MadVR - ArgyllCMS - Page 95 - AVS Forum
 60Likes
post #2821 of 2835 Old 11-04-2014, 04:58 PM
fhoech's Avatar
Quoted: 64 Post(s)
Liked: 50
Originally Posted by baii View Post
When using measurement report for 3dlut in dispcalgui, my experience is that the 3dlut need to be allowed in madtpg(the button) to work correctly.
I ran into this issue too with an older madVR version, just enabling the "Enable madVR 3D LUT" checkbox in dispcalGUI (equivalent of dispread -V) wasn't enough, but I'm not sure this is still true for the current madVR.
fhoech is offline
post #2822 of 2835 Old 11-05-2014, 01:53 AM
madshi's Avatar
Quoted: 69 Post(s)
Liked: 132
Originally Posted by zoyd View Post
The Argyll delay is already at it's minimum (100 ms) based on it's own measurement of display update delay. Typically when it uses the video card directly the delay is 350 ms but when using madTPG it's 850 ms so the extra 1/2 second adds about 16 minutes on to a 2000 patch run. Not a huge deal but it would be nice to trim that down if possible.
Do you happen to use FSE mode with a large number of pre-presented frames? That's good for video playback, but probably not good for madTPG, cause it will increase the delay. Let's say you've configured madVR to present 12 frames in advance at 24Hz. That means if you switch test patterns, madVR first has to wait 1000/24 * 12 = 500ms before a new test pattern reaches the display. Unfortunately Direct3D doesn't allow madVR to abort already presented frames.
Maybe it would make sense to auto-reduce the madVR settings for madTPG to reduce the lag? E.g. I could dial down all settings automatically so that a max of 4 pre-presented frames is used. What do you think?
Hmmmm... Normally madTPG is supposed to do what the calibration software asks for. However, madTPG also remembers the last button states selected by the user. So if the user did disable the madVR 3dlut the last time madTPG was started, the 3dlut will stay disabled in madTPG until the user toggles that button. Is that the problem you're talking about? Currently the madTPG API only allows the calibration software to explicitely *disable* the 3dlut. The calibration software currently can't unpress the "disable 3dlut" button, if the user pressed it. Maybe that's needed, too?
I have on my to do list to update the API to allow loading of a specific 3dlut file into madTPG/madVR. That would allow the calibration software to auto-create and auto-test the 3dlut, without the user having to do anything.
Any other wishes for new/modified APIs, anyone?
madshi is online now
post #2823 of 2835 Old 11-05-2014, 03:00 AM
-Hitman-'s Avatar
Quoted: 46 Post(s)
Liked: 65
@madshi
non api but would ask if it would be possible to add an extra toggle in the "pattern background" setting to temporarily remove the black border around the window pattern?
So that madtpg can be used as an after calibration IR washer by inverting the normal pattern display (0 % grey background + pattern into 100% white background + 0% white pattern without black boarder).
Also when calibration is complete, madvr returns what looks like ~30% pattern, if this could be changed to 0% - so the whole screen becomes black because when unattended calibrations are made and it is some time before returning, having the 30% pattern showing for some time is adding IR to the display, so this would be a big help in stopping this and if left for a long time, I would think could lead to some image burn.
-Hitman- is offline
post #2824 of 2835 Old 11-05-2014, 04:31 AM
zoyd's Avatar
Quoted: 389 Post(s)
Liked: 414
Sounds good, I do use FSE usually with 10-12 frames in advance but at 60Hz.
Allow the driving software to turn on/off the OSD and set APL parameters would be nice (with finer gradations in window size and APL level, say 1%).
zoyd is offline
post #2825 of 2835 Old 11-05-2014, 06:31 AM
fhoech's Avatar
Quoted: 64 Post(s)
Liked: 50
Yes that seems to be it.
fhoech is offline
post #2826 of 2835 Old 11-05-2014, 08:11 AM
baii's Avatar
So the consent is to leave the button on, and clear gpu lut before calibrating/profiling?
If so, may try to get N3W813 to update the first post.
baii is online now
post #2827 of 2835 Old 11-07-2014, 04:58 AM
bsod's Avatar
Liked: 0
Black/dimmable buttons and window borders would be nice for madtpg or some "fake-fulscreen" option, to hide everything accept the dispcalgui status.
bsod is offline
post #2828 of 2835 Old 11-07-2014, 12:30 PM - Thread Starter
N3W813's Avatar
Liked: 35
I will soon. I haven't done any type of calibration for close to an year now. With all the changes, it may take a while before I update the first post.
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is offline
post #2829 of 2835 Old 11-09-2014, 06:31 AM
gwgill's Avatar
Quoted: 100 Post(s)
Liked: 88
This is certainly NOT recommended (see the ArgyllCMS tutorial). Leave the buttons alone (ie. don't override), and let ArgyllCMS manage the VideoLUT and 3DLut state during calibration and profiling.
gwgill is offline
post #2830 of 2835 Old 11-11-2014, 01:20 AM
Evanesco's Avatar
Quoted: 31 Post(s)
Quick question.
How do I make small window patches in the Madvr screen, like on the AVS709 disc? I have a plasma tv, and I want to calibrate it for MadVR.
YAMAHA RX-A2040 9.2 DOLBY ATMOS Networked Receiver
ROTEL RB-1572 Ext AMP
DALI MENTOR 6 FRONTS, DALI IKON VOCAL 2 CENTER, DALI IKON ON-WALL REAR
PANASONIC TX-P50VT30E PLASMA TV
POPCORN HOUR A210 Mediaplayer(streamer)
SYNOLOGY DISKSTATION NAS DS413
Evanesco is offline
post #2831 of 2835 Old 11-11-2014, 01:47 AM
-Hitman-'s Avatar
Quoted: 46 Post(s)
Liked: 65
Originally Posted by Evanesco View Post
Quick question.
Use the slider at the top of the M-TPG window, under "image area" to resize the pattern window.
-Hitman- is offline
post #2832 of 2835 Old 11-11-2014, 01:49 AM
Quoted: 63 Post(s)
I accidentally canceled a calibration early by mistake and now i cant calibrate anymore. I uninstalled, cleaned everything off and re-installed same problem anyone got any fixes? Log file:
2014-11-10 22:45:58,039 Command line:
2014-11-10 22:45:58,039 dispcal.exe
2014-11-10 22:45:58,039 -v2
2014-11-10 22:45:58,039 -dmadvr
2014-11-10 22:45:58,039 -c1
2014-11-10 22:45:58,039 -yn
2014-11-10 22:45:58,039 -qh
2014-11-10 22:45:58,039 -m
2014-11-10 22:45:58,039 "-w0.3127,0.329"
2014-11-10 22:45:58,039 -G2.4
2014-11-10 22:45:58,039 -f0
2014-11-10 22:45:58,039 -k0
2014-11-10 22:45:58,055 -A4.0
2014-11-10 22:45:58,055 "madVR 2014-11-10 0.3127x 0.329y Rec. 1886 S XYZLUT"
2014-11-10 22:45:58,446 dispcalGUI: Starting interaction with subprocess
2014-11-10 22:45:58,446 Setting up the instrument
2014-11-10 22:45:59,210 Product Name: i1Display3
2014-11-10 22:45:59,210 Serial Number: [edited]
2014-11-10 22:45:59,210 Firmware Version: v1.01
2014-11-10 22:45:59,210 Firmware Date: 12Apr11
2014-11-10 22:46:00,365 dispcal: Error - new_disprd() failed with 'Window Access Failed'
2014-11-10 22:46:00,489 dispcalGUI: Reached EOF (OK)
2014-11-10 22:46:00,489 ...aborted.
2014-11-10 22:46:00,505 Calibration has not been finished.
Edit: This appears to only happen to the MADVR profile selected under display device.
avstaku is offline
post #2833 of 2835 Old 11-11-2014, 02:59 AM
Evanesco's Avatar
Quoted: 31 Post(s)
Will I still get full screen, but the color patches only 14% of the screen, with blacks around it?
Evanesco is offline
post #2834 of 2835 Old 11-11-2014, 05:21 AM
-Hitman-'s Avatar
Quoted: 46 Post(s)
Liked: 65
Yes still full screen black boarder, the slider only effects the "patch" window size, you can resize from 4%,8%,12%,16% onwards etc.. (hover mouse over slider to see current set size).
-Hitman- is offline
post #2835 of 2835 Old 11-11-2014, 05:23 AM
Evanesco's Avatar
Quoted: 31 Post(s)
Thanks a lot!! I will try when I get home from work.
Evanesco is offline
Reply Display Calibration
