MadVR - ArgyllCMS - Page 151 - AVS Forum | Home Theater Discussions And Reviews
 489Likes
post #4501 of 4590 Old 01-30-2017, 01:18 PM
Liked: 0
Originally Posted by madshi View Post
Something wrong with the 3dlut then. Did you use madTPG and did you tell ArgyllCMS/DisplayCAL that the 3dlut has to be video levels for input and output?
Yes I used these options (but the output range was greyed out to video levels, there was no way to change that).
Attached is a few seconds of video I used to test the WTW (rename the .doc to .mp4)
As soon as I enable the LUT the text becomes visible.
newpball is offline
post #4502 of 4590 Old 01-30-2017, 02:05 PM
VBB
VBB's Avatar
Quoted: 1018 Post(s)
Liked: 863
You said your monitor expects full range. Did you then set the entire video chain to 0-255 (madVR, video driver, monitor)? That would be the only correct option, and the result should actually be the opposite: You should not be able to see BTB/WTW at all, because it would be clipped.
holdemphil likes this.
VBB is offline
post #4503 of 4590 Old 01-30-2017, 02:20 PM
Liked: 0
Correct!
If I do not set the lut indeed the video levels are expanded to full range as it should!
It is only when I use the lut I get to see WTW, which I should not.
newpball is offline
post #4504 of 4590 Old 01-30-2017, 03:42 PM
Liked: 1
Correct!
What about creating the 3DLUT with the Input encoding TV RGB 16-235 (clip WTW)? Would that help here? I have the same chain as you and only see that WTW pattern when I switch levels in madVR, and not when I use a 3DLUT (though I haven't needed to clip WTW).
holdemphil is offline
post #4505 of 4590 Old 01-30-2017, 05:22 PM
mightyhuhn's Avatar
Quoted: 764 Post(s)
Liked: 260
Correct!
only WTW ?
did you corrected the white point before calibration?
mightyhuhn is offline
post #4506 of 4590 Old 01-30-2017, 08:10 PM
HDgaming42's Avatar
Quoted: 166 Post(s)
I'm not sure if it makes sense discussing "macroblocks" as long as your configuration is not correct.
Please first fix the configuration, then double check it by using a test pattern. If steps 16-235 have different brightness steps, but 0-15 are all black and 236-255 are all white, then black/white levels seems to be setup correctly. Please take extra care to set this up correctly, because everything else depends on that.
Switched to PC 0-255. Confirmed bolded. Reran LUT. Behold, what I refer to as "macroblocks".
Frustrating as all hell. I'm hoping you can help me troubleshoot this further...
LUT with PC 0-255
LUT Unity / Passthrough
LUT with PC 16-235
Passthrough / Unity LUT with TV Brightness Maxed
LUT with PC 0-255
LUT with Unity
The only configuration differences between the PC 0-255 LUT and the PC 16-235 LUT (beyond the video card output levels) was running fewer patches (154 vs 11K). All I did was drop the number of patches down. I didn't have to adjust brightness or contrast on the plasma--patterns looked good. DisplayCAL was happy with the white point RGB Balance and read 117cd/m2.
I did see something fly by in the logs along the lines of "black point hack failed to fire". Does that warrant looking into?
HDgaming42 is offline
post #4507 of 4590 Old 01-30-2017, 08:49 PM
Liked: 0
Originally Posted by mightyhuhn View Post
only WTW ?
Yes, there is no BTB, I checked that!
For Resolve and Scratch I generate luts without "Apply calibration (vcgt)" do I need to check that for the madVR lut?
I will check with a custom (6500) white level, perhaps that is indeed the issue.
newpball is offline
post #4508 of 4590 Old 01-31-2017, 03:09 AM
mightyhuhn's Avatar
Quoted: 764 Post(s)
Liked: 260
@HDgaming42
can you create a 3D LUT for madVR from the reading and check the result with a proper black level test pattern.
if the results are correct you don't have to do the readings again which saves a lot of time.
for me it looks like all images are black clipping even the totally undersaturated one.
@newpball
i don't know it is on by default so leave it on.
and white level is still as measured right?
post #4509 of 4590 Old 01-31-2017, 04:32 AM
Quoted: 151 Post(s)
Hello! I wonder which settings are correct when watching movies via computer? I have a computer hooked to Pioneer SC-95 to the projector Epson HC-2040. Should the settings be RGB or ycbcr 0-255 or 16-235? Anything else I can do to make it correct and "cinemalike"?
Skickat från min SM-G920F via Tapatalk
westbergjoakim is online now
post #4510 of 4590 Old 01-31-2017, 05:14 AM
mightyhuhn's Avatar
Quoted: 764 Post(s)
Liked: 260
depends on your playback device and the settings in it. test it with test file like the black clipping test file from AVS HD 709 - Blu-ray & MP4 Calibration
using YCbCr on a PC is nearly for sure not optimal.
get a colorimeter and calibrate it.
that's the topic of this thread.
post #4511 of 4590 Old 01-31-2017, 05:25 AM
HDgaming42's Avatar
Quoted: 166 Post(s)
@HDgaming42
Heading to work--I can try this tonight.
The shots are from "Dark Knight" and "Stark Trek: Into the Darkness". Both scenes are VERY dark. I agree there seems to be no detail in the blacks, but that's how those scenes look out of my PS3 direct to the TV...PS3 being YPbPr and superwhite enabled, TV 16-235.
post #4512 of 4590 Old 01-31-2017, 05:45 AM
mightyhuhn's Avatar
Quoted: 764 Post(s)
Liked: 260
i don't have these movies so what ever and it is a camera.
just use test pattern and ignore the PS3 make sure it is working correctly on the PC.
BTW. AVR and other stuff in your chain can in theory do a range conversation.
i personally would start with a direct connection to the PC and calibrate from there. the readings are still correct so you don't have to do them again as long as the chain from the PC to the screen is correct and there is no easier chain than PC->TV.
post #4513 of 4590 Old 01-31-2017, 03:42 PM
Liked: 0
Hi
I have some weird problem with Rec709 video, my LED widegamut monitor (AdoibeRGB 99%) and madVR.
I build madVR LUT3D in the usual way: madTPG, configure DisplayCAL to use madVR and measure XYZLUT, then make LUT3D (both 16-235 tp 16-235), abs colorimetric with WP scaling. MadVR set to 0-255. Computer to monitor with Displayport full range 10bpc (also tried with 8bpc) . I mean configuration is OK.
"Some videos", olny a few, show native gamut greenes and cians on scenes instead of Rec709 ones. Their neigbour colors are "almost" full saturation green or cian. It looks like when feed with such full green or cian, ArgyllCMS's LUT3D was broken or madVR has a serious bug.
I've tried making LUT3D from my desktop GPU-calibration profile, same results. I've tried setting as source profile "monitor's driver" ICM (factory synthetic profile with EDIT ganut and D65 white), same results. I've even tried set AdobeRGB profile as input to LUT3D, same results. I've tries also realtive colorimetric intent and it showed the same artifacts but over bigger area.
I've tried also 16-235 and 16-235 clip WTW, same result on those videos.
The only combination that stop this artifact is to build on OS console with ArgyllCMS a LUT3D with 0-255 in and 0-255 out.
I know that this setting is wrong, but visually it's almost equal to proper LUT3D "monitor to rec709" and does not show this ugly native gamut artifacts. When verifing that LUT3D (0-255 one) with HCFR showed 1.x-2dE oversatured primaries over Rec709 RGB primaries... but at least it has not such "AdobeRGB-like" green-cian patches where madVR shoud display Rec709 ones.
"MP4-2c\100% Color\4-100% Green.mp4" from a Test patch frm AVSForum llok gook, Rec709 green. Also Florian's "GrangerRainbow1920.avi" shows proper color, no oversaturated or AdobeRGB like cian or greens.
Any advice? Is it possible that madVR or ArgyllCMS LUT3D maker fails when some video with "WTW" green or cians is feed into their data path?
If somebody has a widegamut monitor calibrated to its full native gamut, have you noticed such artifacts?
I've seen it in Premiere CC2015 & CC2017 videos recompresed by me, or even in commercial DVD titles like "Focus" (Will Smith and Margot Robbie, the scene where Will wears a cian shirt or when ther ase some cars covered with a cian plastic), also in some MP4 anime files.
Here's a link to a Premiere CC2017 recompresed sample shortened to 2sec. I'll try to atach later an snapshot of MPC-HC with the "AdobeRGB cian" patch encoded in a JPG with my EDID/driver monitor profile embebed in that JPG.
https (double dot) (slash slash) 1fichier (dot) com (slash) ?idolmb5hge
(sorry, I cannot attach links or images)
The file is named HDR but it's not HDR (Premiere converted it to SDR) and this issue does not seem to be related to that conversion because "non-HDR" TS anime shows converted to MP4 showed teh same issue and commercial DVD (wich obviously are not HDR) showed the same issues. I mean, forget file name.
Thanks for your time and I hope somebody knows how to fix this issue!.
Hotarou is offline
post #4514 of 4590 Old 01-31-2017, 03:45 PM
Liked: 0
Sorry for the typos!
Hotarou is offline
post #4515 of 4590 Old 02-02-2017, 01:20 AM
Liked: 0
Hi
Nobody here? Does somebody see the oversaturaed blue on top left corner in the MP4 file that I linked with a widegamut monitor and a native to rec709 LUT3D with madVR?
Thanks in advance
Hotarou is offline
post #4516 of 4590 Old 02-14-2017, 03:44 AM
ConnecTEDDD's Avatar
Quoted: 1371 Post(s)
Liked: 1891
LUT with PC 0-255
LUT with PC 16-235
LUT with PC 0-255
LUT with Unity
Just to inform, we have discussed that issue via email between us, usually the ways the user has to use to locate issues to a system is to evaluate the performance by taking post-calibration measurements with a meter, verify color reproduction patterns (this is why I have added about 150 Color Reproduction patterns to my calibration disk for that evaluation) or watch real content to see if there problems introduced.
What I did? since LightSpace CMS has tools and you can import any 3D LUT correction table, I can locate the errors in a cube generated correction in a few seconds, not only for those generated for my system but from any other user which has used any other calibration solution and it's experiencing problems.
There 3 ways to locate the problems with LightSpace, looking the: 1) 1D LUT Viewer, 2) Looking and rotating the 3D Cube Viewer, 3) using LUT Preview.
Looking the 1D LUT Viewer, I saw a strange (large) lift of near black details, is the the reason of the strange blocking of near black.
I used LightSpace's LUT manipulation filter to fix that problem (flatten near black) and user verified that blocking issue gone after loaded the fixed correction but it's not the solution, he has to find out why this is happening.
Also another strange issue is that the user had pre-calibrated his 100% White before starting the display profiling but as you see at top right end of the 1D LUT Viewer the RGB channels balance has changed (re-adjusted a lot).
The Pink line is the UNITY line, I added this manually using PhotoShop for better understanding of what the LUT is doing to the signal.
This shows that there something wrong not related with hardware used as 3D LUT table holder (eeColor 3D LUT Box), but something related to software or setup configuration, just it needs some further testing from the user.
RIppolito and holdemphil like this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #4517 of 4590 Old 02-14-2017, 07:21 AM
madshi's Avatar
Quoted: 532 Post(s)
Liked: 491
Very nice!
madshi is offline
post #4518 of 4590 Old 02-15-2017, 07:26 PM
HDgaming42's Avatar
Quoted: 166 Post(s)
Sadly my media room is disassembled ATM due to a carpet installation. Followed by baseboards when I have the time. I was trying to get a base profile of my plasma with Lightspace DPS and TED's disc when I had to tear it all down.
I'll be back to report my findings. Thanks for the help!
edit: Ted--can't remember if I emailed you that a run at 80nits showed exactly the same issue(s).
ConnecTEDDD likes this.
post #4519 of 4590 Old 02-16-2017, 01:46 AM
Liked: 1891
Hi, I haven't received your new data.
post #4520 of 4590 Old 03-04-2017, 11:10 PM
Liked: 0
Plese, help.
1) I need to create DCI-P3 3D-LUT for DaVinci Resolve.
2) The only option is to choose "Video 3D-LUT for Resolve (D65 / REC709)".
3) What happens if I choose this option, but set "Source Colorspace -> DCI-P3" in "3D-LUT Settings"?
4) What Argyll done in this case? Is it create 3D-LUT for DCI-P3 colorspace, or I'll get the usual REC709 3D-LUT?
5) When I do this and then run Verification, it goes on rec709 and shows that everything is in order.
But I'm not sure that it is DCI-P3 3D-LUT.
Is there any possibility to build a DCI-P3 3D-LUT to Resolve using Argyll and DisplayCal?
Thanks for help!
HauteTension is offline
post #4521 of 4590 Old 03-05-2017, 03:41 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
Originally Posted by HauteTension View Post
[B]3) What happens if I choose this option, but set "Source Colorspace -> DCI-P3" in "3D-LUT Settings"?
4) What Argyll done in this case? Is it create 3D-LUT for DCI-P3 colorspace[...]
Correct, yes.
5) When I do this and then run Verification, it goes on rec709[...]
You need to use the same settings for verification that you used to create the 3D LUT (i.e. change simulation profile to SMPTE431/DCI-P3, and make sure tone curve matches as well).
HauteTension likes this.
DisplayCAL - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 3.3.1 released 2017-06-04
Previous development snapshot (OUTDATED): 3.2.9 Beta (Windows/0install) released 2017-05-23 | Standalone | Changelog
DisplayCAL on Facebook
fhoech is offline
post #4522 of 4590 Old 03-05-2017, 04:33 AM
Liked: 0
Originally Posted by fhoech View Post
Correct, yes.
- Thank You!
It`s heart lifted
post #4523 of 4590 Old 04-02-2017, 06:41 AM
krma's Avatar
help!
Im hoping someone can assist. I did a display calibration using HCFR before i created a 3Dlut with standard settings (per the start of this thread). But when i checked the 3Dlut calibration with HCFR afterwards it appears to be worse.
I suspect it might have something to do with the whitepoint?
My RGB, colour/saturation screenshots and HCFR files are attached.
ID:	2062753   Click image for larger version
ID:	2062769   Click image for larger version
ID:	2062777   Click image for larger version
krma is offline
post #4524 of 4590 Old 04-02-2017, 08:06 AM
Quoted: 1378 Post(s)
Liked: 346
Did you keep the same 2-pt white balance as before, especially the RGB gains?
JVC DLA-RS4910
HCFR Bug List
Dominic Chan is offline
post #4525 of 4590 Old 04-02-2017, 01:13 PM
krma's Avatar
Yes I did. I used the exact same display settings I set using HCFR.
I did notice in a previous DisplayCal run that in the initial RGB setting part (pre LUT creation), the colours weren't lining up. I was expecting them to already be lined up from the HCFR calibration.
krma is offline
post #4526 of 4590 Old 04-02-2017, 01:35 PM
Liked: 346
Did you select the same meter type settings in HCFR and DisplayCAL?
JVC DLA-RS4910
HCFR Bug List
post #4527 of 4590 Old 04-02-2017, 09:40 PM
krma's Avatar
I believe i did: Plasma EDR.
I did apply a CCMX correction file in DisplayCal. Could that be the issue?
krma is offline
post #4528 of 4590 Old 04-03-2017, 04:10 AM
krma's Avatar
Looks like that was the issue...once i put the generic EDR in the colours line up.
krma is offline
post #4529 of 4590 Old 04-06-2017, 11:51 AM
cfelicio's Avatar
My Epson 4030 suffers from bad color uniformity (the right side is quite purple, the left side is quite green, when displaying a 75% grey pattern, for example).
The new Epson 4040 and 5040 let you adjust the color controls in 9 separate regions (see attached picture), wondering if there is a way to do something similar with 3d luts? Any ideas?
cfelicio is offline
post #4530 of 4590 Old 04-06-2017, 12:31 PM
Light Illusion's Avatar
Quoted: 351 Post(s)
Liked: 662
No, a 3D LUT cannot alter screen uniformity.
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
Reply Display Calibration
