MadVR - ArgyllCMS - Page 141 - AVS Forum | Home Theater Discussions And Reviews
 371Likes
Old Today, 02:09 AM
MSL_DK's Avatar
Quoted: 20 Post(s)
Originally Posted by VBB View Post
That particular scene is super-grainy by choice.
Yes, it was a bad example. My concern is, however, the scene before old Murph. There I have a reddish grainy image, can be seen quite clearly between the bars and around the edges of the TV. I will find another example, later today
EDIT:
Another example is Prometheus 5:13, just before she breaks through the cave. It is clearly seen just before the light gets through to the cave.
When it gets dark where I am, I try to find other examples.
Panasonic TX-55CX700E - Dynaudio Focus 200 XD
MSL_DK is online now
Old Today, 07:41 AM
10k
10k's Avatar
Quoted: 644 Post(s)
Liked: 484
That part in Prometheus should be black not red. It is a little grainy but I believe this is compression artifacts and that before she breaks through the rock should be pitch black.
10k is online now
Old Today, 08:11 AM
MSL_DK's Avatar
Quoted: 20 Post(s)
Thanks. I also thought that this scene should be grainy, but without reddish grains. The light conditions are not optimal, where I am, to test this scene, or others with the same behavior, without a 3DLUT. But I suspect madVR to be the cause. I have no knowledge to speak about it, but it may be a result of dithering?
Old Today, 09:28 AM
Light Illusion's Avatar
Quoted: 142 Post(s)
Liked: 386
Why not post the actual LUT here?
We can the assess it by looking at the actual LUT data.
('We' being users that have those tools and abilities)
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is online now
Old Today, 09:54 AM
MSL_DK's Avatar
Quoted: 20 Post(s)
Steve
That would be amazing. Should I just upload the profile from measurements and .cal file?
Old Today, 02:32 PM
mmdd's Avatar
Liked: 1
Hi, I'm using google translator, sorry.
When I calibrate the white dot on the computer where using mpc-hc and 100 IRE pattern to create a 3D LUT by ArgyllCMS and DisplayCAL I observe that mimsmo patron measured differently if the file I reproduce the oppo.
I use projector controls to calibrate the white and Blast HD 6450 graphics is.
Wanted to buy a 3D LUT eeColor Box, but if there is this discrepancy does not work corretamente.
What do you think
mmdd is online now
