MadVR - ArgyllCMS - Page 154 - AVS Forum | Home Theater Discussions And Reviews
 492Likes
post #4591 of 4618 Old 06-21-2017, 03:02 AM
Quoted: 44 Post(s)
Liked: 5
Thinking of an upgrade to my nvidia 950 - if I get a new (nvidia) card, would I have to recalibrate my TV again or would my existing 3dlut be ok?
iSeries is offline
post #4592 of 4618 Old 06-21-2017, 07:31 AM
mightyhuhn's Avatar
Quoted: 772 Post(s)
Liked: 263
should be the same even with an AMD card in your case.
iSeries likes this.
mightyhuhn is offline
post #4593 of 4618 Old 07-08-2017, 11:16 PM
njfoses's Avatar
Quoted: 147 Post(s)
Liked: 98
Has anything changed lately with madTPG? I use both Calman and LightSpace via a laptop to calibrate my Sony 940E HDR display using madTPG as the pattern generator on my HTPC. With both programs this evening, madTPG would disconnect randomly in the middle of taking reads. My network is solid and did not drop, so i am not sure what is causing this behavior. Being that this behavior is happening with both Calman and Light Space, makes me think the issue is with madTPG. Calman, Light Space and madvr are all on the latest version.
njfoses is offline
post #4594 of 4618 Old 08-03-2017, 09:00 AM
Quoted: 121 Post(s)
Is there a FAQ or How-To do to the HDR 3DLUT calibration/profiles?
I did the normal 3D LUT, but I noticed in my KS8000 sub-tree there is a HDR. Normally I have it set to passthrough, but there is an option to add 3D LUT. I tried using the 3D LUT I have for BT2020, 709, and so forth, but it won't take them.
So I am assuming there is another method to get HDR 3DLUT?
rotarydude is online now
post #4595 of 4618 Old 08-04-2017, 11:02 AM
Liked: 0
hi Guys!
I would like to create a 3D LUT profile for madVR, however I am not sure if I should leave the Tone curve under the Calibration menu at "As measured" or shall I rather go with the "Rec. 1886" option. What's the difference?
I would also really appreciate if you could take a look at my other settings if they are right.
Thank you very much.
sorry for my English...
ID:	2263256   Click image for larger version
ID:	2263258   Click image for larger version
linux.alucard is offline
post #4596 of 4618 Old 08-05-2017, 01:38 AM
Liked: 0
Originally Posted by linux.alucard View Post
hi Guys!
TV: Samsung UE55H6500 (FHD) | Colorimeter: X-Rite i1Display Pro | Source: Blu-ray REMUX (FHD) | latest madVR and MPC-HC nightly
post #4597 of 4618 Old 08-07-2017, 03:29 PM
Luis Gabriel Gerena's Avatar
Quoted: 97 Post(s)
Liked: 64
Hello guys!
So I have been playing with ColorMunky display and DisplayCal.
Tried using the 2.2 gamma default and made sure it was set to 120 and 6500D.
Somehow the results are odd...is like my calibration ends up brighter with a lot more shadow detail than expected and when viewing flickr images in Chrome it shows severe banding specially in dark areas. The same image in Explorer does not show this. So must be a Chrome thing but odd that it does not show like this horrible when viewing with the X-rite calibration.
What I did was use the Gains settings of my tv to make all 3 colors meet the arrow as blue was higher. So it was giving me the green signa, that all was perfect.
I have my Nvidia control panel set to Use Nvida color settings, 12bpc under color depth, RGB and Full dynamic range.
Am I missing something?
I am about to order the i1Display Pro instead to use the x-rite software unless someone tells me that I am doing something wrong.
So in summary, my main concern is that the calibrated DisplayCal profile (I did not apply was just using the preview) showed an image that was much brigher, with more shadow detail than the one x-rite calibration shows (and since I edited the photos using the x-rite profile they look a bit too bright now). But if I compare a print to that image, they are surely not the same. My printed photos look very close to my screen image when using the x-rite calibration.
So....in that regards, it would seem to me that I should keep using x-rite so my prints look just like my onscreen edits.
Its also confusing that if the goal of both apps, x-rite and display cal, are to calibrate to a 'standard" why they turn out so different???
Maybe the crippled software on the Munki is to blame?
Anyways, maybe you guys can tell me what I am doing wrong.
Name:	Gamut Sony_2017-08-07 16-34 120cdm² D6500 0.0001cdm² 2.2 VF-S XYZLUT+MTX TESTGabriel.png
Mario Lemieux is GOD!
Go Pens!!!
Aguante Boca!!!
If dolphins are so smart...why do they live in igloos?
Luis Gabriel Gerena is offline
post #4598 of 4618 Old 08-08-2017, 01:08 PM
fhoech's Avatar
Quoted: 430 Post(s)
Liked: 283
Please show your exact settings.
[...] when viewing flickr images in Chrome it shows severe banding specially in dark areas. The same image in Explorer does not show this.
Chrome stable does not support LUT profiles, it falls back to the matrix tags in XYZ LUT + matrix profiles (loosing accuracy). Internet Explorer does not correctly color manage at all, it ignores the display profile and assumes sRGB for display.
The correct setting is "Other applications handle color settings".
DisplayCAL - Graphical front-end for Argyll CMS display calibration and characterization
Current stable version 3.3.3 released 2017-08-08
Previous development snapshot (OUTDATED): 3.2.9 Beta (Windows/0install) released 2017-05-23 | Standalone | Changelog
DisplayCAL on Facebook
fhoech is offline
post #4599 of 4618 Old 08-08-2017, 01:14 PM
fhoech's Avatar
Quoted: 430 Post(s)
Liked: 283
Assuming you already have a profile, on the 3D LUT tab, disable "Create 3D LUT after profiling". Set source space to Rec. 2020, tone curve to SMPTE 2084 (roll-off) and display peak luminance according to your display capabilities. Set 3D LUT format to madVR and select "convert HDR to SDR" if your display is an SDR display or "process HDR content" if it's an HDR display, then create the 3D LUT. You have to assign it to the correct slot in madVR manually afterwards because there is no API for automatic installation yet.
fhoech is offline
post #4600 of 4618 Old 08-08-2017, 07:52 PM
Quoted: 97 Post(s)
Liked: 64
I uninstalled it but now decided to try it again but sadly now I get an error :/
new disprd failed with 'instrument access failed'
Go Pens!!!
Aguante Boca!!!
post #4601 of 4618 Old 08-09-2017, 01:11 AM
fhoech's Avatar
Quoted: 430 Post(s)
Liked: 283
Close the X-Rite software. Check in device manager that your ColorMunki Display is shown under "Human Interface Devices" as "HID-compliant vendor-defined device".
fhoech is offline
post #4602 of 4618 Old 08-09-2017, 08:19 PM
Quoted: 97 Post(s)
Liked: 64
Weird but I was able to get it working without doing anything today and I restarted several times yesterday! Anyways, playing around I started noticing something. It is that with the DisplayCal it creates kind of posterization effect easily visible on shadow areas. Now this goes away if I go into the Color Management of Windows and check the option "Use Windows Display Calibration" When I check that option then while while the image looks darker, I can brighten it and the shadows show a normal gradient into lighter areas instead of the blotchy posterization I was seeing before.
So looks like it happens if I let DisplayCal control things. No idea why, maybe my Sony 43X800D is not that good to be used as a photo editing display? I am consindering a BenQ that is under $1000 but I would hate to give up my 43" for a 32"
Thanks!!!
PS the posterization happens with Display Cal profiles no matter what, after further testing. The only time I dont get that issue is when using the X-rite calibration specifically made with the Easy (photo) option. So confusing!
Go Pens!!!
Aguante Boca!!!
post #4603 of 4618 Old 08-10-2017, 04:20 AM
fhoech's Avatar
Quoted: 430 Post(s)
Liked: 283
Probably means your graphics card driver is quantizing to 8 bits by simple integer truncating. Windows quantizes calibration to 8 bits by rounding to the nearest integer. You can have the same in DisplayCAL by choosing 8 bits in the "Bitdepth" submenu of the profile loader right-click menu.
fhoech is offline
post #4604 of 4618 Old 08-11-2017, 02:18 AM
Liked: 0
This is my first calibration, what do you think? (3D LUT madVR)
Name:	Tone response relative.png
ID:	2266206   Click image for larger version
Name:	Tone response absolute.png
ID:	2266208   Click image for larger version
Name:	Gamut relative.png
ID:	2266210   Click image for larger version
Name:	Gamut absolute.png
post #4605 of 4618 Old 08-11-2017, 07:51 AM
mightyhuhn's Avatar
Quoted: 772 Post(s)
Liked: 263
hard to judge anything from this picture are they post calibration than this is bad.
you should have access to more advanced calibration results.
post #4606 of 4618 Old 08-11-2017, 11:00 PM
Liked: 0
TV: Samsung UE55H6500 (FHD LED) | Colorimeter: X-Rite i1Display Pro | Source: Blu-ray REMUX (FHD) | latest madVR and MPC-HC nightly
sorry for my poor english
File Type: zip madVR 2017-08-11 08-59 0.3127x 0.329y S XYZLUT.7z.zip (515.6 KB, 8 views)
post #4607 of 4618 Old 08-13-2017, 03:30 PM
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
With DisplayCal 3.3.3, I can't find a way to create 3DLUTs for the eecolor box, has the workflow changed?
I use madtpg and have "Display" set to Madvr but can't specify 3D LUT file format, it is greyed out with IRIDAS (.cube)
and where have all the presets gone?
I seem to be able to load some settings that was written with a previous calibration and get the eecolor format but
there surely must be way to specifiy it manually?
EDIT: seems to be some installation quirk, when I run it as administrator, it behaves as it should... weird.
I was prompted to upgrade and the 3.3.3 version installed itself, not sure what could have gone wrong there.
rickardl is offline
post #4608 of 4618 Old 08-14-2017, 04:44 AM
mightyhuhn's Avatar
Quoted: 772 Post(s)
Liked: 263
can you create a verification and upload that html file?
post #4609 of 4618 Old 08-14-2017, 07:16 PM
CFC
CFC's Avatar
Quoted: 24 Post(s)
Still very much learning, and would like some help on matching an HCFR gamma curve.
What would be the equivalent 3D lut tone curve for HCFR set at BT. 1886 with 2.25 effective and 100% input offset?
Thanks for the help,
CFC
Edit:
It looks like based on the information provided by @chros73 here I should be using: 2.25 gamma, relative, 0% output offset
CFC
CFC is online now
post #4610 of 4618 Old 08-15-2017, 02:27 AM
fhoech's Avatar
Quoted: 430 Post(s)
Liked: 283
That's correct.
fhoech is offline
post #4611 of 4618 Old 08-15-2017, 02:29 AM
fhoech's Avatar
Quoted: 430 Post(s)
Liked: 283
Looks like something messed up permissions of your program files directory. Uninstall, remove potentially remaining folder C:\Program Files(x86)\DisplayCAL manually, reinstall.
fhoech is offline
post #4612 of 4618 Old 08-15-2017, 02:35 AM
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
Yes, it seemed I got the wrong permissions giving almost a readonly view of the application...
I can get by with running as Admin for the time being.
By the way, is there a way to specify other gamma settings besides BT1886, 2.4 and 2.2? I am "missing" a 2.3 setting.
rickardl is offline
post #4613 of 4618 Old 08-15-2017, 02:38 AM
fhoech's Avatar
Quoted: 430 Post(s)
Liked: 283
Sure, just type in the value you want.
rickardl likes this.
fhoech is offline
post #4614 of 4618 Old 08-15-2017, 07:24 AM
Liked: 0
Measurement Report attached.
post #4615 of 4618 Old 08-15-2017, 07:44 AM
mightyhuhn's Avatar
Quoted: 772 Post(s)
Liked: 263
doesn't work for me the forum is not providing the zip.
post #4616 of 4618 Old 08-15-2017, 08:44 AM
fhoech's Avatar
Quoted: 430 Post(s)
Liked: 283
The report looks fine, but to verify a 3D LUT, you need to set it in madVR's settings, select the profile it was created from under "Settings" in DisplayCAL, then enable "simulation profile" on the verification tab, set it to Rec. 709, make sure tone curve parameters match the 3D LUT settings, and enable "use sim. profile as target" + "enable 3D LUT". This is why I recommend using the presets because they will set verification up correctly for you.
fhoech is offline
post #4617 of 4618 Old 08-16-2017, 01:16 AM
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
So what would the settings for Absolute/Relative and black output % be for creating a power 2.3 gamma?
rickardl is offline
post #4618 of 4618 Old 08-16-2017, 01:39 AM
mightyhuhn's Avatar
Quoted: 772 Post(s)
Liked: 263
black offset is 100 % for gamma 2.3 but absolute or relative depends on what you want.
Reply Display Calibration
