Calibration for the LG 60PN5300? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-13-2013, 09:27 PM - Thread Starter
Caretaker13795's Avatar
can someone post the best settings for the LG 60PN5300? thanks
Caretaker13795 is offline
post #2 of 6 Old 07-14-2013, 12:18 AM
GeorgeAB's Avatar
Quoted: 135 Post(s)
Liked: 240
From the "sticky" threads above:
'Sharing display menu settings?'
http://www.avsforum.com/avs-vb/showthread.php?t=1055906
GeorgeAB is offline
post #3 of 6 Old 07-26-2013, 04:02 PM
Joker035's Avatar
That thread has been closed. So I will share my settings I posted in another thread.
Ok here is professional calibration settings for my LG 60PN5300 TV. The Tv looks beautiful with these settings in my house, but should be a good base setting for you to work from.
LG 60PN5300
Energy setting: Off
Picture Mode: Expert 1
Panel Light: 100
Contrast: 70
Brightness: 100
H Sharpness: 10
V Sharpness: 10
Color: 57
Tint: Center
Expert Control
Dynamic Contract: Off
Color Gamut: Standard
Edge Enhancer: Off
Color Filter: Off
Gamma: Off
Color Temp: Warm 2
Method: 20 Point IRE
Pattern: Outer
Ire: 100
Red: 5
Green: 0
Blue: 24
Color: Cyan
Saturation: 0
Tint: 3
Luminance: 0
Picture Option
Noise Reduction: Off
Mpeg Noise Reduction: Off
Black Level: Low
Real Cinema: Off
Motion Eye Care: Off
LG 60PN5300, Pioneer VSX-1022,Xbox One, Xbox 360, PS3, Wii U, Directv Genie, Moster Power HTS1600
Joker035 is offline
post #4 of 6 Old 07-26-2013, 04:07 PM - Thread Starter
thanks but i learned on here that Calibration is based on each house that it is in.
post #5 of 6 Old 07-26-2013, 04:53 PM
GeorgeAB's Avatar
Quoted: 135 Post(s)
Liked: 240
Also based upon the fact that consumer electronics components have relatively broad tolerances that prevent equal settings values from performing the same on different units.
http://www.tlvexp.ca/2012/12/the-fruits-of-copying-settings-the-pioneer-lottery/
http://forums.hdtvtest.co.uk/index.php?topic=7202.0
It has been documented that some copied settings values have actually resulted in poorer performance than factory presets on some parameters. It is a myth that the numbers used from a calibrated display will produce an accurate image on another sample of the same make and model. It's simply a roll of the dice at best, and does not teach the copier anything about good video pictures.
GeorgeAB is offline
post #6 of 6 Old 07-26-2013, 11:10 PM
HDTVChallenged's Avatar
Liked: 215
Expert Control
Edge Enhancer: Off
Color Filter: Off
Gamma: Off
Color Temp: Warm 2
Pattern: Outer
Ire: 100
Red: 5
Green: 0
Blue: 24
Color: Cyan
Saturation: 0
Tint: 3
Luminance: 0
Also it's not much help showing only one out of 20 individual greyscale points and only one (out of six) of the CMS settings ... wink.gif But what do I know? smile.gif
HDTVChallenged is offline
Reply Display Calibration
Lg 60 Inch Plasma 60pa550c , Lg 60ln5710
