MadVR - ArgyllCMS - Page 156 - AVS Forum | Home Theater Discussions And Reviews
 500Likes
post #4651 of 4655 Old 10-11-2017, 02:22 AM
ConnecTEDDD's Avatar
Quoted: 1733 Post(s)
Liked: 2137
Originally Posted by gdim View Post
Hey @ConnecTEDDD ,
Thanks for the input! I wouldn't expect a 1% size difference to produce a 500+ nit difference in luminance, right? Or do you think this is possible? The luminance went from around 1300 nits with GDI and madTPG down to only around 720 nits with Masciola's patterns (either played through MPC-HC/madVR or with a USB directly on the TV).
So I'd assume it's more the metadata that are making the TV misbehave. I'll try altering the metadata on Masciola's patterns when I get some time and match them with what I see in madTPG and what was was provided by The Coolest here and see what I get.
Hi, 1% patch difference can have about 40 nits difference for example.
About the difference you see, the metadata or the RGB triplet is responsible.
gdim likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #4652 of 4655 Old 10-20-2017, 05:43 AM
Quoted: 44 Post(s)
Liked: 6
Hi, I'm playing around with creating an HDR to SDR 3dlut from a previous calibration. I followed the instructions further back in this thread, and selected source colour space BT2020, tone curve SMPTE 2084 (roll off) and entered the display peak luminance as measured. I changed black output offset to 100% as I don't want a BT1886 type curve, I want the same curve as my SDR 3dlut (REC 709 2.4). Using this profile everything seems too bright and washed out, like it is a BT1886 type curve which I don't want. If I switch to MadVR's own HDR to SDR conversion with my display peak luminance set there, things look much more like I'd expect. Am I doing something wrong? If I open up advanced options in Displaycal, you can select 'source colourspace', but there is also a 'content colour space' which was defaulted to DCI P3. What's the difference between content colour space and source colour space? Should I be changing content colour space to REC 2020?
iSeries is offline
post #4653 of 4655 Old 10-20-2017, 09:59 AM
Tony359's Avatar
Quoted: 60 Post(s)
hey guys,
have been busy but still would love some help on the issue posted on the previous page
MadVR - ArgyllCMS
thanks
Tony359 is offline
post #4654 of 4655 Old Yesterday, 07:55 AM
saltanar's Avatar
Quoted: 12 Post(s)
Jvc Projector Hdr 3d lut
I read many posts but I don't understand. There is a simple way to create a good Hdr 3d lut for my jvc x5000 wiht Dispalycal or Calman on the same way I do for Sdr?
saltanar is offline
post #4655 of 4655 Old Yesterday, 05:01 PM
crestron's Avatar
SW320 HDR 校正
未校正的灰阶平衡
校正后的灰阶平衡
crestron is offline
Reply Display Calibration
