MadVR - ArgyllCMS - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 492Likes
post #361 of 4618 Old 06-20-2013, 12:20 PM
MSL_DK's Avatar
Quoted: 20 Post(s)
Originally Posted by madshi View Post
If you use "dispread -k" then you also need to use "collink -a". At least that is my understanding?
Yes ... or dispwin test.cal but as explained here, I experience still this problem if I add dispwin test.cal
Panasonic TX-55CX700E - Dynaudio Focus 200 XD
MSL_DK is offline
post #362 of 4618 Old 06-20-2013, 12:54 PM
madshi's Avatar
Quoted: 575 Post(s)
Liked: 541
Have you tried "collink -a" instead?
madshi is offline
post #363 of 4618 Old 06-20-2013, 06:58 PM
gwgill's Avatar
Quoted: 256 Post(s)
Liked: 191
Originally Posted by N3W813 View Post
Once a ccmx file is created, add '-X [filename].ccmx' to dispread command.
You can also install the .ccmx with oeminst and it will appear in the -y list
gwgill is offline
post #364 of 4618 Old 06-20-2013, 08:28 PM - Thread Starter
N3W813's Avatar
Quoted: 45 Post(s)
Liked: 79
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is offline
post #365 of 4618 Old 06-21-2013, 02:38 AM
MSL_DK's Avatar
Quoted: 20 Post(s)
Yes ... with a poor outcome (black level is raised significantly). I go against all advice and set my GFX to 16-235 and see the result of this, later today.
Whatever I have tried with 0-255 I experience grainy picture and black level is raised (too bright)
EDIT
Same result ... black level is raised. I am completely lost ... I can not figure out what's going wrong!
EDIT
I can post Calman 4 before / after results, system settings, hardware and workflow if it can help?
Whatever I do, I find that black level is raised considerably.
MSL_DK is offline
post #366 of 4618 Old 06-21-2013, 09:30 AM
VerGreeneyes's Avatar
Is the raised black level visible in the calibration curves, or does it get introduced later? If you can see it in the curves, you might just need to fiddle with your dispcal settings. My monitor was pretty fiddly, for example, and I had to use the following settings to get a good result:
Code:
dispcal -m -v2 -qu -w 0.312713,0.329016 -g2.2 -a64 -k0 -P 0.5,0.5,2.0 -H -Ibw "[calibration file name]"
Without the "-a64" part, it would raise the output black level to something like 40/256 (although this was on an older beta of the ArgyllCMS software, so things might have changed).
VerGreeneyes is offline
post #367 of 4618 Old 06-21-2013, 10:02 AM
MSL_DK's Avatar
Quoted: 20 Post(s)
Code:
No, it's weird. I have, from what I can see an almost perfect curve ... It is seen when I example shows black clip pattern ... and it is also very visible in a movie as Jack Reacher and The Dark Knight as I like to use as reference only. I am unfortunately preoccupied with my child this weekend ... Um and Le Man :-) so I'll probably not have time to show you the results or screenshots until after the weekend.
MSL_DK is offline
post #368 of 4618 Old 06-21-2013, 11:35 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
If this is your workflow:
  • dispwin -c
  • dispcal.exe -d 1 -v -m -q h -X "WLEDFamily_07Feb11.ccss" -w 0.312713,0.329016 -G 2.4 -f 0 -o madVR_C.icm SAM
  • targen.exe -v -d 3 -G -s 20 -g 100 -f 2000 -c madVR_C.icm SAM
  • dispread.exe -v -d 1 -X "WLEDFamily_07Feb11.ccss" -k SAM.cal SAM
  • colprof.exe -v -a X -q h -b h SAM
  • collink.exe -v -3m -et -Et -Ib -G -ir Rec709.icm SAM.icm SAM_HD_ila.icm
  • dispwin sam.cal
I believe you are supposed to use -E for dispcal and dispread if your video card is set to full range. I know the walkthrough says otherwise but I think that is wrong. I know when I do my cal I don't include the -E switch but my video card only outputs limited range and it works properly. With your current measurements you could re-run collink with -en -Et and see if that works.
zoyd is offline
post #369 of 4618 Old 06-21-2013, 01:06 PM
MSL_DK's Avatar
Quoted: 20 Post(s)
Thanks zoyd! It seems to solve my problem! But damn, it's confusing :-) I will use this workflow when I get time and tell the result of it.
  • dispwin.exe -v -d1 -c
  • dispcal.exe -v -d1 -m -qh -E -yn -X i1d3.ccss -t 6504 "-P0.49226006192,0.488372093023,3.3485915493" "-w0.312713,0.329016" -g 2.2 -o TV.icm "SA5005.p2.2"
  • targen.exe -v -d3 -G -f2500 -g128 -c TV.icm "madVR"
  • dispread.exe -v -k SA5005.p2.2.cal -E -yn -X i1d3.ccss "-P0.49226006192,0.488372093023,3.3485915493" "madVR"
  • colprof.exe -v -qh -bl -aX "madVR"
  • collink.exe -v -3m -qh -et -Et -Ib -G -ila -a SA5005.p2.2.cal Rec709.icm madVR.icm EGEN_3DLUT.icm
MSL_DK is offline
post #370 of 4618 Old 06-21-2013, 01:28 PM
MSL_DK's Avatar
Quoted: 20 Post(s)
BTW ... think my problems started here: http://www.avsforum.com/t/1471169/madvr-argyllcms/180#post_23371018
MSL_DK is offline
post #371 of 4618 Old 06-21-2013, 02:02 PM
zoyd's Avatar
Liked: 1064
The key is that if nothing in the source to display chain forces 16-235 video levels you have to do it with dispread and dispcal -E switch. In my case my video card does this so I don't use that switch. In other cases you may have 0-255 out from your video card but your display does video level compression, so you also wouldn't use the -E switch in that case.
zoyd is offline
post #372 of 4618 Old 06-21-2013, 02:44 PM - Thread Starter
N3W813's Avatar
Quoted: 45 Post(s)
Liked: 79
My video card is outputting 0-255 and my TV is displaying 16-235. I use the -E switch on dispread and the levels I'm getting in the 3dlut (-et -Et) has no issues. confused.gif
N3W813 is offline
post #373 of 4618 Old 06-21-2013, 02:51 PM
zoyd's Avatar
Liked: 1064
What is madVR output set to?
zoyd is offline
post #374 of 4618 Old 06-21-2013, 02:53 PM - Thread Starter
N3W813's Avatar
Quoted: 45 Post(s)
Liked: 79
16-235. BTB and WTW preserved.
N3W813 is offline
post #375 of 4618 Old 06-21-2013, 03:03 PM
zoyd's Avatar
Liked: 1064
ok, that's how it should work - your display is not modifying the input if you see WTW so you are fine. Some displays take 0-255 and compress it to 16-235 thereby clipping BTB/WTW so you wouldn't want -K in that case.
quoted from scenarios.html
"If the video path needs Video Level RGB encoding but does not provide a means to do this, then you will want to include the -E flag in the colprof and dispread command lines above." [colprof should be dispcal]
In other words your video card and/or display are not compressing levels so you need the -E flag to be compatible with madVR.
zoyd is offline
post #376 of 4618 Old 06-22-2013, 12:32 AM
MSL_DK's Avatar
Quoted: 20 Post(s)
I have looked closely at it. My video card is set to 0-255 so is my Display and madVR. If I use dispcal -E and dispread -E and shows a pluge I am forced to raise the brightness with 3 steps on my samsung display.
If I use dispcal and dispread without -E, I had to lower the brightness with 5 steps.
Is it my display not showing real 0-255, or?
MSL_DK is offline
post #377 of 4618 Old 06-22-2013, 12:40 AM
madshi's Avatar
Quoted: 575 Post(s)
Liked: 541
The first thing to do is to setup black & white levels correctly. Whether your display is showing real 0-255 is something you should analyze *before* running the whole Argyll shebang, not afterwards... tongue.gif
If everything is set to 0-255 and working correctly, you should not use the -E parameter. At least's that not what the -E switch was intended for.
madshi is offline
post #378 of 4618 Old 06-22-2013, 03:49 AM
zoyd's Avatar
Liked: 1064
Your display should be showing BTB/WTW in both cases, that has nothing to do with the -E switch. The -E switch is used to create the correct level spacing in the 3dLUT for madVR usage. If your source->display is 0-255 use -E.
@madshi
I don't know why you say that, Graeme explicitly states for madVR flow:
madVR needs the video level encoding generated by dispread -K in 0-255 systems otherwise the level spacing will be incorrect. This is the point I mentioned earlier, madVR expects the 3dLUT to be in 220 step resolution not 255 step. The -e and -E switches in collink then determine how to map the 220 step resolution to the full lut resolution.
What other reason are you thinking -E is for?
zoyd is offline
post #379 of 4618 Old 06-22-2013, 07:33 PM
fallengt's Avatar
My display is output 16-235, and my card can only output 16-235 too (Intel APU), which switch should I use?
MadVR's setting is at 0-255, don't see any obvious banding issue but probally I don't look for it hard enough
fallengt is offline
post #380 of 4618 Old 06-22-2013, 10:21 PM
madshi's Avatar
Quoted: 575 Post(s)
Liked: 541
@madshi
There are 3 possible HTPC level configurations, when using madVR:
(1) Display wants 0-255. GPU and madVR are consequently also both set to 0-255.
This is the most recommended setup because it doesn't (shouldn't) have any banding problems, and still has all video, desktop and games with correct black/white levels. In this case test patterns need to have black at 0,0,0, obviously.
(2) Display wants 16-235. GPU is set to 16-235. madVR has to be set to 0-255.
This is not recommended, because the GPU stretches the madVR output, probably in 8bit without dithering, so banding could be introduced. However, this is not a big problem for ArgyllCMS. Argyll still needs to create test patterns with black at 0,0,0. The GPU will then stretch the test patterns from 0-255 to 16-235, so the display will get 16,16,16, although Argyll rendered 0,0,0. So the levels are correct.
(3) Display wants 16-235. GPU is set to 0-255. madVR is set to 16-235.
This is the recommended setup for best image quality if your display can't do 0-255. This setup results in banding-free madVR image quality. However, levels for desktop and games will be incorrect, because desktop and games will render black at 0,0,0, while the display expects black at 16,16,16. This is a problem for ArgyllCMS, because Argyll will create test patterns with black at 0,0,0, and the display will also receive these at 0,0,0. So basically Argyll test patterns will have wrong levels, which will screw up the whole calibration.
It is my understanding that Graeme implemented the -E switch specifically for (3), because without the -E switch Argyll test patterns would send wrong levels to the display. Basically the -E switch tells Argyll to render test patterns with black at 16,16,16 and white at 235,235,235, which Argyll never had to do before. When using VMR/EVR, you usually switch your GPU to 0-255 or 16-235. In both cases Argyll can render test patterns with black at 0,0,0, and they will still be sent to the display with the correct levels. However, due to my recommendation to use (3) if your display doesn't support 0-255, Argyll suddenly needs to render test patterns differently. Hence Graeme implemented the -E switch.
So my understanding is that -E should be used only for (3) and in no other situation. If you use the -E switch for (1), Argyll will create test patterns with black at 16,16,16 which would be incorrect!
@Graeme, please correct me if I'm wrong.
madshi is offline
post #381 of 4618 Old 06-23-2013, 10:32 AM
slosvt's Avatar
Quoted: 59 Post(s)
Liked: 29
MadVR question.
I have my configuration as follows:
Intel G1610 (DVI) -> Denon AVR (HDMI) -> LG PK550 Plasma (HDMI).
Should I tell MadVR the same? If so, which display device do I apply the profile to?
slosvt is offline
post #382 of 4618 Old 06-23-2013, 10:46 AM
cfelicio's Avatar
Originally Posted by slosvt View Post
MadVR question.
Umm, in my case I can only apply the profile to the TV. Is your Denon receiver is set as a receiver in Madvr?
cfelicio is offline
post #383 of 4618 Old 06-23-2013, 12:03 PM
slosvt's Avatar
Quoted: 59 Post(s)
Liked: 29
Yes, I figured it out. SIlly question actually...
I own Chromapure and have AVS 709 HD on a Blu Ray Disc (in Blu Ray format). What is the best way for me to display the patterns for Chromapure thru MPC-HC, so I can get a reading on the actual display calibration?
I currently do not own a program to play Blu Ray discs on the HTPC.
slosvt is offline
post #384 of 4618 Old 06-23-2013, 12:15 PM
cfelicio's Avatar
You can download the avs 709hd in mp4 format, and run the patterns manually, as I think chromapure still does not support the new pattern generator from madvr.
cfelicio is offline
post #385 of 4618 Old 06-23-2013, 12:57 PM
gtgray's Avatar
Quoted: 225 Post(s)
Liked: 146
setting my NVidia GPU to 0-255 produces 16-235 (video levels). It produces video levels regardless. Any suggestions for that. I have a Radiance in between so I know what the output is of the GPU. It is the same regardless of the setting...... EVGA GT 650ti Boost SC with latest WHQL. What is the trick to get NVidia to actually output PC levels?
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
post #386 of 4618 Old 06-23-2013, 01:03 PM
madshi's Avatar
Quoted: 575 Post(s)
Liked: 541
madVR comes with a tweaker utility for that. See "madNvLevelsTweaker.exe".
madshi is offline
post #387 of 4618 Old 06-23-2013, 01:04 PM
10k
10k's Avatar
Quoted: 1885 Post(s)
Liked: 2124
The switch in the control panel actually does nothing if you are connected via HDMI. Fortunately there is a hack to get around it called the NVIDIA HDMI switcher tool. There is a link to it in the link in my signature below.
:edit: Madshi's tool works as well
10k is offline
post #388 of 4618 Old 06-23-2013, 01:14 PM
slosvt's Avatar
Quoted: 59 Post(s)
Liked: 29
Thank you!
Unfortunately, my setup did not improve using the steps in the first post (Gray Scale patters show more color) and color did not improve much. I might give it another shot later.
slosvt is offline
post #389 of 4618 Old 06-24-2013, 12:12 AM
gwgill's Avatar
Quoted: 256 Post(s)
Liked: 191
It's hard to know what the context is, but if your display is full range (o..255), then you don't use the -E switch in dispcal or dispread. If you think my tutorial says otherwise, please point out where, and I'll fix it...
An alternative to loading the calibration curves into the video card which may give you higher quality is to leave the video card linear (dispwin -c) and include the calibration curves in the 3dLUT using collink -a.
gwgill is offline
post #390 of 4618 Old 06-24-2013, 12:22 AM
gwgill's Avatar
Quoted: 256 Post(s)
Liked: 191
Looks right to me.
gwgill is offline
Reply Display Calibration
