assume this is ABL kicking in.
fhoech is offline
Old 05-13-2015, 04:27 AM
petoulachi's Avatar
Quoted: 22 Post(s)
I have a i1 display Pro, and my screen is a Panasonic P55ST60. I do not set sleep things in power management because I want to be able to have remote access whenever I want, and also my HTPC is a NUC and it does not consume a lot.
I'm a bit surprised, plasma are known for very good quality image ? What is ABL ?
Old 05-13-2015, 04:37 AM
3ll3d00d's Avatar
Liked: 578
it's set at 1hr
3ll3d00d is offline
Old 05-13-2015, 04:59 AM
fhoech's Avatar
Quoted: 414 Post(s)
Liked: 275
What is ABL ?
Automatic brightness limiter. What's your pattern size and background level set at in madTPG?
fhoech is offline
Old 05-13-2015, 05:07 AM
petoulachi's Avatar
Quoted: 22 Post(s)
Default values (so 100% pattern size and 0% background). I guess I have to set the minimal pattern size possible, but what about background ?
Old 05-13-2015, 05:20 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Must be area=pattern size - 8%, background - 25%, APL constant
petoulachi likes this.
anta1974 is offline
Old 05-13-2015, 06:56 AM
petoulachi's Avatar
Quoted: 22 Post(s)
Ok, I'll try that !
Also, I was googling to find more information, and found this : http://www.hometheatershack.com/foru...on-3d-lut.html
where we can read
Select disable calibration under the calibration tab. Do not check disable gamma ramps. Under color & gamma, do not enable gamma processing.
Is it true ? Because I have Gamma ramps AND gamma processing enable.
Old 05-13-2015, 07:05 AM
fhoech's Avatar
Quoted: 414 Post(s)
Liked: 275
where we can read
I think the forum post is correct. "Disable GPU gamma ramps" and "Enable gamma processing" (as most of the other settings) should be left at defaults, i.e. for the aforementioned two NOT enabled (no checkmark).
fhoech is offline
Old 05-13-2015, 07:24 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Why in first post recomendatoin disable GPU gamma ramps enabled (checkmark yes)?
anta1974 is offline
Old 05-13-2015, 07:41 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 251
it disables the microsoft CMS. you can use the ICC from the 3D LUT to calibrated the desktop too (in way lower quality). with out disable GPU gamma ramps you would get wrong colors.
mightyhuhn is offline
Old 05-13-2015, 07:49 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
Correct calibration TV - default uncheck?
anta1974 is offline
Old 05-13-2015, 07:56 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 251
check "this display is already calibrated"
the GPU gamma ramp setting doesn't do anything in this case.
Old 05-13-2015, 08:04 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
I have notebook+TV.
I use 3DLUT.
I must choose calibrate with external 3DLUT.
GPU gamma ramping must disable or enable?
anta1974 is offline
Old 05-13-2015, 08:25 AM
anta1974's Avatar
Quoted: 61 Post(s)
Liked: 29
http://www.spectracal.com/Documents/...QuickStart.pdf
Recomendation uncheck disable gpu gamma ramps.
anta1974 is offline
Old 05-13-2015, 08:46 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 251
there is no clear answer to that.
it depands on how the 3D LUT is created.
was a ICC file loaded at that time?
is a ICC file load after 3D LUt calibration?
all these things can change the answer from no to yes.
in my eye a 3D LUT should be created without any loaded ICC file and the answer to check disable GPU gamma ramps in this case would be yes check disable GPU gamma ramps
anta1974 and petoulachi like this.
Old 05-13-2015, 09:52 AM
fhoech's Avatar
Quoted: 414 Post(s)
Liked: 275
In practice you don't have to deal with any of this manually though because the tools will do the right thing when used. So my recommendation would be to only manually change defaults if something doesn't work, and only after careful consideration if the error may not lie elsewhere (software bug etc.).
fhoech is offline
Old 05-13-2015, 10:14 PM
j5627429's Avatar
My current method to create the 3DLUT is to use MPC-HC + MadVR to display AVS-AVCHD test patterns with all of my standard viewing settings except for turning madvr's 3dlut and gamma settings off, then use a separate laptop & probe running Calman to measure and record results, then input the results into yCMS primaries and grayscale measurements fields in madVR so that yCMS can create the 3DLUT for my projector.
Is the method described in the OP superior?
j5627429 is offline
