MadVR - ArgyllCMS - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 462Likes
post #2251 of 4445 Old 07-05-2014, 12:55 AM
3ll3d00d's Avatar
Quoted: 1553 Post(s)
Liked: 535
Originally Posted by sanderdvd View Post
meter correction file: I ll need to check at Chromapure but all I got from them is a Licence file for Chromapure but this is not what you mean of course. I know my meter is not a regular OEM i1 Display 3 Pro meter but a meter that was calibrated by Chromapure
I have the same meter with same sort of calibration data in the licence file. I asked for the underlying data and then created a correction matrix using the approach in this post
There are further posts after that for actually getting it setup so it works.
I made a spreadsheet with the calcs in, I can send you a copy if you like.
3ll3d00d is online now
post #2252 of 4445 Old 07-05-2014, 01:05 AM
sanderdvd's Avatar
Quoted: 162 Post(s)
Liked: 30
thxz for your reply 3ll3d00d. Can you provide me with a step-by-step-guide how to create this 'meter correction file'?
sanderdvd is offline
post #2253 of 4445 Old 07-05-2014, 01:43 AM
Manni01's Avatar
Quoted: 2618 Post(s)
Liked: 2045
You don't need it to generate the cube, so I would just skip this test for know.
You can always try to refine once you got everything working.
Most i1d3 are extremely close to reference. While the extra calibration Tom did (which resides in the license file) will not be available to ArgyllCMS, it only adds accuracy if your display is the same or similar type as Tom used to generate the correction in the license file.
Just skip that step for now is my advice. If you notice a lack of accuracy, then you can always profile your meter, but until then just use it "raw".
The few i1d3s (factory, not "enhanced") I tried were so close to my i1pro2 that I didn't profile them as I had no idea which one was closer to reference (the i1pro2 itself not being a reference meter).
Manni01 is online now
post #2254 of 4445 Old 07-05-2014, 01:50 AM
sanderdvd's Avatar
Quoted: 162 Post(s)
Liked: 30
Most i1d3 are extremely close to reference. While the extra calibration Tom did (which resides in the license file) will not be available to ArgyllCMS, it only add accuracy if your display is the same or similar type as Tom used to generate the calibration file.
The few i1d3 (factory, not "enhanced") I tried were so close to my i1pro2 that I didn't profile them as I had no idea which one was closer to reference (the i1pro2 itself not being a reference meter).
thxz manni.
So looking at my post #2225 + enable Aero I m good to go and start tje measurement?
post #2255 of 4445 Old 07-05-2014, 02:02 AM
Manni01's Avatar
Liked: 2045
thxz manni.
That I don't know as I've never used ArgyllCMS to generate a LUT (I used Calman), I let those who know answer back. It looks to me that you are, at least for a first test, but I might be wrong.
post #2256 of 4445 Old 07-05-2014, 02:03 AM
3ll3d00d's Avatar
Liked: 535
Get hold of your "chromapure calibration report" which has the measured offsets in it (these are applied in chromapure when you select a measurement mode)
Grab this spreadsheet and enter the offsets from the report into the offset x and offset y cells
Open a command prompt in your argyll install folder and create a reference ccxx.ti3 file
Code:
c:\Argyll_V1.6.3\ref>..\bin\fakeread Rec709.icm ccxx
c:\Argyll_V1.6.3\ref>dir ccxx.ti3
 Volume in drive C has no label.
 Volume Serial Number is C44B-B838
 Directory of c:\Argyll_V1.6.3\ref
05/07/2014  09:14               561 ccxx.ti3
               1 File(s)            561 bytes
               0 Dir(s)  78,855,057,408 bytes free
c:\Argyll_V1.6.3\ref>copy ccxx.ti3 i1pro3_front_projection_screen.ti3
        1 file(s) copied.
Open i1pro3_front_projection_screen.ti3 in a text editor and replace the XYZ values with the values from the spreadsheet in the cal X, cal Y and cal Z columns
Also add the fields as advised in MadVR - ArgyllCMS
Code:
in ccxx.ti3, add the following lines before NUMBER_OF_FIELDS:
TARGET_INSTRUMENT "X-Rite i1 Pro 2"
INSTRUMENT_TYPE_SPECTRAL "YES"
If the display this is for is a refresh type (ie. CRT, Plasma, DLP)
Code:
add the following lines to your "my meter" .ti3 file before NUMBER_OF_FIELDS:
TARGET_INSTRUMENT "Xrite i1 DisplayPro, ColorMunki Display"
INSTRUMENT_TYPE_SPECTRAL "NO"
DISPLAY_TYPE_REFRESH "YES"
DISPLAY_TYPE_BASE_ID "2"
Code:
if this is not a refresh display (ie. LCD), add the following lines
DISPLAY_TYPE_REFRESH "NO"
DISPLAY_TYPE_BASE_ID "1"
Finally run the following command
Code:
c:\Argyll_V1.6.3\ref>..\bin\ccxxmake -T"Front Projection Screen" -f ccxx.ti3,i1pro3_front_projection_screen.ti3 i1pro3_front_projection_screen.ccmx
Writing CCMX file 'i1pro3_front_projection_screen.ccmx' succeeded
You should then be able to use the resulting i1pro3_front_projection_screen.ccmx to apply that correction to the process. You may want to run it without this in the first instance though to check that everything works with a default setup.
|Tch0rT| likes this.
post #2257 of 4445 Old 07-05-2014, 03:56 AM
sanderdvd's Avatar
Quoted: 162 Post(s)
Liked: 30
but you are using the method as described in the beginning of this topic dont you???
post #2258 of 4445 Old 07-05-2014, 04:28 AM
Manni01's Avatar
Liked: 2045
I'm using a similar method (Calman Ultimate) to generate a 3DLUT for MadVR, but I've never used ArgyllCMS/DispcalGUI, which is why I suggested you post here. As you can see, there are very knowledgeable people who know much more than I do about the process detailed in this thread. as they've used it first hand.
The principles are exactly the same though.
post #2259 of 4445 Old 07-05-2014, 04:58 AM
fhoech's Avatar
Quoted: 408 Post(s)
Liked: 267
Originally Posted by Megalith View Post
Does this mean that the following information on the opening post is incorrect and should be disregarded?
2013-05-20 - Elevated black point still exists for some displays/configurations, therefore, Black Point Compensation option should be enabled in DispcalGUI. (step B10)
If targeting BT.1886, the above should definitely be disregarded, because that would override the BT.1886 mapping - a 3D LUT created from a BPC profile with BT.1886 mapping and gamma "x" would result in effectively an output offset, gamma "x" "absolute" tone response curve, not at all BT.1886!
Originally Posted by zoyd View Post
It's explained in this post as removing the black offset directly from the measurements and then rescaling the result
Yes, although the implementation has changed in dispcalGUI 2.0 and newer so that the measurements are no longer altered, which has the (intended) side effect that the profile self check error reported after profile creation correctly reflects the error introduced by BPC (i.e. it will be higher than for a profile without BPC). The net result when using the profile will be the same as previously though.
(I presume so that white XYZ is mapped back to it's original value).
Yes.
I don't know in practice how similar that result will be to what -f0 achieves in dispcal.
It's not directly comparable, but the closest dispcal setting would be -f1 -Gx actually (100% black level output offset with "absolute" gamma "x").
fhoech is offline
post #2260 of 4445 Old 07-05-2014, 07:15 AM
Holiday121's Avatar
Quoted: 476 Post(s)
Liked: 140
Anyone going to be around for a little bit that could give me a hand?
I posted some graphs in a previous post and need some help fixing them. Not sure how off they are.
Also every time I go to create one do I have to wait the 2-4 hours until it completes to see how close I am?
Holiday121 is offline
post #2261 of 4445 Old 07-05-2014, 07:33 AM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1047
@Holiday121 Don't take this wrong but I think you need to spend more time on basic calibration principles so you know what to look for in the graphs and can make your own decisions on where to tweak to get better performance. You should know how to assess your baseline performance (before any 3dlut work) so that you aren't wasting time (and getting frustrated) after complicated and lengthy procedures.
Establish a set of measurements that tell you quickly how your display/projector is behaving, this usually involves both grayscale and some combination of color checker and saturation sweeps that have low average dE and no outliers (peak values 2 or 3x the average). Do this using internal controls only and then after you better understand what the measurements are telling you in this scenario then you can do the 3dlut and you'll quickly see where there are differences in performance (hopefully for the better). You may not even need a 3dlut.
zoyd is offline
post #2262 of 4445 Old 07-05-2014, 07:41 AM
Holiday121's Avatar
Quoted: 476 Post(s)
Liked: 140
I understand from where you are coming from but from what I was told is to get all the dE in line with the greyscale and the 3dlut will take care of my gama and other corrections.
I spent the time going through and tweaking my greyscale to a avg of .78 I believe.
There isn't to many guides on dispcal and breakdowns like hcfr besides the walk through in the first page in which I followed.
Not knowing if I'm on the right track had me second guessing and us taking 4 hours for the 3dlut doesn't bother me but if I do that 100 times and don't know what kind of improvements I need that means I am just destroying my bulb on my projector.
post #2263 of 4445 Old 07-05-2014, 09:17 AM
sanderdvd's Avatar
Quoted: 162 Post(s)
Liked: 30
My calibration (with a i1 Display 3 Pro meter) is already running for 2 hours now! Is that normal?
post #2264 of 4445 Old 07-05-2014, 09:18 AM
Holiday121's Avatar
Quoted: 476 Post(s)
Liked: 140
Yes it too a little longer then that for me.
post #2265 of 4445 Old 07-05-2014, 10:22 AM
Holiday121's Avatar
Quoted: 476 Post(s)
Liked: 140
So after getting my HTPC to work and see my meter I decided to take a 20 point mesurement and its way different then when i took it with my laptop.. So i am guessing using hcfr automated 20 point images is the one i should use?
ID:	149090   Click image for larger version
ID:	149098   Click image for larger version
ID:	149106   Click image for larger version
ID:	149114   Click image for larger version
Name:	main screen.png
post #2266 of 4445 Old 07-05-2014, 11:47 AM
Holiday121's Avatar
Quoted: 476 Post(s)
Liked: 140
ok so here is the newest 10 point i have..
should i mess with the 10% range even though it says .2 but the graph shows them a little high?
ID:	149250   Click image for larger version
post #2267 of 4445 Old 07-05-2014, 02:57 PM
sanderdvd's Avatar
Quoted: 162 Post(s)
Liked: 30
After more than 2 hours my measurement is completed with this result:
What does this actually tell me?
And which options do I check and do I install the profile or not?
post #2268 of 4445 Old 07-05-2014, 03:04 PM
sanderdvd's Avatar
Quoted: 162 Post(s)
Liked: 30
@3ll3d00d. I got my hands on the info you told me to get from Chromapure.
Here it is:
Could you help me on my way what the steps are that I need to take now?
post #2269 of 4445 Old 07-05-2014, 03:07 PM
fhoech's Avatar
Quoted: 408 Post(s)
Liked: 267
The profile self check tells you how well the profile fits the measurement data. In your case the low delta E indicates a very good fit.
As you want to create a 3D LUT from the profile, don't install it.
fhoech is offline
post #2270 of 4445 Old 07-05-2014, 05:36 PM
Holiday121's Avatar
Quoted: 476 Post(s)
Liked: 140
Ok this is what happend after I profiled.
Are those numbers ok ?
post #2271 of 4445 Old 07-06-2014, 12:43 AM
sanderdvd's Avatar
Quoted: 162 Post(s)
Liked: 30
thanks or your reply. Question about the input and output decoding option in the 'Create 3D LUT' options: I m using a HTPC with madVR set to 0-255, LAV video filters RGB Output Level set to 'Untouched', AMD Pixel Format set to 'RGB 4:4:4 Pixel Format PC Standard (Full RGB)' and my display device (JVC RS49 projector) set to HDMI 'ENHANCHED'.
In my case, do I have to change the 'input and output decoding' option to 0-255 or just leave it on the default 16-235?
post #2272 of 4445 Old 07-06-2014, 02:02 AM
fhoech's Avatar
Quoted: 408 Post(s)
Liked: 267
No, 16-235 is always the correct setting when creating a madVR 3D LUT. You'll get a warning message if you try to change it to something else.
fhoech is offline
post #2273 of 4445 Old 07-06-2014, 02:03 AM
fhoech's Avatar
Quoted: 408 Post(s)
Liked: 267
DE76 average 0.32 peak 1.52 seems very good.
fhoech is offline
post #2274 of 4445 Old 07-06-2014, 03:05 AM
anidabi's Avatar
Quoted: 42 Post(s)
Forgive me if this sounds bit stupid question, but from the looks of it, this tutorial seems like it´s only software calibration for your projector... am I right?
So if you don´t do the settings straight from your projector CMS, how do you get the best results? I mean, I have calibrated my computer monitor with i1profiler software, and the first time I did the mistake not to adjust manually my monitors brightness to the prefered value(120cm^2) and the end results were that despite corrected colors, my monitor had very low contrast ratio(like 200:1). Then I asked it about in one forum and was wondering that should these monitors have like close to 1000:1 contrast ration and the answer was to manually adjust monitor brightness from the monitor settings to the preferred value in the beginning of the test. I did that and voilá, 950:1 contrast ratio and corrected colors. My monitor does not have any other adjustment options other than brightness.
So my question is, if you calibrate your projector same way only with software and bring down brightness, contrast and all the other values by force, would it not make the same affect as with my monitor? Somehow the end results would not be as goos as if you adjust all the settings straight from you projector?
anidabi is offline
post #2275 of 4445 Old 07-06-2014, 04:50 AM
sanderdvd's Avatar
Quoted: 162 Post(s)
Liked: 30
ok, thanks. And what is the best method to check my results? Just use my Chromapure package for it with my i1 Display 3 Pro meter?
post #2276 of 4445 Old 07-06-2014, 04:59 AM
-Hitman-'s Avatar
Quoted: 134 Post(s)
Liked: 106
Hi,
I'm having a dispread crash problem with dispcal 2.1, when trying to create a colorimeter correction with an i1pro and i1d3, can get to the part that requires the i1pro to be calibrated against it's tile/plate, then the meter is replaced back to the display then after selecting ok/proceed, dispread crashes.
I've looked at the problems reported section on the dispcal web site and placed the madHcNet32.dll within /bin folder but exactly the same occurs, can anyone help me resolve this issue?
Using MadTPG as the pattern generator.
Log output....
Display type ignored - instrument doesn't support display type
Created MadVR window
Place cap on the instrument, or place on a dark surface,
or place on the white calibration reference,
and then hit any key to continue,
dispcalGUI: Waiting for send buffer
dispcalGUI: Sending buffer: ' '
or hit Esc or Q to abort:
Calibration complete
Place instrument on test window.
Hit Esc or Q to give up, any other key to continue:
Measured display update delay of 240 msec, using delay of 460 msec
dispcalGUI: Reached EOF (OK)
dispcalGUI: Checking subprocess status
dispcalGUI: Subprocess no longer alive (OK)
...aborted.
Loading calibration curves from file...
C:\ProgramData\0install.net\implementations\sha1ne w=5b24209f4533a335ae8e788c5711323b6d959489\dispcal GUI\presets\madVR.icc
...ok.
C:\Argyll_V1.6.3
-Hitman- is offline
post #2277 of 4445 Old 07-06-2014, 05:15 AM
3ll3d00d's Avatar
Liked: 535
Here it is:
Take the values from the correction page for the type of display you have and plug them into that spreadsheet I put on my gdrive. If you don't have excel then I imagine OpenOffice can open it. Failing that let me know which display type and I will let you the final values to put into your ti3 file.
post #2278 of 4445 Old 07-06-2014, 05:25 AM
sanderdvd's Avatar
Quoted: 162 Post(s)
Liked: 30
what is your gdrive?
post #2279 of 4445 Old 07-06-2014, 05:37 AM
3ll3d00d's Avatar
Liked: 535
It is linked in this post - MadVR - ArgyllCMS - just follow that step by step basically.
post #2280 of 4445 Old 07-06-2014, 05:55 AM
sanderdvd's Avatar
Quoted: 162 Post(s)
Liked: 30
thanks. Found it. But I don t get it how to complete the excel file. The values I have are:
Field White x
Field White y
Field Red x
Field Red y
Field Green x
Field Green y
Field Blue x
Field Blue y
Reference White x
Reference White y
Reference Red x
Reference Red y
Reference Green x
Reference Green y
Reference Blue x
Reference Blue y
Correction White x
Correction White y
Correction Red x
Correction Red y
Correction Green x
Correction Green y
Correction Blue x
Correction Blue y
It does not make sense to me how to fill in the excel
Reply Display Calibration
