MadVR - ArgyllCMS - Page 78 - AVS Forum | Home Theater Discussions And Reviews
 492Likes
post #2311 of 4618 Old 07-08-2014, 05:05 AM
3ll3d00d's Avatar
Quoted: 1650 Post(s)
Liked: 621
Originally Posted by mightyhuhn View Post
you do and the effect is only for MadVR nothing else that why i ask how did you read that with chromapure?
fwiw I use jriver with ROHQ (madvr) for this with the chromapure pattern disc loaded into my library
3ll3d00d is online now
post #2312 of 4618 Old 07-08-2014, 06:47 AM
sanderdvd's Avatar
Quoted: 169 Post(s)
Liked: 31
@Holiday121: Don t know how to do a measurement report in Discal so I did not do that. Besides this, I trust Chromapure and want to see result in Chromapure (so I can see the result with and without using the 3Dlut file).
@mighthuhn: I understand the result can only be seen/read by Chromapure when using madVR and the created 3Dlut file. I used the beginning post/guide to create the 3Dlut file and loading the 3Dlut file in madVR. The 3Dlut file is loaded and used for sure because you can clearly see the difference in greyscale and gamma in my Chromapure reports (look at my previous post with images from Chromapure WITH and WITHOUT using the 3Dlut file in madVR). I m using the AVS709 test patterns by the way (the 'standalone' mp4 files which can be found here http://www.w6rz.net/avshd709/MP4-2c.exe
sanderdvd is offline
post #2313 of 4618 Old 07-08-2014, 07:02 AM
mightyhuhn's Avatar
Quoted: 772 Post(s)
Liked: 263
ok did chromapure use the same correction you used to created the 3d lut?
and what about the brightness of 45 cm²?
mightyhuhn is offline
post #2314 of 4618 Old 07-08-2014, 07:12 AM
sanderdvd's Avatar
Quoted: 169 Post(s)
Liked: 31
Yes, 99% sure (I ll have to double check with 3ll3d00d who helped me creating the correction file for Dispcal)
?? ?? What you mean with this
post #2315 of 4618 Old 07-08-2014, 07:27 AM
mightyhuhn's Avatar
Quoted: 772 Post(s)
Liked: 263
45 cm² is shown in your first picture.
normally 120 cm² is the norm and 45 cm² is strange at least to me are you using a projector?
i'm never calibrated a projector but i don't think 45 cm² can be normal.
if i would calibrated a projector i would use MadTPG in fullscreen and make sure the room is dark like a deep cave.
if this isn't a projector 45 cm² can't be normal.
for testing use a smaller testchart no need to run 1000+
post #2316 of 4618 Old 07-08-2014, 07:41 AM
sanderdvd's Avatar
Quoted: 169 Post(s)
Liked: 31
ah, now I see what you mean. The reference light for a digital projector in a bat cave is 12-16fL (Foot Lambert). 45cm2 is approx 13fL so perfect for me (I have a complete dedicated pitch-black HT room). I use MadTPG in fullscreen as suggested in the guide in the first post of this thread.
What do I have to change in DispcalGUI in order to get not a FOUR! hour calibration! I will do a four hours calibration in the end but first I need to figure out what going wrong here and for this I will need to run test calibrations I think don t i? Hope you guys can help me on my way. Maybe I can start with NOT using the created correction file to see if this changes anything? I have a feeling something must be wrong with the Dispcal settings. There are so many and I cannot imagine that all the settings I took from the first post (guide in this thread) are also applicable for my setup.
Maybe it is an idea to use the projectors basic (non calibrated) color and gamma settings to see where it goes from there?
post #2317 of 4618 Old 07-08-2014, 07:43 AM
mightyhuhn's Avatar
Quoted: 772 Post(s)
Liked: 263
ok so a wrong positioned meter isn't the issue too.
can you do a fast non corrected calibration and have a look at that?
300 patches or something like that.
post #2318 of 4618 Old 07-08-2014, 07:52 AM
sanderdvd's Avatar
Quoted: 169 Post(s)
Liked: 31
I ll do this tonight and report back at ya asap. Where do I fill in these patches? And with a non-corrected calibration you mean without the meter correction file that I (actually 3ll3d00d made this for me ) created?
post #2319 of 4618 Old 07-08-2014, 08:04 AM
mightyhuhn's Avatar
Quoted: 772 Post(s)
Liked: 263
go to testchart file and chose "default testchart for lut profiles" this testchart has 271 patches.
my knowledge isn't high enough to look at the icm/cal file i'm sorry
post #2320 of 4618 Old 07-08-2014, 09:00 AM
-Hitman-'s Avatar
Quoted: 149 Post(s)
Liked: 108
Originally Posted by fhoech View Post
By "crash" I assume you get a "dispread.exe has stopped working" error dialog box from Windows?
Please run dispread manually from a command prompt with -D9 to get some diagnostic output.
Correct, i'll re-setup my sensors in a bit and report back, thanks!
Originally Posted by 3ll3d00d View Post
OK so I have created the ccxx. I have a JVC D-ILA projector, this requires as DISPLAY_TYPE_REFRESH "YES" right?
Am I right in thinking the only thing left to do is add the extra command line options like the attached pic?
Originally Posted by zoyd View Post
No need to load it via the extra commandline box, the main UI has an option for selecting correction files.
With Regards to .ti3 and ccmx profiling files....
The appropriately labelled reference and colorimeter files (2 x .ti3) are these 2 files loaded in using Dispcal/tools "create colorimeter correction"?
And with regards to an already combined .ccmx file, can this be permanently loaded into dispcal using the "oeminst" command line and so does this then add the ccmx as a selectable option in the "instrument" select drop down list?
-Hitman- is online now
post #2321 of 4618 Old 07-08-2014, 09:19 AM
fhoech's Avatar
Quoted: 430 Post(s)
Liked: 283
Yes.
It will automatically be selectable in dispcalGUI under "Correction" after it has been created, and is also available to dispcal/dispread/spotread directly (via the -y option).
-Hitman- likes this.
fhoech is offline
post #2322 of 4618 Old 07-08-2014, 09:22 AM
-Hitman-'s Avatar
Quoted: 149 Post(s)
Liked: 108
So it will be like this...
oeminst -y "name of file".ccmx
post #2323 of 4618 Old 07-08-2014, 09:24 AM
mightyhuhn's Avatar
Quoted: 772 Post(s)
Liked: 263
yes
post #2324 of 4618 Old 07-08-2014, 10:24 AM
-Hitman-'s Avatar
Quoted: 149 Post(s)
Liked: 108
Please see attached dispread_log as requested.
Ty.
post #2325 of 4618 Old 07-08-2014, 10:37 AM
fhoech's Avatar
Quoted: 430 Post(s)
Liked: 283
There's no need to use oeminst.
fhoech is offline
post #2326 of 4618 Old 07-08-2014, 10:39 AM
fhoech's Avatar
Quoted: 430 Post(s)
Liked: 283
I meant you should use the same commandline, but add -D9 (e.g. before all the other parameters).
fhoech is offline
post #2327 of 4618 Old 07-08-2014, 10:43 AM
sanderdvd's Avatar
Quoted: 169 Post(s)
Liked: 31
Running a profile&calibration with "default testchart for lut profiles" now but takes still so much time. Already running 90 minutes now........
post #2328 of 4618 Old 07-08-2014, 10:45 AM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 158
Can't u just run a profile?
Holiday121 is offline
post #2329 of 4618 Old 07-08-2014, 11:01 AM
sanderdvd's Avatar
Quoted: 169 Post(s)
Liked: 31
What is the difference between profile and profile&calibration? Do i only need Profile for making a 3Dlut for madVR?
post #2330 of 4618 Old 07-08-2014, 11:28 AM
-Hitman-'s Avatar
Quoted: 149 Post(s)
Liked: 108
Yeah, sorry however I have the variables taken from the dispcal log (process of dispread) + -D9 as per below but does not run correctly...
So need some help please to execute a correct command line..
C:\Argyll_V1.6.3\bin>dispread -D9 -v -dmadvr -c1 -yc -H -Iw -K "i1 Pro & madVR.cal" -s "i1 Pro & madVR"
Output....
MonitorEnumProc() called with hMonitor = 0x10001
MonitorEnumProc() set initial monitor info: 0,0 1920,1200 name '\\.\DISPLAY1'
MonitorEnumProc() called with hMonitor = 0x10003
MonitorEnumProc() set initial monitor info: 1920,0 1536,864 name '\\.\DISPLAY2'
get_displays about to get monitor information for 0
Mon 0, name '\\.\DISPLAY1\Monitor0'
Mon 0, string 'Dell 2407WFP (Analog)'
Mon 0, flags 0x3
Mon 0, id 'MONITOR\DELA016\{4d36e96e-e325-11ce-bfc1-08002be10318}\0003'
Mon 0, key '\Registry\Machine\System\CurrentControlSet\Contro l\Class\{4d36e96e-e
EnumDisplayDevices failed on '\\.\DISPLAY1' Mon = 1
get_displays added description 'DISPLAY1, at 0, 0, width 1920, height 1200 (Prim
ary Display)' to display 0
get_displays about to get monitor information for 1
Mon 0, name '\\.\DISPLAY2\Monitor0'
Mon 0, string 'Generic PnP Monitor'
Mon 0, flags 0x3
Mon 0, id 'MONITOR\ONK0891\{4d36e96e-e325-11ce-bfc1-08002be10318}\0004'
EnumDisplayDevices failed on '\\.\DISPLAY2' Mon = 1
get_displays added description 'DISPLAY2, at 1920, 0, width 1536, height 864' to
display 1
icoms_get_paths: called
hid_get_paths: called
found HID device '\\?\hid#{00001124-0000-1000-8000-00805f9b34fb}_vid&0002045e_pi
d&0099&col05#8&3dbedb1&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}', inst 1 bu
t unable get PID and VID
d&0099&col06#8&3dbedb1&0&0005#{4d1e55b2-f16f-11cf-88cb-001111000030}', inst 2 bu
found HID device '\\?\hid#vid_051d&pid_0002#6&6dcd398&0&0000#{4d1e5 5b2-f16f-11cf
-88cb-001111000030}', inst 3 but not one we're looking for
d&0098&col01#9&31b28b77&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}', inst 4 b
ut unable get PID and VID
d&0099&col01#8&3dbedb1&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}', inst 5 bu
d&0098&col02#9&31b28b77&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}', inst 6 b
d&0099&col07#8&3dbedb1&0&0006#{4d1e55b2-f16f-11cf-88cb-001111000030}', inst 7 bu
d&0098&col03#9&31b28b77&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}', inst 8 b
d&0099&col02#8&3dbedb1&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}', inst 9 bu
d&0099&col03#8&3dbedb1&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}', inst 10 b
d&0099&col04#8&3dbedb1&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}', inst 11 b
icoms_get_paths: returning 0 paths and ICOM_OK
usb_get_paths opening device '\\.\libusb0-0001'
usb_get_paths: turned on kernel debug messages
usb_get_paths: checking vid 0x0971, pid 0x2000
set ep ad 0x1 packetsize 64 type 2
set ep ad 0x82 packetsize 64 type 2
set ep ad 0x3 packetsize 32 type 2
set ep ad 0x84 packetsize 8 type 3
usb_get_paths: found instrument vid 0x0971, pid 0x2000
usb_get_paths opening device '\\.\libusb0-0002'
usb_get_paths opening device '\\.\libusb0-0003'
usb_get_paths opening device '\\.\libusb0-0004'
usb_get_paths opening device '\\.\libusb0-0005'
usb_get_paths opening device '\\.\libusb0-0006'
usb_get_paths opening device '\\.\libusb0-0007'
usb_get_paths opening device '\\.\libusb0-0008'
usb_get_paths opening device '\\.\libusb0-0009'
usb_get_paths opening device '\\.\libusb0-0010'
usb_get_paths opening device '\\.\libusb0-0011'
usb_get_paths opening device '\\.\libusb0-0012'
usb_get_paths opening device '\\.\libusb0-0013'
usb_get_paths opening device '\\.\libusb0-0014'
usb_get_paths opening device '\\.\libusb0-0015'
usb_get_paths opening device '\\.\libusb0-0016'
icoms_get_paths: got 1 paths, looking up the registry for serial ports
icoms_get_paths: looking through FTDI ports
icoms_get_paths: looking through 'VID_0403+PID_6010+5&36488fa&0&12&1'
icoms_get_paths: got FTDI port 'COM8'
icoms_get_paths: got ERROR_NO_MORE_ITEMS
icoms_get_paths: looking through 'VID_0403+PID_6010+5&36488fa&0&12&2'
icoms_get_paths: got FTDI port 'COM9'
icoms_get_paths: looking through 'VID_0403+PID_6010+5&36488fa&0&3&1'
icoms_get_paths: got FTDI port 'COM10'
icoms_get_paths: looking through 'VID_0403+PID_6010+5&36488fa&0&3&2'
icoms_get_paths: got FTDI port 'COM11'
icoms_get_paths: looking through 'VID_0403+PID_6010+6&2cd789d4&0&3&1'
icoms_get_paths: got FTDI port 'COM6'
icoms_get_paths: looking through 'VID_0403+PID_6010+6&2cd789d4&0&3&2'
icoms_get_paths: got FTDI port 'COM7'
icoms_get_paths: looking through all the values in the SERIALCOMM key
icoms_get_paths: Added path 'COM5' fast 0
icoms_get_paths: we now have 2 entries and are about to sort them
icoms_get_paths: returning 2 paths and ICOM_OK
dispread: Error - CGATS file read error : Unable to open file 'i1 Pro & madVR.ti
1' for reading
post #2331 of 4618 Old 07-08-2014, 11:33 AM
-Hitman-'s Avatar
Quoted: 149 Post(s)
Liked: 108
Thanks, figured it out
Could you please explain the -y variable implementation, eg. where does it get added in DispcalGUI and is it necessary if the ccmx profile has already been selected in "correction"?
post #2332 of 4618 Old 07-08-2014, 12:07 PM
dansrfe's Avatar
Liked: 0
How big should the video area be approximately for a plasma TV, edge-lit LED, and full-array LED backlight TVs on madtpg? Thanks!
dansrfe is offline
post #2333 of 4618 Old 07-08-2014, 12:52 PM
3ll3d00d's Avatar
Liked: 621
FWIW the advice I was given was for generating a 3D LUT was not to treat it as a normal calibration, instead it was briefly stated as
find the gamut that is the largest
set gamma to the most accurate but if it's non linear then use preset that makes it 2.1 rather than 2.3 at low end
do greyscale at 100percent stimulus only... leave bias at defaults, just adjust gains
i.e. get white right, give the LUT as much room to work in as possible and then leave it to it.
My attempts at generating a 3D LUT, also with a JVC projector albeit an X3, suggest that the end result is heavily influenced by the starting point, i.e. what state the projector is in. The ccxx differences were quite minor in comparison. Of course bear in mind that I still don't have a result I would call excellent so what do I know!?
post #2334 of 4618 Old 07-08-2014, 01:07 PM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 158
Interesting. Sounds like a learning curve in this as well it's just not follow the guide and get excellent results.
Have you tried calibrating your projector fully without the 3dlut? If so what were the results?
I just finished my JVC rs46.
I'm sure it's not dead perfect but pretty good for a beginner
post #2335 of 4618 Old 07-08-2014, 02:28 PM
3ll3d00d's Avatar
Liked: 621
I did a pretty good job with greyscale/gamma, not so good with managing colour which seemed like a game of whack-a-mole (my projector doesn't have a CMS & I don't really know what I'm doing on that front).
post #2336 of 4618 Old 07-08-2014, 02:52 PM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 158
Did you run the 92 patch? What was ur average?
post #2337 of 4618 Old 07-08-2014, 03:06 PM
3ll3d00d's Avatar
Liked: 621
0.46
I posted a link to that report in MadVR - ArgyllCMS
colour looks good to my eyes in brighter conditions, where I've struggled is with the low levels (blacks crushed and/or colours badly skewed at low light levels)
post #2338 of 4618 Old 07-08-2014, 03:13 PM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 158
Hmmmm that's real low .
I was told you probably wouldn't even see a difference at fixing that.
Your 6500k line is straight any everything?
In the hcfr forum I posted my last 2 calibrations in files . Take a look .
post #2339 of 4618 Old 07-08-2014, 03:21 PM
3ll3d00d's Avatar
Liked: 621
Right so it measures well but looks wrong in various scenes.
post #2340 of 4618 Old 07-08-2014, 03:38 PM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 158
Hmmmm I guess I don't know what to look for. Give me a example
Reply Display Calibration
