plasma dithering and calibration.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-15-2013, 11:37 AM - Thread Starter
benareeno's Avatar
Quoted: 21 Post(s)
the dithering/noise seen on plasmas can be annoying to some....I would think that calibration could do nothing to correct this. Other than lowering contrast which may make the noise less apparent...how could greyscale and primary calibration do anything to effect dithering/noise??
benareeno is offline
post #2 of 3 Old 05-15-2013, 11:39 AM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
It can't.
You can play with brightness, contrast and the panel drive level to see if you a particular combination helps, but for the most part the dithering just is what it is.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 3 Old 05-15-2013, 11:50 AM - Thread Starter
benareeno's Avatar
Quoted: 21 Post(s)
just what I thought...thanks for the reply.
Reply Display Calibration
