Calibrate with JVC RS60U or DVDO DUO ?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-11-2013, 07:47 AM - Thread Starter
CIH USER
Franin's Avatar
Quoted: 2189 Post(s)
Liked: 1311
Hi at the moment Im calibrating with the DVDO DUO which is fine, but I've been thinking would it be better for me to calibrate with the JVC RS60U? I know the DVDO is 11 point but what is the JVC RS60U? I simply cant find any info regarding that. I know I will have to purchase a RS232(Null) to USB which I have to order overseas ( hence why Im asking which is better ) but can I use LAN instead to run the DDC on Calman 5
_________________________
Franin is offline
post #2 of 4 Old 05-11-2013, 08:16 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Usually best to rough it in on the projector first. Then go to the external box.
You can just calibrate it the old fashioned way on the JVC ... manually ... with the remote in hand. You don't have to connect the laptop to the projector.
Calibration is not a race.
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 4 Old 05-11-2013, 08:30 AM - Thread Starter
CIH USER
Franin's Avatar
Liked: 1311
Originally Posted by Michael TLV View Post
Greetings
Regards
Thanks Micheal Im curious to know does the JVC have a 11-point gamma/grayscale adjustment ?
Franin is offline
post #4 of 4 Old 05-11-2013, 10:42 AM
Quoted: 40 Post(s)
Liked: 142
Greetings
Yes, it is in the gamma area.
Regards
Reply Display Calibration
