Is brightness exact same as bias? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-21-2013, 02:44 AM - Thread Starter
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
Are bias and brightness exactly the same? I know they both affect the darker levels,but It looks like brightness affects more the dark levels and bias affects more middle levels.Or am I wrong? I'm trying too balance the gamma.The tv does NOT have 10 point controls.
Samung51pne450
Vic12345 is offline
post #2 of 3 Old 05-21-2013, 09:58 AM
PlasmaPZ80U's Avatar
Quoted: 2304 Post(s)
Liked: 708
bias is brightness by color (R, G, B)... these are grayscale controls
brightness affects all colors (R, G, B) together
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is online now
post #3 of 3 Old 05-21-2013, 12:56 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 353
You should always re-check Brightness after adjusting any of the bias/offset controls and vice versa.
Gain controls affect the brighter range of each color (R G B)... so if you adjust any of those, you should re-measure your 100% white level to make sure it is still where you want it to be and adjust Contrast up or down if your 100% white got too bright or too dim (but you need a meter for this, you would never see it by eye).
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
Reply Display Calibration
