MadVR - ArgyllCMS - Page 145 - AVS Forum | Home Theater Discussions And Reviews
 500Likes
post #4321 of 4651 Old 06-07-2016, 10:27 AM
mightyhuhn's Avatar
Quoted: 779 Post(s)
Liked: 265
Originally Posted by sanderdvd View Post
My gamma tracks pretty good around 2.4 as you can see in the Chromapure result (though the 80-100 range could be a little bit better). So this makes me wonder why my low region black level (17 - 23) clipp. What do I exactly change to get 17-23 not clipp you think? Changing the black output offset slider maybe? If so, on how much % do I put that? Will a change in this setting also cover my point 2. problem with the 10IRE greyscale deviation I have?
you shouldn't use chromepure to verify the calibration. chromapure doesn't know the target that is set in displaycal.
depending on these settings black clipping could be normal and a gamma that looks strange for other programs too.
there are no logs so no one know what you are doing and what you want.
standard bt 1886 shouldn't result in black clipping.
mightyhuhn is offline
post #4322 of 4651 Old 06-08-2016, 05:01 AM
sanderdvd's Avatar
Quoted: 170 Post(s)
Liked: 31
What do you mean with "the target that is set in discalgui"? I m just aiming for a good Greyscale, Gamma and CMS calibration. As you can see in the CP results the Greyscale looks pretty good besides 10IRE. I did not post my colors but there too seems to be better results then the default projector settings.
You say that depending and "these settings" black clipping could be normal. What settings do I need to change to NOT have blacks clipped so bad? Because 17-23 black clipping just is not good. Put on any brightness pattern and it will clipp. This means that you loose shadow detail in the 17-23 range. I tried to change to black offset slider in the 3dlut settings of dispcalgui and did several measurements (0%, 20% and slider at 100%) but all give the same result: black clipps from 17-23.....
@fhoech : I also choose the "clipp WTW" option in the dispcalgui settings. I would have thought this would solve the problem but 230 all the way to 253 still flash while my goal is that only 230-234 flash.
And there is still the 10IRE greyscale that is way off.
What I m actually just are looking for are the perfect settings for:
1. a flat greyscale from 10-100IRE
2. a gamma curve that is around 2.4 from 10 to 100IRE
3. Colors that have a max delta of about 2-3.
Nothing more, nothing less.
sanderdvd is offline
post #4323 of 4651 Old 06-08-2016, 06:12 PM
mightyhuhn's Avatar
Quoted: 779 Post(s)
Liked: 265
a target gamma is for example gamma 2.4 absolute and black output offset of 30 %.
maybe the steps are there but they are to small to be seen i don't have a clue. can you seen them before calibration?
if you can't see all level before calibration open the black clipping test file in madVR go to devices -> properties -> "this display expects..." -> custom levels und change the black until you can see all levels before calibration and of cause you can try some setting on your projector too. i personally would measure the black point at the same time but that's complicated.
and there is no need for new measurements when the gamma settings for the 3D LUT is changed. it will still read the same. and more test patches are very unlikely to fix this. just create a new 3D LUT.
and of cause no one knows here if the projector is using a dynamic CR. this can make calibration nearly impossible.
post #4324 of 4651 Old 06-13-2016, 05:07 AM
sanderdvd's Avatar
Quoted: 170 Post(s)
Liked: 31
The steps are clearly visible without choosing the created 3dLUT file.
I don t use a dynamic iris. JVC projectors don t have one. Also don t use any dynamic contrast features or something like that on my projector.
post #4325 of 4651 Old 06-13-2016, 04:21 PM
mightyhuhn's Avatar
Quoted: 779 Post(s)
Liked: 265
i guess only a log can help now.
post #4326 of 4651 Old 06-14-2016, 08:00 AM
sanderdvd's Avatar
Quoted: 170 Post(s)
Liked: 31
How do I post a log here?
post #4327 of 4651 Old 06-16-2016, 03:31 AM
chros73's Avatar
Quoted: 50 Post(s)
Liked: 24
Can DisplayCal report the current refresh rate of a display? If so, how? (I couldn't find it anywhere.) I was told that it can. Thanks
@sanderdvd: if it's not too long copy it to pastebin, if it's long then zip it and upload it somewhere.
MSI GE60(i73630QM,16GB,IntelHD4000(v10.18.10.4276)+GeF orceGT650m(2GB,v355.98)+muxless,1920x1080@60Hz,Ple xtor M5M 256GB SSD,Win8.1x64+MPC-HCx64+LAV+MadVR)+Yamaha RX-830+LG 55LD650(1080p@24/25/30/60Hz)
chros73 is offline
post #4328 of 4651 Old 06-17-2016, 01:22 PM
Stereodude's Avatar
Quoted: 3454 Post(s)
Liked: 2525
Yes, it can on an impulse type display. It displays it somewhere along the way during the calibration process. I don't remember exactly where. It showed 60Hz on my plasma, and 96Hz for 24Hz input using Cinema Smooth.
Stereodude is offline
post #4329 of 4651 Old 06-18-2016, 03:34 AM
chros73's Avatar
Quoted: 50 Post(s)
Liked: 24
So, do you say that I don't see this info because of LCD? What about OLED?
(It would be good to know where it is exactly.)
chros73 is offline
post #4330 of 4651 Old 06-21-2016, 06:21 AM
Sithuk's Avatar
Quoted: 31 Post(s)
It takes about 6 hours to do a profile and calibrate for my projector. I appreciate I could speed things up by reducing the number of test patterns but I'm happy to stick with the default for now.
I created a 3D LUT for madvr for Rec709 BT.1886. I'd like to create a 3D LUT to give me a flat 2.2 gamma for comparison.
Do I have to re-run 6 hours worth of measurements or is there a quicker way?
Originally Posted by VBB View Post
Originally Posted by Sithuk
Do I have to re-do a calibrate&profile if I want to create a different gamma profile? I've created a 3D LUT for Rec709 BT.1886.
Do I have to re-run all the colorimeter measurements again if I want to try a Rec709 flat 2.2 gamma? Or is there a way to create a new 3D LUT using the previous colorimeter measurements?
VBB response:
You don't have to re-run the calibration. Go to the 3D LUT tab in DisplayCAL and change the settings to what you want.
Sithuk is offline
post #4331 of 4651 Old 06-21-2016, 07:08 AM
fhoech's Avatar
Quoted: 432 Post(s)
Liked: 283
Easy. On the 3D LUT tab, disable "Create 3D LUT after profiling".
10k and Sithuk like this.
DisplayCAL - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 3.3.5 released 2017-10-18
Previous development snapshot (OUTDATED): 3.2.9 Beta (Windows/0install) released 2017-05-23 | Standalone | Changelog
DisplayCAL on Facebook
fhoech is online now
post #4332 of 4651 Old 06-28-2016, 09:35 AM
Bloodwound's Avatar
Quoted: 126 Post(s)
Liked: 37
Sorry a little OT: gwgill: any particular reason that the Klein K10 isn't supported? Since the K10a is, supporting the K10 would be trivial,no?
Bloodwound is offline
post #4333 of 4651 Old 06-28-2016, 10:04 AM
fhoech's Avatar
Quoted: 432 Post(s)
Liked: 283
From the Argyll CMS documentation:
Reported also to work with the K-1, K-8 and K-10.
post #4334 of 4651 Old 06-28-2016, 10:13 AM
Bloodwound's Avatar
Quoted: 126 Post(s)
Liked: 37
Displaycal won't detect my K10 (rs232 version). Any idea why? Works in Chromasurf and Calman.
I want to see if it's better than the i1disp pro/c6 at calibrating my 2 rec709-ish lcd monitors. (laptop/external). I get metameric failure (whitepoint differs a lot) even though I profile my meter with an i1pro2.
And btw, the Klein K10 is an absolute stunner with my plasma. My I1disp pro jumps all over the place in comparison.
post #4335 of 4651 Old 06-28-2016, 10:40 AM
fhoech's Avatar
Quoted: 432 Post(s)
Liked: 283
Run
Code:
C:\Path\To\Argyll_V1.8.3\bin\dispread -?
and see if the instrument is listed. You may need to install the FTDI virtual COM port driver.
post #4336 of 4651 Old 06-28-2016, 10:57 AM
Bloodwound's Avatar
Quoted: 126 Post(s)
Liked: 37
Originally Posted by fhoech View Post
Run
Code:
Doesn't say anything except it does see the comport. Installing FTDI driver won't work. I'm using a USB/serial adapter which is based on the Prolific chip.
-c listno Set communication port from the following list (default 1)
1 = 'COM3'
post #4337 of 4651 Old 06-28-2016, 11:05 AM
fhoech's Avatar
Quoted: 432 Post(s)
Liked: 283
Doesn't say anything except it does see the comport. [...]
1 = 'COM3'
Try
Code:
C:\Path\To\Argyll_V1.8.3\bin\dispcal test
And see if it can access the instrument. BTW, COM ports are filtered from DisplayCAL because they are of little use normally, but you can enable them by making a small edit to the config file. The instrument has to work on the commandline first, though.
post #4338 of 4651 Old 06-28-2016, 11:14 AM
Bloodwound's Avatar
Quoted: 126 Post(s)
Liked: 37
This was the output.
Argyll 'V1.8.3' Build 'MSWin 64 bit' System 'Windows V10.0 SP 0'
dispcal: Error - new_disprd() failed with 'Instrument Access Failed'
post #4339 of 4651 Old 06-28-2016, 06:04 PM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
I don't know about any K10's that aren't USB, certainly don' have one, and so I haven't made any allowance for supporting it. I'm not sure exactly what would be involved, but if you contact me privately, I can send you some code to test.
gwgill is offline
post #4340 of 4651 Old 06-28-2016, 06:11 PM
Bloodwound's Avatar
Quoted: 126 Post(s)
Liked: 37
Technically speaking, all Klein are rs232. Just that the USB version has a USB/serial adapter built in. Klein use a ftdi chip, so if I had used a ftdi usb/serial adapter, it would technically be the same as a USB only Klein meter and would probably work, no?
But it shouldn't matter what usb/serial adapter you use, as long as it's seen as a (virtual) com port. Sent you a PM gwgill, I'm happy to test out some code.
post #4341 of 4651 Old 06-30-2016, 05:07 AM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
Right - but an RS232 and USB based serial instrument are quite different when it comes to automatically identifying them. Both have to be identified heuristically which can be time consuming, and given that the list of instruments which can be either is vanishingly small, it's fastest to only look for the type of instrument that has a particular interface. RS232 instruments include a lot of legacy X-Rite instruments as well as the Spectrolino etc., and they may be configured with quite low baud rates (1200), so a lot of time can be spent trying to locate and identify an instrument on a general serial port (minutes), whereas the small list of USB connected serial instruments use a small number of high baud rates, meaning that they can be tested for rapidly (seconds).
gwgill is offline
post #4342 of 4651 Old 06-30-2016, 08:00 PM
Bloodwound's Avatar
Quoted: 126 Post(s)
Liked: 37
Try
Code:
https://sourceforge.net/p/dispcalgui...read/79025325/
This is badly documented. Would you consider putting this option in the GUI itself? Initial argyllcms fix for the Klein rs232 version was detected correctly using this parameter in the dispcalgui config file. (I guess you haven't updated it to change the folder/filename to DisplayCal yet)
post #4343 of 4651 Old 07-01-2016, 02:05 AM
fhoech's Avatar
Quoted: 432 Post(s)
Liked: 283
I'll add this in the next update.
If you updated from dispcalGUI to DisplayCAL, then it'll use the existing folder. You can rename it manually (+ the config files) if you wish (you'll also have to edit the config file and change all paths from the old storage directory to the new one).
post #4344 of 4651 Old 07-10-2016, 09:34 AM
Liked: 1
Hey everyone. The help and knowledge you guys have provided in this thread is invaluable and I hope to pick your brains a bit more.
I am considering purchasing either an i1Display Pro or ColorMunki Display for the (almost) sole purpose of creating a 3D LUT file for madVR. My main screen is a 55LB561V (LED, full array, no local dimming).
Q1) Of the two colorimeters mentioned, which, if either, has the potential to provide a more accurate reading for my display?
Q2) If I purchase an OLED in the future, which has the potential to provide a more accurate reading for that panel type?
Q3) I have read that both colorimeters have identical hardware but, even with 3rd party software, the ColorMunki Display is significantly slower than the i1Display Pro. How are both these statements true, and how does it impact the questions above?
If you couldn't tell, this is my first foray into the world of calibrating (other than test discs), so any help is appreciated.
holdemphil is offline
post #4345 of 4651 Old 07-10-2016, 09:47 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
The two probes will have identical accuracy on whatever display type you plan to use them on (yes, they use the same hardware). The colormunki is firmware crippled to run slower and it is not supported by the commercial calibration software packages.
holdemphil likes this.
zoyd is offline
post #4346 of 4651 Old 07-10-2016, 10:32 AM
Liked: 1
Thank you for explaining that it's the firmware that causes the slower measurements. I don't really fully understand what "slower measurements" mean in practice, though. Is it just a matter of X-Rite pushing the i1 to the top or does the slower measurements actually impact calibrating an OLED, for example? If it is only a matter of patience and not end result, then I will go for the cheaper ColorMunki.
post #4347 of 4651 Old 07-10-2016, 11:53 AM
zoyd's Avatar
Liked: 1064
The minimum measurement time using the i1D3 is 200 ms + overhead (patch delay) while the colormunki is 1000 ms + overhead so it can about five times faster on bright patches. In actual use the i1D3 should be run somewhat slower anyway (0.5 sec) for profiling so depending on the patch distribution you'll save some time on long profile runs, but it may be only something like 20% and not a factor of 2. So practically speaking there is not a huge time savings. The only real limitation is if you ever wanted to use one of the commercial profiling packages, but this limitation is not one of calibration accuracy - argyllcms performs as well as (if not better in some situations) than other solutions.
zoyd is offline
post #4348 of 4651 Old 07-10-2016, 08:41 PM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
Note that because of the limited measurement rate of the Munki display, it's not practical to measure the display refresh rate and synchronize the measurements for refresh type displays. All that's practical is to do longer measurements and hope that refresh cycle errors average out.
gwgill is offline
post #4349 of 4651 Old 07-10-2016, 09:11 PM
Liked: 1
This is what I had read and was slightly concerned about. Would this apply to OLED technology or only plasma/CRT? I notice X-Rite have intentionally ommited OLED from their ColorMunki Display supported panel types. Related or marketing?
So much to learn.
post #4350 of 4651 Old 07-29-2016, 08:44 AM
Liked: 1
Decided to pick up the CM Display and have been playing around with it for the last few days. I have made 3 identical runs with the exception being the correction file used (and 2-point correction/backlight via interactive adjustment). During all 3 runs I set the TV to gamma 2.4, wide gamut, default brightness/contrast. Would someone be able to tell me which measurement report (attached) is the one most worth trying to tweak?
All of the reports suggest there are problems with the red swatches, and the only one that seems to track the gamma curve accurately is the one made using the i1 DisplayPro, ColorMunki Display & madVR (i1 Pro).ccmx correction file, but also seems to exacerbate the red issues (maximum ΔE*00) and throw some other colours off.
Reply Display Calibration
