MadVR - ArgyllCMS - Page 83 - AVS Forum | Home Theater Discussions And Reviews
 500Likes
post #2461 of 4653 Old 07-14-2014, 09:10 AM
mightyhuhn's Avatar
Quoted: 779 Post(s)
Liked: 265
this is the result with 3D lut in MadPTG ?
mightyhuhn is online now
post #2462 of 4653 Old 07-14-2014, 09:20 AM
jaimemlg's Avatar
Could you make a screenshot with the best setting configuration for dispalgui with rec709 and 2.2 gamma?
jaimemlg is offline
post #2463 of 4653 Old 07-14-2014, 09:23 AM
splotten's Avatar
Quoted: 290 Post(s)
Liked: 138
I believe so. I first load the 3Dlut into madvr and enable "calibrate this display by using external 3Dlut files" before opening MadTGP. I then assume that the 3Dlut is then used in MadTGP as long as i dont disable the 3Dlut in MadTGPs setting (see screen shot in previous post).
splotten is offline
post #2464 of 4653 Old 07-14-2014, 12:56 PM
Liked: 0
@splotten : Make sure that in madTPG.exe, the button "disable videoLUT" is activated, but do not activate "disable 3dLUT".
EDIT
Oh ... that's what you did. Silly me.
EDIT no. 2
Try the "verify_video_extended.ti1" testchart.
Stillbruch is offline
post #2465 of 4653 Old 07-14-2014, 01:08 PM
Liked: 0
Follow the instructions like in post 1, but:
- Tone Curve: Gamma 2.2
- Select Black point compensation under profiling settings.
- (Don't know if this is necessary, but I did it like this) For the testchart, use the same settings as suggested in post 1, but select Rec709_Gamma22.icm as preconditioning profile.
- When you create the 3D LUT, do as suggested in post 1, but select Rec709_Gamma22.icm as source profile and do not select Apply BT.1886 gamma mapping (it automatically disables itself anyway in this case).
@splotten : Your measurement report doesn't look so good. Either something went wrong or your display is kind of mediocre. Mine looks like this (Gamma 2.35, BPC), and the display (Samsung UE40F6510) isn't that impressive: http://pastebin.com/download.php?i=LYYcTtjU
post #2466 of 4653 Old 07-14-2014, 02:38 PM
splotten's Avatar
Quoted: 290 Post(s)
Liked: 138
I know. It was exactly that "something" I was looking for.
splotten is offline
post #2467 of 4653 Old 07-14-2014, 03:25 PM
-Hitman-'s Avatar
Quoted: 166 Post(s)
Liked: 121
I'd put my money on the "something " to be your meter, 3 years old is way to long for a d2 it will have drifted somewhat and your not just doing greyscale in a 3d lut, get an I1D3
-Hitman- is offline
post #2468 of 4653 Old 07-14-2014, 04:29 PM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
Inaccuracy in the meter won't give you a bad verification report, it will just give you a bad visual result.
Fiddling with the MadTPG buttons will though - you shouldn't normally have to touch "disable VideoLuts" or "disable 3dlut", since ArgyllCMS will set them appropriately when it's using MadTPG as the patch display source.
gwgill is offline
post #2469 of 4653 Old 07-14-2014, 06:43 PM
nw06's Avatar
inconsistent black reading
Admittedly, it has been a while since I looked at this, but when I was trying to trouble shoot the raised black levels generated by the 3dlut, I noticed that my black level readings in the log seemed to be very inconsistent. One reading would be correct at 0.003cdm2 (Panasonic VT60), while others would vary wildly and up to 0.15 cdm2. This surely would contribute to the less than optimal result I was seeing.
I am using an i1DisplayPro, so it's reading ability and repeatability should not be the issue.
I presume the preceding lighter patch readings are contaminating the black patch readings? Is there any way I can specify the correct black level manually? Or can I fiddle with the patch reading intervals/order somehow to avoid the contamination between patches?
nw06 is offline
post #2470 of 4653 Old 07-14-2014, 11:41 PM
sillysally's Avatar
Quoted: 1015 Post(s)
Liked: 952
I wouldn't rule out your meter, or not using a long enough delay.
Also how you do your pre calibration for your VT60 may also be part of you problem.
Last night I did two meter profiles using ChromaSurf for profiling the K10-A to the Jeti 1211, and then inputting my new profiles into the K10's internal memory. Also check the data reports on the two profiles to see witch profile I thought was better.
Using my VT60 that my meters where profiled off of.
Using Argyll and gwgill's posted manual fix (script), ran a custom made 9405 point patch set using the tools in Argyll to make the patch set.
I used BT.1886 2.4 to make this 3DLUT.
The black level, this time came out exactly were I expected it to.
You can use this measurement report to compare with yours.
PM me if you need some suggestion's on how I set up my VT60
Click on the link, download the 493 point measurement report, open it with your browser (Internet explorer, Google, ect).
http://s000.tinyupload.com/index.php...76933772578342
ss
ps, Ted. As I usual do when I run a profile, used ChromaSurf to do a black level calibration on my K10. So as It turns out not having Argyll or CM do a black level calibration had nothing to do with my slight black level issue that is fixxed now.
ConnecTEDDD likes this.
"Don't worry be happy"
For Sale Lumagen Radiance Pro 4440/2, see link for details
http://www.avsforum.com/forum/210-vi...l#post54911046
sillysally is offline
post #2471 of 4653 Old 07-15-2014, 08:57 AM
jaimemlg's Avatar
What relationship between brightness and contrast must be set prior to the BT1886 and gamma 2.4? and for gamma 2.2?
jaimemlg is offline
post #2472 of 4653 Old 07-15-2014, 10:22 AM
splotten's Avatar
Quoted: 290 Post(s)
Liked: 138
That was my thinking as well. A bad meter cant detect its own errors. However it can produce a bad calibration. I cant rule out that it is in fact the meter, but i still think its strange that i get such a bad result in the verification when its verified with the same meter. That sounds like something else might be going on as well.
I will once again redo the calibration and profile withe the revised settings and post the result here :-)
splotten is offline
post #2473 of 4653 Old 07-15-2014, 12:59 PM
baii's Avatar
Quoted: 25 Post(s)
hunt for a DTP-94 as a check, they can be find cheap and do wonder on srgb displays.
I have one dated 06 when I brought it 2 years ago?, still matches the result in validation reports (done using a colormunki display). ofc YMMV.
baii is offline
post #2474 of 4653 Old 07-15-2014, 02:04 PM
-Hitman-'s Avatar
Quoted: 166 Post(s)
Liked: 121
ss
Wow ss, think you've got the most accurate VT on the planet there, good work that man
sillysally likes this.
-Hitman- is offline
post #2475 of 4653 Old 07-15-2014, 05:48 PM
gwgill's Avatar
Quoted: 261 Post(s)
Liked: 196
.. but i still think its strange that i get such a bad result in the verification when its verified with the same meter. That sounds like something else might be going on as well.
That's the point of verification, to confirm that the process itself is working. A bad verification indicates that it is not. Either the profile is not being created properly, or the resulting 3dLUT is not being applied properly.
gwgill is offline
post #2476 of 4653 Old 07-15-2014, 07:22 PM
sillysally's Avatar
Liked: 952
Same as you would set your Contrast and Brightness for a normal calibration. That also would apply to how you set your pre calibration setting in your display.
You don't want to crush blacks or clip whites.
ss
post #2477 of 4653 Old 07-15-2014, 09:27 PM
|Tch0rT|'s Avatar
Quoted: 186 Post(s)
Liked: 130
When you refer to the patch set is that another name for the testchart in dispcalGUI? Can you post your patch set for us to use too? How long does it take (I know PC & meter speeds will make this different for everyone)?
My Home Theater/Video Gaming/HTPC/2 Channel rig (Mitsubishi, MartinLogan, Marantz, DIYMA, and others)
|Tch0rT| is offline
post #2478 of 4653 Old 07-16-2014, 03:13 AM
sillysally's Avatar
Liked: 952
It takes me about 4 hours 30 min to run. I use madTPG for my patch generator and a K10-A for my meter.
I run this when I go to bed.
ss
Name:	9405 Testchaart-patchset.jpg
|Tch0rT| likes this.
post #2479 of 4653 Old 07-16-2014, 03:49 AM
|Tch0rT|'s Avatar
Quoted: 186 Post(s)
Liked: 130
ss
Thanks again! I'm afraid to find out how long that will take to run with my i1Display Pro... the testchart in the 1st post took about 2 hours 30 min last time I ran it but I accidentally clicked on Calibrate & Profile instead of just Profile.
|Tch0rT| is offline
post #2480 of 4653 Old 07-19-2014, 10:31 PM
sillysally's Avatar
Liked: 952
dispcalGUI has been updated to 2.1.0.9
ss
post #2481 of 4653 Old 07-20-2014, 02:03 AM
ACappo's Avatar
Quoted: 47 Post(s)
Liked: 45
hmm when trying to update via zero install it sayI got latest version 2.1.0.0?
ACappo is offline
post #2482 of 4653 Old 07-20-2014, 02:28 AM
Liked: 0
Probably means, there is new source code: http://sourceforge.net/projects/disp...iles/snapshot/.
post #2483 of 4653 Old 07-20-2014, 02:57 AM
fhoech's Avatar
Quoted: 432 Post(s)
Liked: 283
Yes, only the development snapshot has been updated (see Getting the latest development snapshot via Zero Install), changelog as always in the ReadMe. Most changes from the previous snapshot (2.1.0.8) were under the hood, with the exception of added support for Argyll 1.7 development features (optional output offset instead of "pure" BT.1886, and forced RGB black point hack) and a bugfix for ambient measurements with instruments that only have monochrome ambient sensors (Spyder 3 and 4 Elite/Pro).
fhoech is online now
post #2484 of 4653 Old 07-20-2014, 03:43 AM
-Hitman-'s Avatar
Quoted: 166 Post(s)
Liked: 121
Hi,
Where can I find detailed information on the "edit testchart" options, can't seem to find the info on the general dispcalgui web page?
+ when creating a custom synthetic .icm, I want to create one for pL 2.25, I load the rec709 RGB to populate the settings and select gamma but the gamma dropdown only lists 2.2, 2.35, 2.4 etc..., do I just choose 2.2 and manually type/add a 5 at the end (eg.2.25) and ok to leave white and black level at defaults or change to actual measured data?
-Hitman- is offline
post #2485 of 4653 Old 07-20-2014, 05:20 AM
fhoech's Avatar
Quoted: 432 Post(s)
Liked: 283
The testchart editor isn't fully documented, but you can find some information under Profiling settings. For more, refer to the Argyll CMS "targen" documentation (most of the testchart editor options have a corresponding targen parameter).
Yes, you can just type in any gamma value you like. Note that "absolute"/"relative" doesn't work for synthetic profiles in dispcalGUI 2.1.0.0 when not using Rec. 1886 (it's always absolute), this is fixed in the 2.1.0.9 snapshot. Black level always influences the curve offset, white level only influences the curve shape if using DICOM.
post #2486 of 4653 Old 07-21-2014, 04:19 PM
renji1337's Avatar
Quoted: 70 Post(s)
I currently calibrate my PC monitors with my spyder4 with dipscalgui, could I do the same and calibrate my HDTV I use for blurays on my HTPC?
renji1337 is offline
post #2487 of 4653 Old 07-21-2014, 05:34 PM
Stereodude's Avatar
Quoted: 3454 Post(s)
Liked: 2526
Yes, but you'd probably want to start with HCFR to dial in the various hardware settings on your TV first.
Stereodude is online now
post #2488 of 4653 Old 07-21-2014, 05:46 PM
renji1337's Avatar
Quoted: 70 Post(s)
^how do I do this? and would the TV look good with just HCFR?
Also is HCFR a program I have to download or just a guide? I've never calibrated a TV before, just PC monitors which is super easy with dipscalgui
post #2489 of 4653 Old 07-22-2014, 11:21 AM
Aryn Ravenlocke's Avatar
Quoted: 351 Post(s)
Liked: 134
MadVR - I keep seeing everywhere how this is the way to go to get the very best in picture quality out of my HTPC. But I download it, open it up, and have no clue what I am looking at.
It is a feature of MB Theater I am looking forward to though, even if I do need to go back to university to learn how to use it.
Aryn Ravenlocke is offline
post #2490 of 4653 Old 07-22-2014, 11:34 AM
-Hitman-'s Avatar
Quoted: 166 Post(s)
Liked: 121
Yes you can but you will need an external box to hold the 3D Lut you create with dispcal, like an EEcolor box see here....
eeColor processor - ArgyllCMS
Yes it's free calibration software you download and use a sensor to take readings from the display, see here...
HCFR - Open source projector and display calibration software
Madvr is a high quality video renderer/codec you install, for use with MPC-HC or any other video player that supports it, have a look here for more info...
http://forum.doom9.org/showthread.php?t=146228
-Hitman- is offline
Reply Display Calibration
