MAC support - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-26-2013, 08:44 PM - Thread Starter
YanivZX6R's Avatar
Quoted: 17 Post(s)
Can someone please list all known calibration software that can work on a MAC?
(without a simulation software)
YanivZX6R is offline
post #2 of 7 Old 06-26-2013, 09:09 PM
hoozthatat's Avatar
Liked: 38
Unfortunately both CalMAN 5 and ChromaPure are not Mac compatible. However, both pieces of software do work via Bootcamp and/or Parallels (assuming you have a spare version of a Windows OS, or that you're willing to purchase a license.) If that's not on your agenda then I'd look toward ColorHCFR, it's completely free and works incredibly well on both Mac and PC (I've used it on both my Mac Mini and my Windows 7 PC.) The UI is nowhere near as intuitive as say CalMAN 5, but the functionality is all there and absolutely gets the job done and I greatly appreciate the software.
60F8000; RX-V367; TSi300 x2; YST-SW102; Harmony 650; Apple TV; Microsoft Xbox One Console; RF-HTS120;
xRite i1 Display Pro (OEM); CalMAN 5 Basic; ColorHCFR
hoozthatat is offline
post #3 of 7 Old 06-26-2013, 09:23 PM - Thread Starter
YanivZX6R's Avatar
Quoted: 17 Post(s)
ColorHCFR MAC version only support
Spyder II
Spyder III
post #4 of 7 Old 06-26-2013, 09:49 PM
hoozthatat's Avatar
Liked: 38
Spyder II
Spyder III
I use an xRite i1 Display Pro OEM, no problems.
post #5 of 7 Old 06-27-2013, 02:43 AM
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
basICColor has a Mac version, but I'm not sure if they finally added meter profiling support, I requested that a year ago - very quick, very easy to use.
Also, check if Argyll CMS has a Mac version - it's free, and I had excellent results with it on Windows with ICC based calibration.
- M
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
post #6 of 7 Old 06-27-2013, 03:18 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
If you have an Intel Mac, you can run Windows 7 or Windows 8 on it and run any calibration software you want. You ARE NOT required to run Mac O/S only on Intel Macs.
You may even be able to have Windows and Mac O/S installed on the Mac and choose which starts when you turn on the computer. That avoids the whole simulator issue. And gives you access to the best calibration software options.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #7 of 7 Old 06-27-2013, 10:41 PM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
Yes you can use windows and osx on the same machine. You can even install windows on an external drive, using thunderbolt which is very fast, and boot from there.
On intel macs.
Wouter73 is offline
Reply Display Calibration
