Proper CALMAN 5 C6 meter mode for Sharp 70LE857U TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-07-2013, 06:53 PM - Thread Starter
scottts's Avatar
Just got a new Sharp 70LE857U. I'm using a C6 colorimeter with CALMAN 5.1.1.
Anyone know the proper Meter Mode setting for this Sharp? I think it's white LED but is it normal or wide gamut?
Can't find the answer anywhere.
Scott
scottts is offline
post #2 of 8 Old 06-08-2013, 08:26 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 333
You'll want to use the RGBY led table.
That's your quattron table.
sotti is offline
post #3 of 8 Old 06-08-2013, 12:29 PM - Thread Starter
scottts's Avatar
Of course, makes perfect sense. I missed that choice in the menu for some reason.
scottts is offline
post #4 of 8 Old 09-18-2013, 03:37 PM
croswald's Avatar
The c6 is a rbg meter it does not have a yellow censor in it.. you can nit adjust color space on a quatron
croswald is offline
post #5 of 8 Old 09-18-2013, 03:46 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 333
Your eye doesn't have a yellow sensor either.
We have tri-chromatic vision, our entire system of measuring and quantifying color is based around the fact that our eye has short, medium and long wave cones that roughly equate to blue, green and red colors. Everything we perceive is based on the sensitivity of those cones. Yellow is just a mixture light that excites both our medium and long wave cones.
So just like our eye's the C6 does not need an additional sensor, only the correct spectral table just like any other display.
sotti is offline
post #6 of 8 Old 09-18-2013, 03:57 PM
PlasmaPZ80U's Avatar
Quoted: 2239 Post(s)
Liked: 686
There's one thing that's always bothered me about the name of that table...
I believe there is also a choice called LCD Direct View (RGB LED), in which RGB refers to the color of the LEDs in the backlight whereas the Sharp Quattron table is called LCD Direct View (RGBY LED), in which RGBY is referring to the colors of the sub-pixels in the LCD panel itself, not the backlight which is White LED as far as I know.
Perhaps something like RGBY-LCD Direct View (White LED) or LCD Direct View (Sharp Quattron White LED) would be more consistent with the naming scheme the other LCD tables use?
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha RX-A2070, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is offline
post #7 of 8 Old 09-18-2013, 03:58 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 333
Point taken.
sotti is offline
post #8 of 8 Old 09-18-2013, 05:07 PM
Liked: 686
Point taken.
thanks
Reply Display Calibration
Sharp He Lc 70le857u 70 Inch 3d Smart Led Tv
