MadVR - ArgyllCMS - Page 122 - AVS | Home Theater Discussions And Reviews
 260Likes
post #3631 of 3647 Old Yesterday, 07:31 PM
LucaT's Avatar
Quoted: 14 Post(s)
Originally Posted by fhoech View Post
It's probably more straightforward to just use the "3D LUT for madVR" preset. Adjust the patch amount on the "Profiling" tab with the slider to around 2000 patches to get a similar patch count as used in the first post if you want.
Thanks a lot for the rapid answer.
Should I use the 32bit version of everything? (Argyll, MadVr, MPC-HC)
LucaT is offline
post #3632 of 3647 Old Yesterday, 07:33 PM
fhoech's Avatar
Quoted: 248 Post(s)
Liked: 164
I'm about to go to bed
Doesn't matter anymore I think.
DCG (dispcalGUI) - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 3.0
Current development snapshot: 3.0.0.4 Beta | Changelog
fhoech is online now
post #3633 of 3647 Old Yesterday, 07:36 PM
LucaT's Avatar
Quoted: 14 Post(s)
Me too!
Last question please
Do I find the preset into "setting" on the top of DispcalGUI?
Thanks, good night
LucaT is offline
post #3634 of 3647 Old Yesterday, 07:38 PM
fhoech's Avatar
Quoted: 248 Post(s)
Liked: 164
Yes.
post #3635 of 3647 Old Yesterday, 07:40 PM
LucaT's Avatar
Quoted: 14 Post(s)
Yes.
I will try .... But tomorrow
Have a good night and thanks again
LucaT is offline
post #3636 of 3647 Old Today, 12:25 AM
madshi's Avatar
Quoted: 140 Post(s)
Liked: 210
Originally Posted by zoyd View Post
The eecolor output is 12 bit regardless of input. (If display accepts it)
Ah thanks - good to know! I was told (a looooong time ago) that the output bitdepth was always the same as the input bitdepth. It seems they've updated their firmware. Or else, maybe I was told incorrectly. Either way, doesn't matter...
FWIW, my JVC X3 isn't half as smooth in dithered 10bit mode compared to dithered 8bit mode. But well, this will differ from display to display.
madshi is offline
post #3637 of 3647 Old Today, 01:15 AM
ConnecTEDDD's Avatar
Quoted: 252 Post(s)
Liked: 678
Hi Madshi, It was my fault, eeColor will output 12bit if you feed it with 8bit signal.
There not available any firmware update for eeColor from it's initial release since now.
I found the error at my post below:
Originally Posted by ConnecTEDDD View Post
Quote: Originally Posted by madshi
Quote: Originally Posted by ConnecTEDDD
eeColor features 16bit internal signal processing and it uses different 6 memories of Correction LUT in 10bit per color (30bit in total) resolution, after that it outputs the same bits as is taking at the input.
If you send eeColor 12bit per color signal then at the output you will get 12 bit per color (36bit in total)
Interesting - thanks! For comparison, madVR uses 16bit per color (48bit in total) LUTs.
So if I feed 8bit (per color) to the eeColor, the output is also 8bit? Hopefully it is dithered down from the internal 16bit processing bitdepth?
If you send YCbCr 4:4:4 with 8bit per color, inside the eeColor is converted to RGB for internal processing and for appyling your selected memory LUT and then it's converted to YCbCr 4:4:4 with 8bit per color for the output.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, CalPC, ControlCAL
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #3638 of 3647 Old Today, 02:05 AM
madshi's Avatar
Quoted: 140 Post(s)
Liked: 210
Thanks Ted. To be honest, I didn't remember from where I had the information. But it's good to have it corrected now.
ConnecTEDDD likes this.
madshi is offline
post #3639 of 3647 Old Today, 03:18 AM
Francois76l's Avatar
Quoted: 56 Post(s)
Dear all,
I'm going to test the last dispcalgui V3.0.0 + Final ArgyllCMS V1.7 on my JVC x35 (ie RS46).
Generally I profile my JVC with approximately 2050 patches with auto testchart.
I usually run the 1D-LUT calibration before profiling.
What do you suggest? Increase the number of patches and disable the 1D-LUT calibration (response curve set to "As measured") or keep my previous settings?
thanks for your advices!
HiFi:Nad C320BEE+Marantz CD-63 MkII-Ki Signature+Boston VR2+DIY cabling
HC:Onkyo TX-SR875+Boston VR2+CR8+VRC+Subwoofer MJ Acoustic Ref1 MKII
DISPLAYS:Panasonic P50ST50E/JVC DLA-X35 + HTPC (LAV+ffdshow+Avisynth+MPC-BE+MadVr)
SCREEN: Lumene Movie Palace Premium 240C + Dedicated room
Francois76l is online now
post #3640 of 3647 Old Today, 03:38 AM
zoyd's Avatar
Quoted: 787 Post(s)
Liked: 697
Originally Posted by |Tch0rT| View Post
Has anyone compared the eeColor 3DLUT box to madVR 3DLUT? I've thought about getting an eeColor 3DLUT box just so I can run all my other sources (video game consoles and gaming rig) through it. I don't think I can run that stuff through my HTPC...
I've done a couple of comparisons and they are identical as far as I can tell visually. The two measurement runs I did comparing the residual color errors gave a very slight edge to madVR on my display.
I see that too from the Lumagen, 8bit dithering smooths out some quantization errors while 10bit does not.
|Tch0rT| and all clear like this.
zoyd is online now
post #3641 of 3647 Old Today, 04:06 AM
Quoted: 56 Post(s)
Zoyd I would really appreciate your advice concerning the 1D-Lut calibration
I've just tuned my 6500K and I'm ready to start the process
post #3642 of 3647 Old Today, 04:32 AM
zoyd's Avatar
Quoted: 787 Post(s)
Liked: 697
zoyd is online now
post #3643 of 3647 Old Today, 04:47 AM
Quoted: 56 Post(s)
Embed calibration curve in profile?
post #3644 of 3647 Old Today, 04:53 AM
fhoech's Avatar
Quoted: 248 Post(s)
Liked: 164
Use linear + embed, that way madVR will be able to set correct videoLUT state during playback.
post #3645 of 3647 Old Today, 04:58 AM
Quoted: 56 Post(s)
Thank you so much for all your precious advises! Really appreciate! I did as you said and I increased the number of patches (more than 4000)
See you in 4 hours ;-)
post #3646 of 3647 Old Today, 09:09 AM
Quoted: 56 Post(s)
Calibration process finish.
The result without 1D-LUT calibration is not as good as with 1D-LUT calibration.
average dE: 0.42 max : 3.2!
Befor my max was 2.3
The 6500K is less accurate between 0 - 30IRE (6924K @ 10ire, 6700K @ 30 ire and 6500K below 30ire).
The blinking 16-18 bars are still invisible (totally blacks) but I know that the i1d3 is responsible for that (not enought accurate to read the blacks of the JVC).
For the moment I keep the result since the last 3D-LUT is 100hours old now
Thanks again for your help!
Name:	Tone response curves X35_madVR 2015-05-23  (absolute) S XYZLUT.png
post #3647 of 3647 Old Today, 10:34 AM
sillysally's Avatar
Quoted: 301 Post(s)
Liked: 377
zoyd, I am sure you are correct in what you are saying, I am just tiring to point out there may be exceptions.
By definition. Dithering is the attempt by a computer program to approximate a color from a mixture of other colors when the required color is not available. For example, dithering occurs when a color is specified for a Web page that a browser on a particular operating system can't support.
What I am seeing (in the early stages of profiling and experimentation) on a new LG 2015 4K 65EG9600 OLED, seems to help the overall smoothness of the up converted 1080p or lower image.
ss
sillysally is online now
Reply Display Calibration
