Calman & bt.1886 gamma - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Plasma Window size
4-5% 1 7.69%
4-5% APL 2 15.38%
6.5% 4 30.77%
6.5% APL 0 0%
10% 3 23.08%
10% APL 2 15.38%
12-15% 1 7.69%
12-15% APL 0 0%
Voters: 13. You may not vote on this poll
post #1 of 4 Old 06-20-2013, 03:21 PM - Thread Starter
cadett's Avatar
Quoted: 37 Post(s)
Liked: 98
So, after calibrating my ST60 a few times now, I'm trying to come to a conclusion on a final run.
I've tried 4/5/6.5/10 percent windows & the apl options of those windows.
I settled on a gamma of 2.3, but now want to experiment using bt.1886 gamma formula.
I'm running Calman 5 Ent. As I understand it, it uses your mll & measured luminance to calculate the "curve".
From what i've read if your set measures .01 cd/m2(.003fl) you should use 0.0 for your target.
Then there is also the option for white level target in Calman also.
Should I just leave this at the measured white level or should I set it to my target 35fl.
The reason I ask is because I use a custom workflow(very similar to the HT Advanced, with tweaked deltaE targets)
Does Calman use my measurement at the 100 ire pattern to set my target white? Because I set my luminance with a 2% pattern, but I set my gamma/grayscale with a 5% ire pattern, so the luminance will differ.
Am I headed in the right direction?
cadett is offline
post #2 of 4 Old 06-20-2013, 03:47 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
From the research I've seen the APL of your average movie is in the 17-23% range, so I would go with an APL pattern set somewhere in that range. I would imagine the difference between a 17% APL and a 23% APL would be very small.
Leave your setting for white on use measured white. There seems to be a rash of people wanting to change this, but it's a bad idea. The option is there only for very specific scenarios (monitor matching).
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 4 Old 06-20-2013, 04:26 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
Originally Posted by sotti View Post
I would go with an APL pattern ...snip...17% APL and a 23% APL
And which disc (of the half dozen that are circulating) have patterns in this range?
B.
Brian B is offline
post #4 of 4 Old 06-20-2013, 04:37 PM - Thread Starter
cadett's Avatar
Quoted: 37 Post(s)
Liked: 98
So after some reading & tinkering, setting Calam to hit the bt.1886 gamma target on my set, will be equivalent of setting it to hit a target of 2.4 using the power formula. I think I'm going to just use the power formula & use a target of 2.75.
Now the jury is still out on what patterns to use for the ST60. 5% or 5% APL. I understand the argument, just not sure if I'm board with it.
cadett is offline
Reply Display Calibration
