MadVR - ArgyllCMS - Page 140 - AVS Forum | Home Theater Discussions And Reviews
 391Likes
Old 12-31-2015, 08:19 AM
fhoech's Avatar
Quoted: 392 Post(s)
Liked: 243
Originally Posted by VerGreeneyes View Post
I'm sure, although it really is a while ago so the APIs might have changed (this was before there was a 64-bit version of madVR). I did have to "Enable LAN Access" in the madVR tray icon and let it through my firewall (and I made sure to have madHcCtrl.exe running on both PCs by changing the tray icon settings to "always show tray icon").
Ok, that seems to make sense. The two madHcCtrl instances saw each other over the network, established the connection, and then dispcal/dispread simply connected to the local madHcCtrl instance.I guess the key was to have madHcCtrl running on both PCs prior to using dispcal/dispread.
DisplayCAL - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 3.1.3.1 released 2016-04-11
Current development snapshot: 3.1.3.2 Beta (Windows/0install) released 2016-04-23 | Standalone | Changelog
DisplayCAL on Facebook
fhoech is offline
Old 12-31-2015, 08:39 AM
fhoech's Avatar
Quoted: 392 Post(s)
Liked: 243
Originally Posted by johnsanc View Post
My laptop is actually a Macbook, and I still cannot get discalGUI to connect to madTPG on my Windows 10 HTPC. I also tried your suggestion in my Windows 10 VM on my Macbook as well, but in both cases I just get an error that says "madTPG was not found or could not be launched." Any suggestions?
You may have to poke some holes in your firewall. Note that if you're on a Mac, you don't need to make the config edit I mentioned.
fhoech is offline
Old 12-31-2015, 08:45 AM
johnsanc's Avatar
Liked: 0
That did the trick for Windows to Windows. Had to set the firewall rules to All instead of Private for some reason. No luck with Mac, but I'm on the right track. Thanks for your help!
johnsanc is offline
Old 12-31-2015, 09:01 AM
johnsanc's Avatar
Liked: 0
Mac fixed as well. For some reason the firewall rule for Python wasn't created yet. Thanks again!
johnsanc is offline
Old 12-31-2015, 01:02 PM
VBB
VBB's Avatar
Quoted: 842 Post(s)
Liked: 702
Thank you Florian, Graeme, and Mathias. Happy New Year everyone!
10k, fhoech and chros73 like this.
Henry
Vizio M70-C3, Sharp LC-70LE857U
Onkyo HT-RC360
Synology DS1813+ & DX513 x2
X-Rite i1Display Pro, ArgyllCMS, DisplayCAL, madVR, HCFR
HTPC running Kodi with MPC-HC + madVR, Plex for remote streaming
VBB is online now
Old 01-01-2016, 10:57 PM
sillysally's Avatar
Quoted: 733 Post(s)
Liked: 771
Using Windows 10 pro, color management extended, NVIDIA Quadro video card, DispcalGUI and madTPG as pattern generator.
Any thoughts on why madTPG window on my TV goes dormant when starting calibration and or profile from DispcalGUI. What happens is the dormant TPG screen stays the same showing the headers and the test patterns are displayed on my PC screen. If I use the pointer on the extended screen (TV) click on it, that makes the screen active and all is well running test patterns for calibration, but when dispcalGUI starts the profiling test patterns the extended screen is dormant and the PC starts displaying the patterns.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
Old 01-02-2016, 09:05 AM
-Hitman-'s Avatar
Quoted: 78 Post(s)
Liked: 87
ss
What I did was - double click the MadTPG window on the extended desktop to make it go from full screen to window size, then double click again to return it to normal full screen, then the patches would show on the extended display, seems if you are working between 2 displays it picks the main display, this method fixes it back to the correct display /extended.
sillysally likes this.
-Hitman- is offline
Old 01-02-2016, 10:26 AM
YonathanZ's Avatar
Quoted: 91 Post(s)
I followed this guide except for the testchart creation part. I instead used the "default testchart for 3dlut" drop-down option. Now the blacks look grey on my plasma. Suggestions? I couldn't exactly do the testchart thing because it looked different on my version of dispcalGUI.
YonathanZ is offline
Old 01-02-2016, 10:53 AM
VBB
VBB's Avatar
Quoted: 842 Post(s)
Liked: 702
The guide on the first page is very outdated. Florian has since streamlined everything to a point where the average user really only needs to pick a preset from the dropdown menu up top (madVR, in our case) and select a correction suitable for their screen type (unless you have a spectro).
Henry
Onkyo HT-RC360
VBB is online now
Old 01-02-2016, 10:55 AM
fhoech's Avatar
Quoted: 392 Post(s)
Liked: 243
What you are seeing is probably just the difference between your Plasma's native response and Rec 1886. You can test different tone curves settings on the "3D LUT" tab (disable "Create 3D LUT after profiling" to create a new 3D LUT from an existing profile).
fhoech is offline
Old 01-02-2016, 12:30 PM
YonathanZ's Avatar
Quoted: 91 Post(s)
What kind of tone curve would you recommend? Based on what I read Rec 1886 isn't widely used yet, is this correct? I also understand that if I set a gamma setting, it should be based on the lighting in the room. I watch in a pitch dark environment, so what would be a good gamma value? Thank you.
Edit: Calibrating to gamma 2.2 as we speak. I have good faith this will work.
I did have a difficulty with the Interactive Display Adjustment part. I tried many settings in the TV and none changed the brightness of the RGB colors, and as it is, the Green is very dark, while the Red and Blue are both above the middle. I hope this won't ruin the profiling.
Old 01-02-2016, 01:20 PM
YonathanZ's Avatar
Quoted: 91 Post(s)
After 30 minutes of profiling, it started doing a set of 1400 patches (!!) which would take hours, so I had to cancel. I set the calibration speed to fast so I'm not sure why it's doing so many patches. How do I change that so I can get it over in 30 minutes or so?
Old 01-02-2016, 01:53 PM
fhoech's Avatar
Quoted: 392 Post(s)
Liked: 243
See the other thread you created. Your problem is likely not related to calibration, you need to fix your TV settings first.
fhoech is offline
Old 01-03-2016, 06:21 AM
chros73's Avatar
Quoted: 40 Post(s)
Take a look at this: MadVR - ArgyllCMS
What kind meter do you have? Probably you can't do anything about it with a given meter but decreasing the size of patches (if you want to save time.)
MSI GE60(i73630QM,16GB,IntelHD4000(v10.18.10.4276)+GeF orceGT650m(2GB,v355.98)+muxless,1920x1080@60Hz,Ple xtor M5M 256GB SSD,Win8.1x64+MPC-HCx64+LAV+MadVR)+Yamaha RX-830+LG 55LD650(1080p@24/25/30/60Hz)
chros73 is offline
Old 01-03-2016, 07:18 AM
sillysally's Avatar
Quoted: 733 Post(s)
Liked: 771
I reinstalled Windows 10 and drivers. Your double click on the screen fix works like a champ!!!
ss
-Hitman- likes this.
Old 01-19-2016, 03:09 AM
Sunset1982's Avatar
Quoted: 48 Post(s)
is there a way to create a 3DLut for 3D tv mode? How do I do that?
Sunset1982 is offline
Old 01-19-2016, 04:49 AM
mightyhuhn's Avatar
Quoted: 654 Post(s)
Liked: 218
just tell your Tv the image is side by side and calibrate.
mightyhuhn is offline
Old 01-19-2016, 08:13 AM
Sunset1982's Avatar
Quoted: 48 Post(s)
ah, thx.
Old 01-19-2016, 12:33 PM - Thread Starter
N3W813's Avatar
Quoted: 20 Post(s)
Liked: 65
Anybody know if it is possible to connect to a remotely networked Madvr Test Pattern Generator via DispcalGUI? Or does DispcalGUI still need to be running on the same machine as MadTPG?
I've finally gotten time to mess with display calibration again and will update the first post with the latest workflow and screenshots. Sorry for the delay guys.
Brian Hampton, VBB, fhoech and 1 others like this.
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is offline
Old 01-19-2016, 12:55 PM
VBB
VBB's Avatar
Quoted: 842 Post(s)
Liked: 702
See this post: MadVR - ArgyllCMS
Henry
Onkyo HT-RC360
VBB is online now
Old 01-19-2016, 01:39 PM - Thread Starter
N3W813's Avatar
Quoted: 20 Post(s)
Liked: 65
Thanks VBB!
And thanks to Florian for adding the network madTPG support since I've now moved from Windows to OSX on my primary laptop.
N3W813 is offline
Old 01-19-2016, 06:36 PM - Thread Starter
N3W813's Avatar
Quoted: 20 Post(s)
Liked: 65
@Florian , I'm getting a "Flag '-V' not recognised" error when try to run a measurement report on DispcalGUI 3.0.6.3 on OSX.
Code:
18:33:13,613 --------------------------------------------------------------------------------
18:33:13,614 Measurement report...
18:33:13,682 --------------------------------------------------------------------------------
18:33:13,682 Session log: Measurement Report 3.0.6.3 — madVR — 2016-01-19 18-33.log
18:33:13,682
18:33:18,702 Connected to madVR version 0.90.3.0 (192.168.0.23:60562)
18:33:34,024 Pattern area: 100%
18:33:34,025 Background level: 0%
18:33:34,025 Background mode: Constant
18:33:34,026 Border width: 20 pixels
18:33:34,026
18:33:34,027 Working directory:
18:33:34,028   /
18:33:34,029    var/
18:33:34,029     folders/
18:33:34,030      vx/
18:33:34,030       0n8ljdx1799clymygrb6qtp80000gn/
18:33:34,031        T/
18:33:34,031         dispcalGUI-w2o4ZW/
18:33:34,031
18:33:34,032 Command line:
18:33:34,032   dispread
18:33:34,032     -C
18:33:34,033     '"/Applications/dispcalGUI/dispcalGUI.app/Contents/MacOS/python" ./.wait'
18:33:34,033     -P1,1,0.01
18:33:34,033     -v
18:33:34,034     -V
18:33:34,034     -K
18:33:34,034     /Applications/dispcalGUI/dispcalGUI.app/Contents/Resources/linear.cal
18:33:34,035     -c1
18:33:34,035     -yr
18:33:34,035     -X
18:33:34,036     'madVR (X-Rite i1 Pro 2).ccss'
18:33:34,036     'Measurement Report 3.0.6.3 — madVR — 2016-01-19 18-33'
18:33:34,036
18:33:34,042 dispcalGUI: Starting interaction with subprocess
18:33:34,088 Read a Display, Version 1.8.3
18:33:34,089 Author: Graeme W. Gill, licensed under the AGPL Version 3
18:33:34,089 Diagnostic: Flag '-V' not recognised
18:33:34,090 usage: dispread [options] outfile
18:33:34,090  -v              Verbose mode
18:33:34,091  -d n                 Choose the display from the following list (default 1)
18:33:34,110     1 = 'Color LCD, at 0, 0, width 1920, height 1200 (Primary Display)'
18:33:34,110  -dweb[:port]         Display via a web server at port (default 8080)
18:33:34,110  -dcc[:n]             Display via n'th ChromeCast (default 1, ? for list)
18:33:34,111  -c listno            Set communication port from the following list (default 1)
18:33:40,519     1 = '/dev/cu.usbserial-142A'
18:33:40,519     2 = '/dev/cu.usbserial-142B'
18:33:40,519  -p                   Use telephoto mode (ie. for a projector) (if available)
18:33:40,532  -y l|c                Other: l = LCD, c = CRT
18:33:40,533  -k file.cal          Load calibration file into display while reading
18:33:40,535  -K file.cal          Apply calibration file to test values while reading
18:33:40,536  -s                   Save spectral information (default don't save)
18:33:40,537  -P ho,vo,ss[,vs]     Position test window and scale it
18:33:40,537                       ho,vi: 0.0 = left/top, 0.5 = center, 1.0 = right/bottom
18:33:40,537 etc.
18:33:40,538                       ss: 0.5 = half, 1.0 = normal, 2.0 = double etc.
18:33:40,538  -F                   Fill whole screen with black background
18:33:40,539  -E                   Encode the test values for video range 16..235/255
18:33:40,539  -Z nbits             Quantize test values to fit in nbits
18:33:40,539  -J                   Run instrument calibration first (used rarely)
18:33:40,539  -N                   Disable initial calibration of instrument if possible
18:33:40,540  -H                   Use high resolution spectrum mode (if available)
18:33:40,540  -w                   Disable normalisation of white to Y = 100
18:33:40,541  -X file.ccmx         Apply Colorimeter Correction Matrix
18:33:40,596  -X file.ccss         Use Colorimeter Calibration Spectral Samples for
18:33:40,596 calibration
18:33:40,596  -Q observ            Choose CIE Observer for spectrometer or CCSS colorimeter
18:33:40,596 data:
18:33:40,597                       1931_2 (def), 1964_10, S&B 1955_2, shaw, J&V 1978_2,
18:33:40,597 1964_10c
18:33:40,598  -I b|w               Drift compensation, Black: -Ib, White: -Iw, Both: -Ibw
18:33:40,598  -Y R:rate            Override measured refresh rate with rate Hz
18:33:40,599  -Y A                 Use non-adaptive integration time mode (if available).
18:33:40,599  -Y p                 Don't wait for the instrument to be placed on the display
18:33:40,600  -C "command"         Invoke shell "command" each time a color is set
18:33:40,600  -M "command"         Invoke shell "command" each time a color is measured
18:33:40,601  -x x                 Take manually entered XYZ values
18:33:40,601  -W n|h|x             Override serial port flow control: n = none, h = HW, x =
18:33:40,601 Xon/Xoff
18:33:40,601  -D [level]           Print debug diagnostics to stderr
18:33:40,602  outfile              Base name for input[ti1]/output[ti3] file
18:33:40,677 dispcalGUI: Reached EOF (OK)
18:33:41,369 ...aborted.
N3W813 is offline
Old 01-30-2016, 03:14 AM
alamagar's Avatar
Hi,
I've created a 3DLUT following the procedure. At the end of the process dispcalgui shows me a window asking for "Install 3DLUT" or "Cancel". I chose "Install 3DLUT" but I am not sure what is the effect, as I checked afterwards in madVR and I needed to install the 3DLUT file manually.
Is this a good election (Install 3DLUT)? Do I need to undo something to prevent collateral effects?
Thanks in advance
alamagar is online now
Old 01-30-2016, 06:36 AM
baii's Avatar
Quoted: 23 Post(s)
Originally Posted by alamagar View Post
Hi,
Thanks in advance
It save the 3dlut under OS drive in program data/madvr and set 3dlut in madvr to said 3dlut.
Sent from my 306SH
baii is offline
Old 02-03-2016, 10:36 AM - Thread Starter
N3W813's Avatar
Quoted: 20 Post(s)
Liked: 65
First post has been updated with the latest workflow instructions for DisplayCAL 3.1.
UPDATES
2016-02-03 - Updated workflow with new configuration options and screenshots for DisplayCAL 3.1.
@Florian , thanks for the remote MadVR fixes!!!
VBB, 10k, zoyd and 6 others like this.
N3W813 is offline
Old 02-04-2016, 04:23 AM
chros73's Avatar
Quoted: 40 Post(s)
UPDATES
Thanks for this!
If you like you can also include this guide as a URL (I can edit it if you disagree/want to add something to it) or make your own post about it, since that makes the biggest confusion among new users.
MadVR - ArgyllCMS
MSL_DK likes this.
chros73 is offline
Old 02-04-2016, 10:11 AM - Thread Starter
N3W813's Avatar
Quoted: 20 Post(s)
Liked: 65
Originally Posted by chros73 View Post
Thanks for this!
MadVR - ArgyllCMS
Good idea! I loved your post. I've added a link to it under the step for Calibration tab.
Btw, looks like there are a couple of images missing from section 2 under Preface.
N3W813 is offline
Old 02-05-2016, 01:21 PM
xvfx's Avatar
Quoted: 395 Post(s)
Liked: 221
Should I completely remove X-Rite's iProfiler for DisplayCAL under OS X, or would it create any strange end results if left installed?
xvfx is offline
Old 02-08-2016, 07:30 AM
Brian Hampton's Avatar
Quoted: 456 Post(s)
Liked: 204
Hi,
I haven't calibrated in so long but I'm thrilled about the updates to the first post of this thread.
I'm making a calibration for my i1d3 using my i1pro (spectro) and my understanding is the matrix method can be more accurate. Anyways, I don't know if my projector (Sony HW30ES) should be classified as Refresh or LCD. Anyone know? I'm just going with LCD.
I am having a problem. I have a small monitor and the projector hooked up with MadVR TPG on the projector. And, whenever I try to measure I have to race over with my mouse and click the MadVR TPG into "focus" or DisplayCal puts all the swatches on the monitor which isn't being measured.
-Brian
Brian Hampton is offline
Old 02-08-2016, 11:26 AM
jmonier's Avatar
Quoted: 22 Post(s)
LCD is correct for most projectors.
I've found the the B.1 portion of the first post is not needed. DisplayCAL will start MadTPG and set the options for you. (It does not set fullscreen but everything works fine in a window.)
DisplayCAL will ask you to place the instrument on the window (or aim it toward the window on the screen) and you can position the window at this time before you click OK.
If "Interactive display adjustment" is checked under "Calibration settings" (it is by default and should be unless you have a good reason not to do the initial adjustment) you then still have to start it before anything happens, so it should be no problem to get everything setup before DispCAL does it's thing.
VBB likes this.
jmonier is offline
taboola here
