Need help choosing an HDMI Color Space - AVS Forum
post #1 of 14 Old 07-15-2013, 06:33 PM - Thread Starter
Jim McC's Avatar
Liked: 31
I recently bought the Panasonic BDT230 player, and I don't know which HDMI Color Mode to choose. My display is the Mitsubishi HC3800 DLP projector. I have the Spears and Munsil 1st edition disc, and read the article on their website, but it's way too complicated for me. Is there 1 test I can use to choose one? I also have the AVS709 test patterns if that would be easier. Thanks
Jim McC is offline
post #2 of 14 Old 07-15-2013, 06:41 PM
rahzel's Avatar
Liked: 145
I would use YCbCr 4:2:2.
rahzel is offline
post #3 of 14 Old 07-15-2013, 10:16 PM
Rolls-Royce's Avatar
Liked: 61
Me too.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #4 of 14 Old 07-16-2013, 04:26 AM
JimP's Avatar
Quoted: 70 Post(s)
Liked: 179
Why?
Samsung 64F8500, Panasonic 65VT50, Oppo 95, Tivo Roamio for OTA, Dish VIP722, Marantz AV8801 preamp, Rotel Amps, Atlantic Tech 8200 speakers, Seaton Submersive HP, Calman 5, Chromapure, Accupel DVG-5000, i1Display3pro, i1pro2, eecolor colorbox.
JimP is offline
post #5 of 14 Old 07-16-2013, 08:08 AM
sspears's Avatar
Liked: 49
There is a PDF that has check boxes to mark off after looking at each pattern.
I would start with the chroma alignment pattern and look at the red stripe on yellow background. Does the pink blur on either side of the red stripe look symmetrical? Or is one side dark red and the other pink? You want to select the mode where it is symmetrical.
If you don't see a difference on the above pattern, then look at the chroma multiburst. Does the last burst on the 2nd and fourth row look brighter in one vs. the other? Go with the brighter burst.
The Panasonic player has advanced chroma processing, so if you let it convert to 4:4:4, then the 2nd row burst will probably be brighter than sending 4:2:2. If you disable the processing then they might be the same.
sspears is offline
post #6 of 14 Old 07-16-2013, 09:47 AM
rahzel's Avatar
Liked: 145
Originally Posted by JimP View Post
Why?
Doug can explain it better than I can.
HTPCs is a different story.
rahzel is offline
post #7 of 14 Old 07-16-2013, 02:53 PM
Doug Blackburn's Avatar
Liked: 221
USUALLY YCbCr 4:2:2 is the best choice... I'd say 90%-95% of the time that's what you want to use.
The exceptions are random models that for some reason, sending them RGB produces better-looking images. So you always want to do a check with your particular display Watch something familiar in YCbCr 4:2:2 then repeat the same scene in RGB mode (16-235 or limited or Standard, different manufacturers use different conventions for naming). If the images look the same, just use 4:2:2 and forget about it. But if RGB looks better, switch all your sources to RGB mode if they have an option to do that.
If you are doing the comparison between the 2 modes and you don't notice either one being obviously better (or worse) than the other mode, don't fret over it. Most of the time there's not going to be a difference. Don't spend more than 10 minutes looking for differences either. If you see a difference, it should be fairly obvious and you won't need anthing close to 10 minutes to decide that one of the connections looks better.
In even more-rare cases, RGB looks worse than YCbCr... doesn't happen very often, but I have seen it 2 times on 2 different brands of displays more than a couple of years apart.
You never want to assume 1 mode is the right mode all the time. You really have to check each brand/model display you use and if you ever change displays, you should check again with the new display. I've never detected a way to determine what mode is going to work best, it has always come down to a visual check. Fairly close to 95% of the time, you'll see no difference between RGB and YCbCr 4:2:2 mode so don't be surprised if that's what you experience.
"Movies is magic..." Van Dyke Parks
THX Certified Professional Video Calibration
ISF -- HAA -- www.dBtheatrical.com
Widescreen Review -- Home Theater & Sound
Doug Blackburn is offline
post #8 of 14 Old 07-16-2013, 05:03 PM - Thread Starter
Jim McC's Avatar
Liked: 31
Thanks guys.
Jim McC is offline
post #9 of 14 Old 07-17-2013, 01:16 AM
Vic12345's Avatar
Quoted: 12 Post(s)
Liked: 25
I've read rgb is better because ycc is more compressed,(although I thought setting it to hdmi black level low would compress it too)..i would think less compression would mean smoother gradation(gradation more an issue on plasma)? I use rgb black level low.
Vic12345 is offline
post #10 of 14 Old 07-17-2013, 08:11 AM
Iain-'s Avatar
Liked: 37
Where is this PDF file located?
I've looked at the both disks on S and M calibration disk (edition 2) and on your website as well. Nowhere to be found. confused.gif
Iain- is offline
post #11 of 14 Old 07-17-2013, 09:59 AM
ElectronicTonic's Avatar
Liked: 58
Here's the PDF.......and here's the walk-through on how to use it.....LINK.
ElectronicTonic is offline
post #12 of 14 Old 07-17-2013, 10:49 AM
rahzel's Avatar
Liked: 145
Almost all video is encoded using YCbCr 4:2:0 and uses a range of 16-235, so outputting RGB would require a conversion. No compression is being done regardless of what color space you use when it comes to Blu-Ray. You may be thinking of gaming consoles or PCs that output native RGB 0-255. It's usually best to avoid conversions, so for video, YCbCr is usually the best option. As Doug said, there are rare times that RGB will look better.
HTPCs are different because unlike Blu-Ray players, they can't output native YCbCr so they need to get converted to RGB before it reaches the display anyway. So with PCs, IMO it's best to output RGB 0-255 whenever possible, or RGB 16-235 if your HDMI port is shared and you need to match your other devices.
rahzel is offline
post #13 of 14 Old 07-18-2013, 02:14 PM
Liked: 221
8-bit RGB carries more color information than humans can see. There is ZERO reason to use RGB unless it happens to be the mode that produces the best looking images on your particular display.
Blu-ray discs are encoded in YCbCr 4:2:0 But you NEVER get that out of a Blu-ray disc player.
The 4 refers to the luminance data, the 2 and the 0 refer to how much color decimation is done (this is NOT the same thing as compression). Color decimation removes the "excess" color information that we can't benefit from because our vision system can't see it. 4:4:4 indicates no color decimation and YCbCr 4:4:4 has the same amount of data in the datastream as RGB... which means way more data than needed for human vision as related to color resolution. The data on the Blu-ray disc is always 4:2:0 but disc players always output 4:2:2 or 4:4:4 when you select a YCBCr mode so the player already restores some of the decimated color information. Doing MORE "un-decimation" accomplishes nothing though which is why 4:2:2 is the best output option. Most displays process video in YCbCr mode anyway (where color and tint can be fairly easily manipulated). It is much more difficult for a TV to process RGB and in fact, most TVs receiving RGB actually convert the incoming RGB to YCbCr before processing it. By sending YCbCr, you avoid that extra conversion step. You can tell if a TV is converting RGB to YCbCr this way: If you send RGB to the display and the COLOR and TINT controls still work, the TV is converting RGB to YCbCr. If the COLOR and TINT controls become unavailable in RGB mode, the TV is staying in RGB mode when you send RGB.
But none of that tells you whether RGB or YCbCr looks better. You still have to view familiar content in both modes in order to see if one mode is obviously better than the other.
post #14 of 14 Old 07-18-2013, 08:06 PM
Vic12345's Avatar
Quoted: 12 Post(s)
Liked: 25
I have too use gamma+1 for reasons i wont repeat again,but it makes the shiny whites too Shiny bright and midtones washed out on bright screens.
I read ycc makes things shinier/brighter/more luminance in the bright areas.Is this true?
If true,is it still true when you use a low contrast setting?
Edit I've gone back to gamma 0,as 1 washes out the brighter shades too much with the lower contrast I'm using.
Vic12345 is offline
Reply Display Calibration
Panasonic Dmpbdt230 Wi Fi Blu Ray Player
User Tag List
