MadVR - ArgyllCMS - Page 84 - AVS Forum | Home Theater Discussions And Reviews
 488Likes
post #2491 of 4587 Old 07-22-2014, 05:51 PM
|Tch0rT|'s Avatar
Quoted: 185 Post(s)
Liked: 128
Originally Posted by -Hitman- View Post
Yes you can but you will need an external box to hold the 3D Lut you create with dispcal, like an EEcolor box see here....
eeColor processor - ArgyllCMS
The whole point of this thread is to create a 3DLUT with ArgyllCMS + dispcalGUI and use madVR to apply the created 3DLUT instead of buying an eeColor box...
My Home Theater/Video Gaming/HTPC/2 Channel rig (Mitsubishi, MartinLogan, Marantz, DIYMA, and others)
|Tch0rT| is offline
post #2492 of 4587 Old 07-22-2014, 07:10 PM
Sunset1982's Avatar
Quoted: 48 Post(s)
I've got a HTPC and a LG OLED TV. Tomorrow i want to calibrate this setup with madvr & discalgui, because the 21point kalibration through my tv menu has a firmware bug that makes a good calibration impossible. I want to calibrate to rec.709 and gamma 2.3. what settings should i change from the #1 post to do so? What setting should i use on my tv? (2.2 or 2.4 are possible)
Can I use a testchartfile optimzed for gamma 2.2 and rec 709? or which one should i choose?
Sunset1982 is offline
post #2493 of 4587 Old 07-23-2014, 02:14 AM
-Hitman-'s Avatar
Quoted: 134 Post(s)
Liked: 106
Just stipulating another option, a lot of users/posters on this thread use the ee box for the 3d lut, not just MadVR.
-Hitman- is offline
post #2494 of 4587 Old 07-24-2014, 02:43 PM
LucaT's Avatar
Quoted: 63 Post(s)
Hello guys,
I have the xrite's "i1-displayPro" and Panasonic 60ZT60 and Of course the PC, I tried to follow instructions on the first post but it doesn't work on my PC, the dispcalGUI's "calibration & profile creation" when I start immediately show me error and stop.
I don't know what I do wrong.
And about the MadVR test pattern: I didn't understand well what should I do with it, I open it, select the two button as from instruction and then?
It doesn't show to me any "start" or other!?
Thanks a lot
LucaT is offline
post #2495 of 4587 Old 07-24-2014, 03:30 PM
mightyhuhn's Avatar
Quoted: 748 Post(s)
Liked: 256
first post the error.
you need to open the madTPG first and then start calibration & profiling.
mightyhuhn is offline
post #2496 of 4587 Old 07-24-2014, 03:30 PM
Liked: 0
Originally Posted by LucaT View Post
Hello guys,
Thanks a lot
What's the error message? Did you open madTPG.exe?
Stillbruch is offline
post #2497 of 4587 Old 07-24-2014, 03:33 PM
LucaT's Avatar
Quoted: 63 Post(s)
Thanks for replies guys
I'll post the error as soon as possible
About madTPG:
Should I just let MadTPG open without do anything? and then open DispcalGUI and start calibration & profiling?
My bad, what a stupid!
Sorry guys
LucaT is offline
post #2498 of 4587 Old 07-24-2014, 04:52 PM
LucaT's Avatar
Quoted: 63 Post(s)
Which difference are there between:
Disable or not
- Black point compensation
- Smooth B2A tables
- Low quality B2A tables.
LucaT is offline
post #2499 of 4587 Old 07-25-2014, 04:50 AM
LucaT's Avatar
Quoted: 63 Post(s)
"Error - display read failed with 'Window Access Failed' "
This error showed after about 1hour
LucaT is offline
post #2500 of 4587 Old 07-25-2014, 09:52 AM
-Hitman-'s Avatar
Quoted: 134 Post(s)
Liked: 106
Hi,
Just want to report an small issue I've encountered with dispcal and MadTPG as the pattern source, so probably for Madshi.
In a dual monitor (primary and extended) setup I have MadTPG minimised to taskbar, so I can use an unattended calibration overnight (as to not create IR from the TPG minimised window boarder left after dispcal process completion)and the madtpg window returns minimised to taskbar when process is finished.
I start MadTPG and drag the minimised (small) window on to the extended desktop and minimise it to the taskbar, then start dispcal profile routine, which brings up MadTPG fullscreen as expected but if I encounter a problem and stop dispcal process (madTPG returns to task bar as it should) but when I start dispcal again the MadTPG goes full screen on the primary monitor and not back to the extended display, same with when dispcal has completed the profile, I create a lut and then run a measurement report, starting a dispcal process but again the madtpg goes full screen/patterns are on the wrong primary screen.
Could this be fixed as i'm having to restart MadTPG after every dispcal process?
-Hitman- is offline
post #2501 of 4587 Old 07-25-2014, 01:19 PM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
- Smooth B2A tables
Already answered. If you look at the top, you'll see a "Search this thread" option. If you click "Advanced search" and enter the respective keywords and my username, it should be pretty easy to find the relevant posts
fhoech is offline
post #2502 of 4587 Old 07-25-2014, 01:33 PM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
Hmm, that's odd. If dispcal/dispread can't get a connection to madTPG, then this usually means you can't even start measurements. Does this happen while measurements are running, or after calibration (if you used calibration)?
fhoech is offline
post #2503 of 4587 Old 07-25-2014, 01:35 PM
LucaT's Avatar
Quoted: 63 Post(s)
I read but I don't understand what exactly are those option.
And about using the "low quality B2A" then is greyed at 33X33X33 without possibility to choose
LucaT is offline
post #2504 of 4587 Old 07-25-2014, 01:37 PM
LucaT's Avatar
Quoted: 63 Post(s)
I don't know exactly when because I clicked "Calibration and Profiling" and let it there working without watching.
LucaT is offline
post #2505 of 4587 Old 07-25-2014, 01:45 PM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
The short answer is just use the settings recommended on the first page on this thread. For more details on those options, see the dispcalGUI development snapshot documentation (note that "Smooth B2A tables" doesn't apply to 3D LUTs).
Ok, I guess this happened when it started the profiling measurements after calibration (which is still odd because I would have expected that you could not even have started calibration). Was madTPG still running when you noticed the error?
In any case, you should be able to continue where you left off. Under "Settings", the very last entry should be the calibration file that was created. Select it (should already be if you haven't changed anything) and click "Profile only". When asked "The calibration file XXX.cal will be used. Continue?" click "Continue".
fhoech is offline
post #2506 of 4587 Old 07-25-2014, 02:59 PM
LucaT's Avatar
Quoted: 63 Post(s)
Enabling a 3dlut that I did ( but I don't know with which options because it was just one of first try) the movie's Image results quite darker than disabling the 3DLut
LucaT is offline
post #2507 of 4587 Old 07-25-2014, 03:01 PM
LucaT's Avatar
Quoted: 63 Post(s)
I will try!
Anyway if the "smooth B2A table" doesn't apply to the 3DLut why Can I choose for the 3DLut 65X65X65 only if I enable it?
LucaT is offline
post #2508 of 4587 Old 07-26-2014, 03:47 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
All the 3D LUT settings are in a separate window.
fhoech is offline
post #2509 of 4587 Old 07-26-2014, 05:02 AM
LucaT's Avatar
Quoted: 63 Post(s)
So what is that setting? Isn't it refered to the 3DLut?
What is it about?
LucaT is offline
post #2510 of 4587 Old 07-26-2014, 05:18 AM
fhoech's Avatar
Quoted: 424 Post(s)
Liked: 280
See the documentation I linked above.
No.
fhoech is offline
post #2511 of 4587 Old 07-31-2014, 12:15 PM
Sunset1982's Avatar
Quoted: 48 Post(s)
Hi Guys!
What Gamma target should I use when calibrating my LG OLED TV? Power 2.2 or `rec.1886? What should be the better deal?
if rec 1886, absolute or relative?
if i create the 3dlut, is the right output encoding TV RGB 16-235 even if madvr is set to 0-255?
post #2512 of 4587 Old 07-31-2014, 01:33 PM
mightyhuhn's Avatar
Quoted: 748 Post(s)
Liked: 256
Originally Posted by Sunset1982 View Post
Hi Guys!
this guide is about bt 1886 and with perfect black it should result in 2.4 with what you usual want.
and leave the 3d lut at 16-235 this is working as intended.
post #2513 of 4587 Old 07-31-2014, 06:45 PM
gwgill's Avatar
Quoted: 250 Post(s)
Liked: 186
Start with BT.1886 (== 2.4 power), and then adjust it to suite your viewing conditions.
gwgill is offline
post #2514 of 4587 Old 08-01-2014, 11:18 AM
Sunset1982's Avatar
Quoted: 48 Post(s)
Ok, I used the settings from the first post with these results.
What should i do about the bad 5% grey part?
What settings could I use to put the RGB Lines more on a line?
Name:	calibrated gamma.JPG
ID:	191689   Click image for larger version
post #2515 of 4587 Old 08-11-2014, 05:55 AM
IceB's Avatar
Today I have decided to re-calibrate the settings on my JVC X-30 projector since the bulb has passed 1K hours.
The ColorHCFR measures have passed smooth and after a while my new 2.22 Gamma calibration was achieved.
However I am unable to process the 3DLUT for the madVR.
Processing the settings according the guide on the first page on some moment I get the same error LucaT has mentioned :
"Error - display read failed with "Window Access Failed" "
I have disabled the antivirus software (just in case) and disabled any power saving in Windows and processed the "Calibrate & Profile" again.
Again, at some point toward the end of the 48 chart measures - same error. Clicking OK brings the unwelcome : "Calibration has not been finished.".
I think that the measurements are not accomplished, therefore there is no new settings label ready yet to proceed with the profiling.
Using the meter DTP-94.
Any workaround thoughts ?
IceB is offline
post #2516 of 4587 Old 08-11-2014, 04:49 PM
gwgill's Avatar
Quoted: 250 Post(s)
Liked: 186
No-one is in a better position to figure out why it isn't working than you, because you have full access to the problem. Everyone else has to wildly guess from a great distance.
You don't say whether you are running the ArgyllCMS tools manually, or using DispcalGUI.
You don't really say what pattern generator you are trying to use. MadTPG ?
If so, what happens when you start MadTPG ?
What happens when you then run "dispwin -D7 -dmadvr" ?
etc. etc.
gwgill is offline
post #2517 of 4587 Old 08-11-2014, 05:06 PM
IceB's Avatar
Originally Posted by gwgill View Post
No-one is in a better position to figure out why it isn't working than you...
I agree.
Yet I am confused and could not solve it yet. Moreover, since another user - LucaT - had probably a similar experience I believe it is better to share mine as well.
No details mentioned regarding the process, since as I have wrote, I was following the first page guide with no personal changes.
I have figured out that my DispcalGUI version is 2.1.0.0.
There are updated snapshots on the web at the moment.
I will try again with the latest version.
Yet again, 2 users with exact same error while others had no such issues. Hopefully this will be resolved.
IceB is offline
post #2518 of 4587 Old 08-11-2014, 05:47 PM
gwgill's Avatar
Quoted: 250 Post(s)
Liked: 186
I doubt it will get resolved while those who are experiencing it, refuse to investigate it.
gwgill is offline
post #2519 of 4587 Old 08-12-2014, 01:25 AM
madshi's Avatar
Quoted: 531 Post(s)
Liked: 490
@IceB , do you have madVR installed, or are you just using it as part of e.g. J.River MC? If you have it installed, did you start madTPG before you started DispcalGUI? Finally, did you start madTPG and DispcalGUI on the same PC?
madshi is offline
post #2520 of 4587 Old 08-12-2014, 09:00 AM
-Hitman-'s Avatar
Quoted: 134 Post(s)
Liked: 106
@madshi
Any idea's with the below report as still troublesome and keep having to restart MadTPG every time before a dispcal run to get it to display on the correct monitor?
Hi,
-Hitman- is offline
Reply Display Calibration
