Klein's Software Update Released - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ConnecTEDDD
post #1 of 21 Old 05-09-2013, 06:21 PM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1045 Post(s)
Liked: 1515
Klein ChromaSurf 5.2.403 (09 May 2013)
Release Notes
Changeset Logs:
* Fixing hardcoded RGB matricies.
* Esc will exit out of measurment
* Added Manual Entry Device
* Check devices that are unplugged and close them
* Create Cal will stay infront of the background form
* Fixed not connecting to some serial to USB devices on MAC
* PC Pattern Gen works with muit montiors
* Added signing text for windows
Unknow issues:
* Mac Lion (version 10.7): Fullscreen problems
Tested Linux platforms:
* CentOS 6
* Ubuntu 13
Download Link
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #2 of 21 Old 10-09-2013, 01:19 AM - Thread Starter
Liked: 1515
Klein SDK Package: v2.35.194 Oct 10, 2013
Release Notes
Major
* Added DCI-P3 Gamut
* replaced WhiteSpec with GamutSpec
* Added FootLamberts to Nits and back
* Added Hue and Saturation
* Flicker to 150HZ on new devices
Minor
* Be able to compare GamutSpecs
* Fix flicker crash
* Fixed memory leaks
* Added new correction for flicker
* Added hue, staturation, value, gamutSpec to AvgMeasurement
* Added Docs for GamutSpec
Download Link
post #3 of 21 Old 12-18-2013, 01:12 AM - Thread Starter
Liked: 1515
Klein ChromaSurf 5.6.458 (17 December 2013)
ChromaSurf is updated to be compatible with newest Mac 10.9 (Maverick) Operting System (as of 17/12/2013).
Latest Version: Added Features
* New GamutSpec window
* Kelvin Calculator: Hue and Saturation graph
* Pattern Manger: Changed max stable time for the pattern Gen to 15 sec
* Flicker: Added 3 error indicator
* Pattern Manger: Added a Manual Pattern Gen
* General: Added nits/fL to all the values
* Settings: Removed Flicker from setting
Latest Version: Bug Fixes
* CreateCal: Fix Select Cal from going in the background
* CreateCal: Only one instance
* CreateCal: Fixed a Unit
* Flicker: fix going to old 100 instead of 150 when connected to the new firmware
* Pattern Manger: Users cannot change colors doing a run
* Pattern Manger: Doesn't hide form after finished
* General: Changed the text on unstable measurement error
* General: Resizing Hue and Saturation better
* General: Fixed FL and Nits conversion.
* Mac: Doesn't crash on load
* Linux: Doesn't crash on ESC in pattern run
Latest Version: Tested Linux platforms:
* CentOS 6
* Ubuntu 13
Download Link
post #4 of 21 Old 04-26-2014, 12:31 AM - Thread Starter
Liked: 1515
Klein ChromaSurf 5.10.471 (25 April 2014)
Added Features
*Flicker
- Removed Roll off
- Added Signal graph
- Added RangeLock
- Added Save one Shot
- Added Save the current Flicker
- Added when paused, can between switching units
- Added Flashes
- Added Logging Flashes
*Main window
- Removed Flicker from window, added a new window for flicker
- Added Save the current Measurement
- Added more IRE Steps, from 5 - 100 every 5 steps
- Added Auto connection to the previously Klein Device that was connected
- Added a Max White Y adjustment setting
- Mapped the target color to the Test Panel
- Added Video/Broadcast mode for easier calibration
*Test Panel
- Removed Flicker
*System
- Added Day Theme
- Unit text boxes will resize
- Added decimal points to Max White Y
Bug Fixes
*Create Cal
- Fixed repeating last color
*Main Window
- Fixed Slow Connections
*System
- Corrected Sony's offset
- Added Nits/fL to Logging, Kelvin Calc, and TestPanel
- Fixed a crash on closing ports in Create Cal, and other similar forms
* CentOS 6
* Ubuntu 13
Download Link
Iron Mike likes this.
post #5 of 21 Old 04-26-2014, 02:48 AM
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
I can get the latest 5.10.471 to install but CS won't run... it'll abort with an error that a .dll is missing.... all on Win 7 x64...
did u get the latest version to run ?
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
post #6 of 21 Old 04-26-2014, 02:56 AM - Thread Starter
Liked: 1515
Nope, I have send email before 2 hours to Klein to solve that error with a new build.
post #7 of 21 Old 04-26-2014, 11:19 AM
funkymonkcp's Avatar
I had the same error on Windows 8.1. I kept uninstalling and reinstalling and it eventually worked. There is a funny typo in the program. Calibration is spelled way wrong. Also the Mac version has all it's menus greyed out when I try to create a cal file.
funkymonkcp is offline
post #8 of 21 Old 04-30-2014, 04:57 AM - Thread Starter
Liked: 1515
Hi, now you can safely re-download/install that update, the reported installation problem has been fixed from Klein's crew.
post #9 of 21 Old 04-30-2014, 05:17 AM
I reported it to them as well; guess they got a number of emails from people saying the same thing. It's nice to have to head shed of a company reply to emails, as well as the developers.
post #10 of 21 Old 04-30-2014, 05:30 AM - Thread Starter
Liked: 1515
Yes, the calibaetion typing error it will be fixed also, I will let you know when the link will be updated.
post #11 of 21 Old 04-30-2014, 05:52 AM
Yeah, they told me the typo would be fixed in a future release as well. I wouldn't expect them to upload an entirely new version for a simple typo that doesn't really affect anything. The .dll error was a bigger deal.
post #12 of 21 Old 04-30-2014, 05:54 AM - Thread Starter
Liked: 1515
Yes, ofcourse, that typing is not a big deal, but a newer version will be uploaded under the same build version. I will let you know wink.gif
post #13 of 21 Old 06-23-2015, 04:45 PM - Thread Starter
Liked: 1515
Klein ChromaSurf 5.23.532 (23 June 2015)
Release Notes
VerfiyBlack: aiming lights check
WhiteOffSets: Changed "Sony" to "Sony OLED"
Flicker: Added Colorimeter connection options
Gamutspec: Changed tolerance for white offsets
MainWindow: users can click on Flicker before Klein device is hooked up
MainWindow: Fixed an xy issue on Magnified mode
MainWindow: Add offsets settings
MainWindow: CalFil 0 will display on startup
CreateCal: Fixed crash on Switching devices
CreateCal: Fixed bug on closing form and close Klein Device
CreateCal: Fixed bug on getting measurements from Klein Device
Download Link
post #14 of 21 Old 09-17-2015, 04:24 AM - Thread Starter
Liked: 1515
Originally Posted by Light Illusion View Post
Originally Posted by TomHuffman View Post
Originally Posted by sotti View Post
Steve, Tom & Joel,
Klein has released a new SDK for K10-A/K-80 etc. (In case you haven't informed from Klein directly for this release)
Klein SDK v2.60.254 (September 16, 2015)
Release Notes
Flicker:
* Added JEITA Discount
* Added JEITA and VESA for dB
* Added Constrast Method and Normalized percent
* Adding Nits to flicker, but still need work
Measurement:
* Added K-80 Support
Wrappers
* Changed .Net EventHandling to return the object
* Updated .Net wrapper to VS2013
* Added native c++ object
* Updated XCode
Download Link
post #15 of 21 Old 09-17-2015, 02:47 PM - Thread Starter
Liked: 1515
Originally Posted by gwgill View Post
Forgot to include Graeme.
post #16 of 21 Old 09-24-2015, 03:43 AM - Thread Starter
Liked: 1515
Klein SDK v2.61.254 (September 23, 2015)
Release Notes
Added Labivew support for Continuously Measuring.
Added Labivew support for Continuously Flicker.
Download Link
post #17 of 21 Old 12-17-2015, 03:43 AM - Thread Starter
Liked: 1515
Klein ChromaSurf 5.36.551 (16 December 2015)
Release Notes
Mac: Fixed a connection bug
Mac: Fixed a saving profile bug
Mac: Fixed a QC profiling bug
Gamutspec: Fixed DCI-P3 White point
Gamutspec: Fixed offset not applying on startup
Mainform: Fixed an averaging display bug
FlickerForm: Fixed the signal graph when no K-10 is hooked up
CreateCal: Updated the PatternManager
PatternManager: Changed the UI
Themes: Fixed a few issues
Download Link
post #18 of 21 Old 12-17-2015, 04:05 AM - Thread Starter
Liked: 1515
Note: Download Link for Windows Installation is temporary broken, I will update again when it's been fixed.
post #19 of 21 Old 12-17-2015, 12:26 PM - Thread Starter
Liked: 1515
Download Link for Windows Installer is now working.
post #20 of 21 Old 02-18-2016, 04:11 AM - Thread Starter
Liked: 1515
Klein ChromaSurf 5.37.557 (17 February 2016)
Release Notes
CreatCal: Fix couldn't read measurements from CS-2000, PR-650, and BM-7
Download Link
post #21 of 21 Old 01-07-2017, 01:42 AM - Thread Starter
Liked: 1515
Klein ChromaSurf 5.43 (04 January 2017)
New Features
Test Color Batch allows users to set up color patch timelines.
Profile selection for CS.
Arrow keys now navigate between colors on Pattern Gen Window.
Added the resolution of the Patch Sizes on Pattern Gen Window.
Faster way to check Klein devices.
Faster way to check for PR-650 devices.
Faster way to check for CS-2000 devices.
HI-DPI buttons.
Antialiasing on Graph.
Updated the UI for Flicker and Main Forms.
Added Max averaging for auto low light.
Added auto for low light for averaging on Pattern Gen Window.
Added Faster Measuring Mode.
Allow users to log more than one time in Flicker log.
Kelvin Calculator can convert from LAB to any other measurement by using spectro.
Added loading iris when doing black calibrations.
Flicker Auto lock.
Deleting profiles requires password.
Crash Fixes
Sending images without a Pattern Gen hooked up.
Mac: selecting a device.
Mac: rescanning for a device.
Clicking QC save data when there isn't any data.
Bug Fixes
Labels and LineEdits able to resize better.
Changed nits to Lux when using Lux profiles.
Memory leaks.
Kelvin Calculator graph now updates on a gamut change.
Better locking for Mac.
Using RAW XYZ instead of corrected XYZ for averaging.
Units in Manual Entry.
Download Link
sillysally likes this.
Reply Display Calibration
