LightSpace DPS - (Free Display Check Version of LightSpace CMS) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-17-2013, 10:54 AM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1051 Post(s)
Liked: 1517
LightIllusion has released a Free Display Check version of their renowned LightSpace CMS display colour management system.
LightSpace DPS is a 'Free License' version of LightSpace, enabling the accuracy of any display to be verified against any given preset standard, such as Rec709, BT.1886, DCI P3, etc., allowing operators, colourists, supervisors, DoPs and directors to be confident that a the images they are observing are guaranteed to be accurate, by checking any display to verify if they are accurately set-up, without any unwanted colour issues, ensuring all footage is reviewed accurately throughout the image pipeline.
With LightSpace DPS, and a compatible probe, any user can perform accurate display profiling, measuring the difference between any specified colour standard, and the actual colours a given display shows.
Being able to quickly and easily verify any display accuracy is a critical capability for any image based workflow.
LightSpace DPS has one main function - to be used for Display Profiling and Verification, allowing the user to determine if a given display requires re-calibration or not.
With LightSpace DPS it is possible to use any of LightSpace's profiling capabilities, but without the ability to 'save' any profiles. All checking needs to be performed on the profile before closing the software.
The free Display Check version of LightSpace can be downloaded from the Light Illusion website:
For information on the free Display Check version of LightSpace CMS see the LightSpace DPS Page
To register for a Free LightSpace DPS license please use the LightSpace DPS Registration Page.
This license will activate the normal Demo Download into the 'free' profiling version.
I'm starting a separate thread for the Free version of LightSpace DPS, any questions about operation/guides/settings/workflow/etc. can be answered here by LightIllusion Team or by LightSpace's Experienced Users.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #2 of 12 Old 06-17-2013, 03:59 PM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 848
Ya Ted, I have been using that display checker comparing BT1886 to REC 709 and other things you show.
And that's why I only use 709 for my profiles, running home LS.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #3 of 12 Old 06-19-2013, 12:03 PM - Thread Starter
Liked: 1517
ss
Anyone with a Supported Meter (i1D3 OEM, i1PRO1/2, JETI, Minolta, PhotoResearch, Discus....etc.) can verify his display very easy now with this Free Version of LightSpace. wink.gif
post #4 of 12 Old 06-20-2013, 01:55 AM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 848
Here is how my 65VT60 profiles using the pre settings found here.
http://www.avsforum.com/t/1466472/2013-panasonic-settings-issues-thread/1110#post_23439581
This is how the free or home Light Space profiling tool's results will look like.
ss
post #5 of 12 Old 06-20-2013, 03:43 AM
Quoted: 1393 Post(s)
Liked: 587
Ted,
I'm interested in giving it a try, but what do you use for a signal generator?
I have an accupel 5000. Is it compatible with the software?
JimP is online now
post #6 of 12 Old 06-20-2013, 09:13 AM - Thread Starter
Liked: 1517
Ted,
Hello Jim, Currenty the Lumagen Radiance Series Processors can be used as an External Hardware Pattern Generator Box.
For LightSpace's Internal Pattern Generator, You can use your HDMI Out of your notebook, using extended desktop feature, but a Black Background as a wallpaper and move the LightSpace measurement Window to the extended desktop space. Then center it using the window xy info LightSpace provides you and set the window size you want, using Window xy pixel numbers also.
After that click the LigtSpace measurements Window to hide that window title bar.
Things will be easier when i will finish the Ted's LightSpace Calibration Disk Project and release it to public.
* You have to check your Video Card settings also, disable all enhancements etc...
post #7 of 12 Old 06-20-2013, 02:50 PM
cadett's Avatar
Quoted: 37 Post(s)
Liked: 98
At your mercy!!!
cadett is online now
post #8 of 12 Old 01-10-2014, 08:59 AM - Thread Starter
Liked: 1517
Light Illussion's LightSpace DPS (Free Display Check Version of LightSpace CMS) now supports up to 21-Point Cube (9.261 Color Points) Free Display Verification for daily performance test where accurancy is very critical.
Verification
It is also possible to generate a LUT from the profile, which aids checking the profile information as the 3D cube view and 1D graph LUT will show the necessary corrections required for the display profiled. The LUT can also be 'virtually applied' to the display for re-profiling, howing the effect of the LUT corrections.
High Accuracy
Unlike inferior display checking systems, LightSpace CMS is not limited to a small range of colour patches, providing 'Quick Profiling' for daily checking, as well as full cube based profiling, including 21^3 with 9261 individual colour patches (and beyond) for unlimited accuracy when verifying the accuracy of any given display.
Quick daily verification takes seconds, and ensures no display drift, while full cube based profiling ensure any given display is actually accurate to the required colour space target.
Simple Confirmation
Display accuracy is simplicity itself to check, with the closer the cube image is to being a cube, the better the accuracy.
And being able to rotate the cube in 3D space makes it simple to spot any colours that are inaccurate anywhere in the volumetric colour space.
All this in addition to standard CIE, DeltaE, gamma graphs, including LightSpace's unique RGB Separation graph.
RGB Separation
RGB Separation' is a very quick and simple guide to likely display accuracy.
If this graph shows errors the display has to be considered inaccurate.
Free Download Link
post #9 of 12 Old 01-10-2014, 09:59 AM
realzven's Avatar
Liked: 84
Steeve, no good news from xrite for Lightspace to support D3 retail ?
realzven is offline
post #10 of 12 Old 01-10-2014, 02:52 PM
Light Illusion's Avatar
Quoted: 320 Post(s)
Liked: 627
Nope, still no good news from X-Rite...
Feel free to contact them and let them know you are unhappy with their position regarding the Retail version of the probe.
I really do wish they would change their position on this!
Steve Shaw
LIGHT ILLUSION
Light Illusion is online now
post #11 of 12 Old 01-11-2014, 12:27 AM
realzven's Avatar
Liked: 84
Thanks for the reply Steeve, i hope xrite will change the decision in 2014.... wink.gif
realzven is offline
post #12 of 12 Old 01-11-2014, 03:46 AM
Quoted: 320 Post(s)
Liked: 627
One point worth making is the with the 'User Definable' patches capability you can make any colour sequence you want to run calibration verification.
For example, make a selection of patches that are specifically aimed at 'memory colours', such as grass, sky, skin tones, etc...
There is no need to stick to the standard profiling cubes sizes and colours biggrin.gif
Steve Shaw
LIGHT ILLUSION
Reply Display Calibration
