MadVR - ArgyllCMS - Page 133 - AVS Forum | Home Theater Discussions And Reviews
 488Likes
post #3961 of 4587 Old 10-10-2015, 11:49 AM
Quoted: 132 Post(s)
Liked: 4
Originally Posted by fhoech View Post
FRC (which is a form of temporal dithering) in the display itself is independent from the source, so the graphics card or driver settings don't play into it at all (although the card may do additional dithering of its own).
If the tech specs of the display say 8bit + FRC, then that's likely what is happening.
Thanks! Does FRC get in the way of calibration? FRC seems to prevent banding, but it creates that crawling effect and I guess that means it is impossible to fully measure any specific grayscale level..?
Masharak is offline
post #3962 of 4587 Old 10-11-2015, 11:36 PM
gwgill's Avatar
Quoted: 250 Post(s)
Liked: 186
Originally Posted by sillysally View Post
My K10-A pointer seems to get turn on when running calibration and or profile, using triplet 8% windows, APL Linear 25% background. I have to manually turn off twice the pointer using the on/off switch in the K10.
I haven't managed to reproduce such behaviour, as the ArgyllCMS tools make sure that they turn the pointer off before doing any sort of measurement.
I have noticed that the the K10 "guide light off" command sometimes returns bogus error codes and interferes with a subsequent measurement command though, so you could try this beta test snapshot of the relevant MSWin 64 bit tools, to see if they improve the situation or not.
gwgill is offline
post #3963 of 4587 Old 10-12-2015, 09:32 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
In theory it shouldn't, as it allows for finer tuned grayscale steps, but maybe there's something else going, e.g. interference with madTPG's dithering. It's hard to know for sure.
DisplayCAL - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 3.3 released 2017-05-30
Previous development snapshot (OUTDATED): 3.2.9 Beta (Windows/0install) released 2017-05-23 | Standalone | Changelog
DisplayCAL on Facebook
fhoech is offline
post #3964 of 4587 Old 10-12-2015, 09:55 AM
sillysally's Avatar
Quoted: 874 Post(s)
Liked: 874
Thank You. I will try it.
The last two calibration/profile's I ran there was NP.
However I didn't turn on the K10's guide light.
ss
"Don't worry be happy"
sillysally is offline
post #3965 of 4587 Old 10-14-2015, 01:58 AM
sillysally's Avatar
Quoted: 874 Post(s)
Liked: 874
No luck with your tools.
See screen shot for results.
This link is to my last successful 3DLUT, using dispcalGUI 3.0.4.3 and ArgyllCMS 1.8.2
LG 55EF9500 and 65EF9500 OLED Owners Thread
UpdateSee screen shots for when pointer turns on.
Once I click OK pointer turns off.
Pointer turn on and off when the next screen shot came on.
I use dispcalGUI 3.0.4.3 and ArgyllCMS 1.8.2 non beta.
ID:	994825   Click image for larger version
Name:	Point was turned on.jpg
ID:	994841   Click image for larger version
Name:	Next on off pointer screen.jpg
post #3966 of 4587 Old 10-14-2015, 08:34 PM
Quoted: 1547 Post(s)
Liked: 639
What does it mean when madVR reports; -creating Direct3D device failed (8876086c)
It was working earlier this evening. I must have broken it.
JimP is online now
post #3967 of 4587 Old 10-15-2015, 06:52 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
You can change the whitepoint on the "Calibration" tab. Did you not use one of the 3D LUT presets?
fhoech is offline
post #3968 of 4587 Old 10-16-2015, 12:41 AM
Sunset1982's Avatar
Quoted: 48 Post(s)
haven't been here for a while... are there any news for LG OLED users with slow meters (i1 Display Pro) to avoid the LG dimming? Maybe an option for changing dark and light patches ?
Sunset1982 is offline
post #3969 of 4587 Old 10-16-2015, 01:46 AM
mightyhuhn's Avatar
Quoted: 748 Post(s)
Liked: 256
the dimming doesn't happen on a small patch so use a really small madTPG window/patch size.
mightyhuhn is online now
post #3970 of 4587 Old 10-16-2015, 02:26 AM
Sunset1982's Avatar
Quoted: 48 Post(s)
I dont think so. I used small patches (window size 10-18) but dimming does work even with this small ones. Not possible to make a 3DLut with i1DPro atm.
post #3971 of 4587 Old 10-16-2015, 06:33 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
You could try this suggestion by @10k (use an automatically changing Windows background with dim pictures, and set madTPG to not use fullscreen)
fhoech is offline
post #3972 of 4587 Old 10-17-2015, 12:23 AM
mightyhuhn's Avatar
Quoted: 748 Post(s)
Liked: 256
with fullscreen and black background?
maybe try 5 % should be big enough for your sensor at contact mode.
the EC9300 was stable until 25%.
my source: http://www.rtings.com/tv/reviews/by-brand/lg/ec9300
post #3973 of 4587 Old 10-17-2015, 10:04 AM
Quoted: 132 Post(s)
Liked: 4
GWGill,
I am not pulling this out of my butt on HardForums there was a member who talked about you (I think meeting you) at a color/calibration-science conference. I do NOT know if that is BS though.... He stated that spectro profiling for exact accuracy is not necessary due to eye adaptation and how you, yourself, firmly agreed with that. Supposedly, eyes adjust well when calibration error is exactly the same throughout all the measurements. For example, if i1Display Pro is mis-reading Red by 10% on whichever display, then eyes will easily adjust to a calibration where all of grayscale and all of color gamut have that exact 10% deviation. Eyes will not adapt if the error is different. For example, un-calibrated display may have completely messed up grayscale with too much Blue on 0-40% IRE and too little Green on 40-60% IRE and too much Red on 60-100% IRE, as well as, randomly inaccurate color gamut. In such messed up case, eyes won't adjust to see a calibrated picture.
What is your actual opinion? If the above is true, then does it even make sense to get a spectrometer to get better accuracy? It doesn't seem like it because eyes can adjust to an error that occurs throughout the calibration..
Hardware: i1Pro & i1Display Pro. Software: CalMAN 5 Enthusiast Edition, HCFR Calibration, ArgyllCMS + dispcalGUI, madVR.
HDTV: Samsung LN40B550 40" CCFL SPVA LCD @ 1080p, 60Hz, 2700:1 CR. Gaming Monitor: Eizo Foris FG2421 24" LED MVA LCD @ 1080p, 120Hz + backlight-strobing, 4700:1 CR.
HTPC: Intel i7 3770K @ 4.8Ghz, 16GB 2200Mhz RAM, GeForce GTX 1080 @ 2000/11000Mhz, 256GB + 500GB SSD, 2TB HDD, Windows 10 Pro (x64)
Masharak is offline
post #3974 of 4587 Old 10-17-2015, 11:34 AM
baii's Avatar
Quoted: 25 Post(s)
I think that is somewhat true, essentially how our eye adapt to different viewing conditions?
I.e viewing condition for print 5000k vs 6500 for digital consumption. So it depends on if the "accuracy" include viewing condition?
This is my view as a end user, not a scientist ~
Sent from my 306SH
baii is offline
post #3975 of 4587 Old 10-18-2015, 02:41 AM
Light Illusion's Avatar
Quoted: 351 Post(s)
Liked: 661
What you are describing (I think) is a difference between Relative and Absolute calibration.
(As you say, that is not the same as having random calibration throughout the colour gamut and/or grey scale).
The human eye will indeed 'manage' consistent colour errors, effectively balancing them out relative to other colours.
A good example is when grading films (I have graded a fair few...).
As a colourist you get used to the need to keep referencing back to a 'pure white/grey scale' while grading to prevent you perception of colour from drifting during a grading session.
If you don't do that, after 30 minutes of grading you can easily be making wrong colour assumptions.
While you don't 'see' the errors at the time, walking out the grading room (for a coffee, etc) coming back into the room and looking at the exact same shot you were just grading can be a real shock!
So, we use perfect grey scale/white balance references to keep our eyes 'in calibration'.
I used a small light-box, with very accurate grey scale transparencies.
But, back to the original question - while such Relative errors can be 'assimilated' by the human eye, the issue is the Absolute colour error remains, and that means you are no longer seeing the colour as the DoP and Colourists intended, and that can alter your emotional perception of the images you are viewing.
Having a 'cooler' image generates a very different emotional response than a 'warmer' image, for example.
That makes accurate calibration rather important to me
Steve
ConnecTEDDD and Elix like this.
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #3976 of 4587 Old 10-18-2015, 07:23 AM
Quoted: 132 Post(s)
Liked: 4
Yes, that is exactly what I thought. I am just wondering whether i1Display Pro error (without spectro-profiling) can be big/high enough to create that different perception of a film.
BTW, does anybody know whether Japanese films shown or sold in the US use 6500K? I heard in Japan they use 9300K...
Masharak is offline
post #3977 of 4587 Old 10-18-2015, 04:59 PM
gwgill's Avatar
Quoted: 250 Post(s)
Liked: 186
We are known to chromatically adapt to a wide range of white points, but note there is some in nuance in this. We adapt best along the black body locus direction, and less well in other directions. Adaptation becomes poorer at extremes, and is influence by more than just the image we are looking at - the white point of the surround and ambient will affect our perception. So in practice, and in isolation (i.e. not comparing multiple side by side displays), an error in the absolute white point of a display is likely to be a lot less visually significant that other aspects of a calibration, particularly if the error is in the blue/yellow direction rather than green/purple direction.
That depends how grossly inaccurate the colorimeter is, and in what direction the error lies. One of the quandries is that without some higher accuracy reference, you don't know what the error is.
gwgill is offline
post #3978 of 4587 Old 10-19-2015, 02:28 AM
gwgill's Avatar
Quoted: 250 Post(s)
Liked: 186
I'm unable to reproduce the sequence you show using the computers screen - the target LEDs flash and the measurements commence immediately without the dialog "Place the instrument on the test window and click OK to continue" appearing - which is a little odd.
If I select a remote display (ChromeCast in my testing), then the above dialog
does appear and the LED target is turned on, but it turns off immediately I click OK.
This is using ArgyllCMS V1.8.2 and dispcalGUI 3.0.4.3, and the K-10A has firmware v01.09fh.
I'm not sure what difference between this and your setup is triggering the problem.
If you run the "spotread" tool from the command line with your K-10A plugged in, does hitting 't' reliably toggle the LED target lights on and off ?
gwgill is offline
post #3979 of 4587 Old 10-19-2015, 07:25 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
[...] the measurements commence immediately without the dialog "Place the instrument on the test window and click OK to continue" appearing - which is a little odd.
The "Place instrument ..." message box should only appear when madTPG is not set to use fullscreen mode (in fullscreen mode, there should be a countdown instead in the madTPG window), although at the start of the interactive display adjustment step, dispcalGUI will instruct madTPG to leave fullscreen (because otherwise the interactive adjustment window may be potentially obstructed), so if interactive display adjustment is not disabled the message should always appear. Fullscreen mode is then restored for the characterization measurements. This is somewhat clunky, but I wanted to avoid people not being aware of a window waiting for user interaction behind a fullscreened madTPG.
fhoech is offline
post #3980 of 4587 Old 10-19-2015, 07:36 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
I'm not sure anymore the problem you're seeing is related to the pointer LED. From what you describe, the pointer behaves as I would expect from what Graeme said, i.e:
- Pointer turns on when dispcal.exe is launched at the start of the interactive display adjustment step. After you press OK in the "Place instrument ..." message, the pointer turns off (this is equivalent to pressing a key when using dispcal.exe on the command line).
- After interactive adjustment, dispcal.exe exits and dispread.exe starts for the characterization measurements. Pointer turns on when dispread.exe starts, then turns off when dispcalGUI recognizes that dispread is waiting for keyboard input and sends a keypress to start measurements (no user interaction at this point).
Maybe something else is going on that causes the bad result you're getting sometimes?
fhoech is offline
post #3981 of 4587 Old 10-19-2015, 08:20 AM
sillysally's Avatar
Quoted: 874 Post(s)
Liked: 874
I am not saying that ArgyllCMS, DispcalGUI or madVR is causing any issues.
Mater of fact I got Graeme beta tools to work using DispcalGUI 3.0.4.3, results where as expected.
I have run three successful profiles in a row.
As long as I don't use interactive display adjustment and stop, then click on the calibration tab.
I can use interactive display adjustment step, once done hit stop and cancel. Then close dispcalGUI, unplug K10 and plug back in, start dispcalGUI hit com ports button then just go directly to the calibration/profile button.
On a side note, using madTPG APL Linear, using on screen mode for meter. I can run your largest slider testchart 11,000+ points and calibration, Graeme K10 meter delay without a misread as far as I can tell. Works for both the LG EG9600 and LG EF9500 65" OLED's.
Using Graeme beta tools he kindly posted for me and the K10-A. There seems to be a raising of the Luminace reads for 5% thru 15%, from using the 1.8.2 non beta tools.
ss
post #3982 of 4587 Old 10-19-2015, 08:38 AM
sillysally's Avatar
Quoted: 874 Post(s)
Liked: 874
I need to check what firmware my K10-A has.
No I haven't but will try "spotread" command line.
As I said I can see the LED target light come on and off using dispcalGUI 3.0.4.3
The one thing I am unclear about, is why have the K10-A's LED target light come on at all.?
Wouldn't it be for the best if argyllCMS never turned on/off the target light, and fhoech just added a manual toggle switch for the K10-A's LED target light.?
Thanks Graeme and fhoech.
post #3983 of 4587 Old 10-19-2015, 09:53 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
I think it's reasonable that the pointer LED turns on when starting one of the Argyll CMS tools, as this is the time when a user will typically position the instrument for display readings.
I'm still not really sure I understand the problem, i.e. the pointer LED turning on and off before readings start should not influence the readings at all. It would only pose a problem if the pointer stayed ON during the readings for some reason. I would suspect this could happen due to a race condition, for example (when using Argyll CMS on the command line, user reaction time when asked to press a key is usually anywhere from roughly half a second to several seconds, but when run via dispcalGUI there's no user interaction when characterization follows the interactive adjustment step, and the delay between dispcalGUI recognizing the "press any key" message from Argyll CMS and actually sending the key is mere milliseconds, so I assume the pointer will be turned on and off without much of a delay and maybe the K-10 has issues with that, i.e. maybe it ignores a "turn the pointer off" command when it follows too rapidly after a "turn pointer on" command. I'm just speculating though).
fhoech is offline
post #3984 of 4587 Old 10-19-2015, 04:01 PM
gwgill's Avatar
Quoted: 250 Post(s)
Liked: 186
It doesn't seem to be working that way. I had it set to use my main computer screen in window mode, and there was no "Place instrument.." message for the K10 or the i1d3. It did show this message for a remote test window (ChromeCast).
gwgill is offline
post #3985 of 4587 Old 10-19-2015, 05:33 PM
gwgill's Avatar
Quoted: 250 Post(s)
Liked: 186
Right, so just this sequence causes you problems ?
I don't seem to be able to reproduce the issue though. The LED taret lights go out for me and stay out after clicking "OK", and don't go on again after hitting "stop" during interactive adjustment.
Hmm. I do notice a bug in there, although I would think it was in V1.8.2 as well. You could try this, to see if the black measurements are more stable.
gwgill is offline
post #3986 of 4587 Old 10-19-2015, 05:33 PM
gwgill's Avatar
Quoted: 250 Post(s)
Liked: 186
ArgyllCMS operates stand-alone. Each tool that does display measurements needs to give the user a chance to see where the test patch window will appear, and therefore where they should place the instrument. So each time such a tool starts, by default it displays a grey test window, and asks to user to position the instrument before moving on. This is the time to turn instrument guide lights/lasers on, because this is precisely the time it can and should be used, and minimises the number of interactions needed with the user.
gwgill is offline
post #3987 of 4587 Old 10-20-2015, 12:16 PM
Sunset1982's Avatar
Quoted: 48 Post(s)
I got a strange problem with dispcalgui and my new i1Display Pro.
I bought a new i1D Pro and since then I got a "Error-display read failes with'instrument access failed'" message. The new meter is rev.b.
the old one is rev. a and works flawless... any idea?
post #3988 of 4587 Old 10-20-2015, 12:54 PM
Quoted: 13 Post(s)
Liked: 1
Hello guys, what is the best way to measure the white balance? I have noticed that the results of the measurements are different if a move the windows of dispacalgui on the screen at the same time when Madtpg is open and measuring... Actually I leave madtpg use full screen and I swap quickly with alt/tab to check the measurements of the WB without anything else on the screen to not skew the results...
yokbob is offline
post #3989 of 4587 Old 10-20-2015, 01:40 PM
Quoted: 13 Post(s)
Liked: 1
Before the launch of the calibration I have a message asking if I want to use linear calibration or enable calibration curves in the profile... Could you please let me know what is the best to use??? Many thanks
yokbob is offline
post #3990 of 4587 Old 10-20-2015, 01:52 PM
sillysally's Avatar
Quoted: 874 Post(s)
Liked: 874
Yes that is the sequence that causes me problems.
I have seen the LED target light go on after that sequence.
I ran my third profile last night, used my new method to work around what I think the issue is, and it looks like that profile came out as expected.
Thank You I will try your new tools.
I haven't installed the 3DLUT's from last night's profile. Once I install in eecolor and measure using CM and the Lumagen 2041 as pattern generator. I will have a better idea on how the old beta worked.
I just find it better to setup the meter using a cross hair window before I start any interaction with calibrate and profiling. madTPG window is always centered as is the Lumagen's window. So from making a meter profile matrix (using Chromasurf), pre calibration (using Calman), white point target, calibration and profiling (using argyllCMS) my meter is always reading from the same spot.
iow once I set my meter/s placement, there is no need to reset it.
ss
Reply Display Calibration
