MadVR - ArgyllCMS - Page 142 - AVS Forum | Home Theater Discussions And Reviews
 491Likes
Old 04-02-2016, 05:57 AM
Quoted: 44 Post(s)
Liked: 5
Something odd, madtpg no longer displayson my screen. It shows as open on the taskbar, and can preview it by hovering over it but it just will not show on my screen. Anyone got any ideas?
Edit - fixed.
iSeries is offline
Old 04-02-2016, 01:54 PM
Quoted: 44 Post(s)
Liked: 5
Hi guys, me again. How does this look?
ID:	1354610   Click image for larger version
Name:	Standard Colour - Gamut.png
ID:	1354618   Click image for larger version
Name:	Standard Colour - Tone Response Curve.png
iSeries is offline
Old 04-02-2016, 07:02 PM
baii's Avatar
Quoted: 25 Post(s)
There is a verify function in dispcal.
Sent from my SM-T700 using Tapatalk
baii is offline
Old 04-05-2016, 03:51 AM
chros73's Avatar
Quoted: 50 Post(s)
Liked: 24
Verification of icc profile
Originally Posted by chros73 View Post
Where are these icm profile located and how do they get loaded into Windows? I couldn't find any info in the docs about this.
Does it work automatically when I crate a 3dlut with madvr profile?
(I'm still using v3.0.6)
Originally Posted by fhoech View Post
Note that you don't really need to concern yourself with this, but they are in C:\Windows\System32\spool\drivers\color
Thanks, I found the folder. (And I upgraded to 3.1.2 version.)
As it turned out I can't use the generated icm file from a madvr profile, can I?
So, I choose and ran an "Office & Web" profile (to create an icm file for the desktop). But the Verification tab doesn't correspond to the selected Office profile: Simulation profile is checked. Is it a bug?
If I understand it correctly at the part "Checking accuracy of a display profile" of http://displaycal.net/#verify-profile , I only have to select an RGB type of testchart/reference (like: "2008 color accuracy and grayscale" or "XXXL verification") and deselect the Simulation profile. Is that right?
Because I tried to verify the verification with HCFR, but I don't know, again, what kind of color space standard I shall choose for this (sRGB?); and its measurement gave me different results.
MSI GE60(i73630QM,16GB,IntelHD4000(v10.18.10.4276)+GeF orceGT650m(2GB,v355.98)+muxless,1920x1080@60Hz,Ple xtor M5M 256GB SSD,Win8.1x64+MPC-HCx64+LAV+MadVR)+Yamaha RX-830+LG 55LD650(1080p@24/25/30/60Hz)
chros73 is offline
Old 04-05-2016, 04:26 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
You can, but note that by default, the 3D LUT presets don't do 1D LUT calibration which may be desirable for a desktop monitor profile.
That's fine.
Note that the non-3D LUT presets don't influence verification settings, and so they'll just be what was last used.
If you want to check the profile accuracy (i.e. how well the profile predicts the actual monitor gamut and response), then yes.
There's no matching option in HCFR I think (it ignores the display profile, only the video card gamma tables affect HCFR measurements), so the verifications are not comparable in this case.
DisplayCAL - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 3.3.1 released 2017-06-04
Previous development snapshot (OUTDATED): 3.2.9 Beta (Windows/0install) released 2017-05-23 | Standalone | Changelog
DisplayCAL on Facebook
fhoech is offline
Old 04-05-2016, 09:30 AM
chros73's Avatar
Quoted: 50 Post(s)
Liked: 24
Thanks for the explanation!
How? Manually copying the icm file from the profile folder? Because the corresponding options (install, load, etc...) are greyed out in the menu, if I select an old madvr profile.
I also skipped the 1D LUT calibration (by setting everything to measured on the calibration tab), I got better results with this when I used a madvr profile.
chros73 is offline
Old 04-05-2016, 09:38 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
Select your profile under "Settings", then your actual display (not madVR) on the "Display & instrument" tab, then click the "install" button next to "Settings" while on the same tab.
fhoech is offline
Old 04-05-2016, 12:54 PM
chros73's Avatar
Quoted: 50 Post(s)
Liked: 24
Now I'm getting more confused (again, since I don't know anything about )
It worked (I'd never think of that ): it complained about smissing high quality tables then it generated it and installed it. But:
1. I don't see any difference on a picture when I enabling/disabling it (icm file generated from an madvr profile)! (Applying that 3DLUT in madvr shows a huge difference in picture.)
Strange thing is that I created one of the Office profile with the same UI settings (everything set to Measured on the Calibration tab) (without the 3DLUT generation) and it shows a huge difference when I enable it.
2. Shall the Tone curve set to something else than Measured? (All the rest are set as Measured on the Calibration tab when I use the Office setting).
3. According to the first post here http://www.lightillusion.com/forums/...rum=8&topic=28 , "ICC profiles generated from 3D LUTs, as with SpaceMan ICC, will be 100% accurate". Is it the case with DisplayCal as well? (Of course it's not working for me now, see 1.)
If it's true than this would be the way to go.
4. Err... Why, do I want to do something different during this kind of verification?
5. Again from that first post (which I didn't know): "Such calibration uses 1D LUTs only in a form called VCGT, and WILL ONLY match the colour temperature and gamma of a display - NOT the gamut."
Is it the cause that we shouldn't set a Simulation profile on the verification tab?
chros73 is offline
Old 04-05-2016, 01:01 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1056
This is correct, in HCFR you can enable or disable the video card gamma tables when sending patterns.
zoyd is offline
Old 04-05-2016, 03:50 PM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
Only ICC color managed applications will make use of the display profile, much in the same vein as not all applications support (video) 3D LUTs.
The "Office" preset (like most other "PC" monitor presets) uses gamma 2.2 by default.
I'm not sure what you're asking, since DisplayCAL doesn't generate ICC profiles from 3D LUTs, but the other way around.
Possibly, maybe. For (video) 3D LUTs, there's really only one way to verify them - using the source colorspace they've been created against (e.g. Rec 709 BT 1886) as verification target. ICC profiles are linked on-the-fly, so when no specific source colorspace is chosen, you check the profile against the native display measurements, which will tell you how accurate the profile is. You can also do a similar check as with a 3D LUT by setting a simulation (source) colorspace (it's important in that case that "Use simulation profile as target" is not enabled).
VCGT has nothing to do with the simulation profile setting.
fhoech is offline
Old 04-06-2016, 03:53 AM
chros73's Avatar
Quoted: 50 Post(s)
Liked: 24
Yes, you're right, of course
Yes, (like desktop wallpaper or irfanview, etc.), but it doesn't do anything when I apply a display profile generated from a madvr profile (I tried it twice: on my TV and on my monitor). Can you verify it whether it's a bug? (Because it would be the easiest way to generate a display profile if we already created a 3DLUT.)
I wanted to do the 2nd (with the "Use simulation profile as target" is enabled) for the first time I tried, and it gave me huge errors. Is it because the icc profile doesn't modify the color gamut?
chros73 is offline
Old 04-06-2016, 04:16 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
The Windows desktop is not color managed, and IrfanView's color management is very limited and doesn't work right most of the time in my experience. For a (free) color managed image viewer, try Google Picasa or XnViewMP instead (you have to enable color management manually in both).
No, it's because when "Use simulation profile as target" is enabled, the display profile is not used at all.
fhoech is offline
Old 04-06-2016, 02:12 PM
Quoted: 44 Post(s)
Liked: 5
Ok after watching a bunch of stuff it seems my previous calibration was crushing blacks a little. Yesterday i redid everything, figuring i'll give 1886 another go. I followed the procedure, pre calibration on tv minimal - just turned off any extra processing, brightness and contrast correctly set. Started displaycal up and chose madvr preset, ticked off white drift as i have a plasma, and clicked calibrate andprofile. I adjusted high end red and blue so everything was centered and ran the calibration. Much to my surprise this time 1886 looked great, decent contrast, good shadow detail. Today For my own peace of mind to make sure it wasnt a fluke i reran everything. Didnt change a thing on the tv so everything was centered when i started the calibration. It ran through and it came out much brighter than the one from last night. Ran again, same thing, brighter, even though nothing has changed. Tv and meter well warmed up in all cases.
Does anyone have any idea why i cant seem to get a repeatable, consistent calibration, despite nothing changing at all on the tv or in displaycal/madtpg? Because i can't possibly say my tv is calibrated if the outcome isnt repeatable.
iSeries is offline
Old 04-06-2016, 03:32 PM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
Sounds like a possible issue with ABL or maybe black level retention. What was the black and white level measured for the "good" and one of the "bad"/"too bright" runs (you can look at the profile information or the measurement data TI3 file to check)?
fhoech is offline
Old 04-07-2016, 03:01 AM
Quoted: 44 Post(s)
Liked: 5
Apologies, it was of my own making. Seems my i1d3 is really sensitive to ambient light. I'd run the 'bad' calibrations during the day and early evening. Running the calibration in darkness makes a massive difference (which i didnt think it would as i'm using the meter in direct contact). I ran 3 20 minute calibrations last night to be sure, and then finished off with the default 1500 pattern calibration. 1886 looks wonderful.
As for ABL, through trial and error, experimenting with various window sizes and black / APL backgrounds, my best results come from using a 10% window on a black background. Using APL backgrounds lowered gamma so the image was too bright, and using smaller windows than 10% on a black background skewed readings. Bigger than 10% triggered too much ABL. 10% - just right. I'm sounding like Goldilocks now lol.
Anyway, thanks for your help and thanks for this great software. Just one more question if I may? Is it worth running a longer calibration than the default?
fhoech likes this.
iSeries is offline
Old 04-07-2016, 07:23 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
That's up to you to decide. Measuring more patches will usually tighten the deltaE differences - if that results in tangible (visible) improvement is in the eye of the beholder, though.
fhoech is offline
Old 04-07-2016, 10:01 AM
Quoted: 44 Post(s)
Liked: 5
Thanks - I think I will stick with the defaults. When targeting 1886, is it better to have the TV on 2.2 gamma or 2.4?
iSeries is offline
Old 04-07-2016, 07:47 PM
mightyhuhn's Avatar
Quoted: 764 Post(s)
Liked: 261
depends on what the real gamma is with 2.4/2.2 and the black point using BT 1886.
so no one can answer that.
maybe measure and see what is closer to bt 1886.
mightyhuhn is online now
Old 04-08-2016, 04:31 AM
Quoted: 44 Post(s)
Liked: 5
Thanks huhn, without actually measuring, overall it's definitely closer to 2.2. Shadow end looks to be around 2.1 or so and pushing up from there.
I'm fast coming to the conclusion that there is no way to properly calibrate a plasma. Seems the best I can do is make it look as good as I can.
iSeries is offline
Old 04-08-2016, 08:47 AM
Quoted: 44 Post(s)
Liked: 5
In MadTPG, is there a way to make the top tool bar disappear when running interactive adjustments? Once I've set the window size and set the few other options I don't need to see it anymore. Only once I've done the interactive adjustments and move on to profiling does it go full screen.
iSeries is offline
Old 04-08-2016, 12:41 PM
Sithuk's Avatar
Quoted: 31 Post(s)
Do I have to re-do a calibrate&profile if I want to create a different gamma profile? I've created a 3D LUT for Rec709 BT.1886.
Do I have to re-run all the colorimeter measurements again if I want to try a Rec709 flat 2.2 gamma? Or is there a way to create a new 3D LUT using the previous colorimeter measurements?
Sithuk is offline
Old 04-08-2016, 12:43 PM
VBB
VBB's Avatar
Quoted: 1018 Post(s)
Liked: 864
Enable full-screen and disable OSD. Two boxes up top.
VBB is offline
Old 04-08-2016, 12:45 PM
VBB
VBB's Avatar
Liked: 864
You don't have to re-run the calibration. Go to the 3D LUT tab in DisplayCAL and change the settings to what you want.
Sithuk likes this.
VBB is offline
Old 04-08-2016, 01:29 PM
Quoted: 44 Post(s)
Liked: 5
Hi, that only works when actually running the patch measurements. When doing the interactive adjustments MadTPG stays in 'windowed' mode, which is fine but I would like to know if there's a way to hide the toolbar at the top.
iSeries is offline
Old 04-08-2016, 01:36 PM
VBB
VBB's Avatar
Liked: 864
I know what you mean. It's a bug, not sure if in DisplayCAL or madTPG. You have to double-click on the madTPG window after you click "Start" on the interactive display adjustment. And no, there is no way to hide the toolbar in windowed mode.
VBB is offline
Old 04-09-2016, 08:36 AM
Quoted: 44 Post(s)
Liked: 5
Thats a shame, new to this so it's been up on my plasma for many hours over many days now and i'm pretty sure i'll end up with the tool bar burned in!
iSeries is offline
Old 04-09-2016, 09:07 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
Hours? How long does it take to do interactive adjustment on this plasma?
Btw, I'm pretty sure the madTPG behavior is by design: Once the calibration software has connected, the user shouldn't really be allowed to change some of the critical TPG settings (i.e. VideoLUTs on/off, 3D LUT on/off), because these are set by the calibration software. I would agree though that having the fullscreen on/off switch still be user controlled would be nice to have, just like the "stay on top" button, maybe @madshi can change this?
VBB likes this.
fhoech is offline
Old 04-09-2016, 09:09 AM
Quoted: 44 Post(s)
Liked: 5
Like i said, i'm new at this lol. Different contrast settings and window sizes mean different rgb adjustments, so with every different setting i try, the rgb contols have to be readjusted
And for me, once the interactive adjustment is started, i have to go onto madtpg to re-click full screen because for some reason it isnt sticking
And talking of the interactive adjustments, how critical is this to the process? If say i have a 10% window and balance high rgb, if i then make the window bigger or smaller, rgb is off again and i have to re-balance it. So how on earth am i to know if i've set it correctly? The readings also change depending on where i put the interactive adjustments window!
iSeries is offline
Old 04-09-2016, 09:36 AM
chros73's Avatar
Quoted: 50 Post(s)
Liked: 24
You're right with both statements.
Good observasion, thanks! I always wondered about this.
I tried XnViewMP but still don't see any difference with an icm generated from a madvr profile, but I should.
Can anybody confirm this? (It only takes for around 15 minutes to try it.) Thanks
chros73 is offline
Old 04-09-2016, 09:42 AM
baii's Avatar
Quoted: 25 Post(s)
If you use 3dlut, you can really try skipping the interactive adjustment and see how it result, should not be much difference.
I always do 2 run , one for madvr, one for color managed apps. Most software require "mounting/installing" in the window color management.
I like irfanview cause it can color manage untagged image, which happen to be more than one would like.
Sent from my 306SH using Tapatalk
baii is offline
