Do backlight strobing/scanning features like 'LED Motion Plus' affect meter profiles? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 09-10-2013, 06:01 AM
ConnecTEDDD's Avatar
Quoted: 1116 Post(s)
Liked: 1607
Originally Posted by Mark Rejhon View Post
Originally Posted by PlasmaPZ80U View Post
are there any LED/LCDs out there that have full motion resolution (identical to CRT and Plasma)
Yes. LightBoost. See above post.
And to lesser extent, Sony's new interpolation-free "Motionflow Impulse". This works great for 60fps material -- computer graphics & console games & sports motion on TV. The Sony Motionflow Impulse is a strobe backlight on Sony that outperforms scanning backlights. It comes very close too without needing to use interpolation, but it has dimness/flicker disadvantage. Do not forget to disable the ambient light sensor because it can excessively dim the image -- Motionflow Impulse becomes too dim when the ambient light sensor is enabled. Sony HDTV's in the series HX920, HX923, HX925, HX929, XBR950, W905A, W802A all now has this interpolation-free plasma-competing strobe mode, which shines during HTPC 60fps video game.
However, LightBoost is still the world's LCD motion clarity champion but is currently limited to computer usage.
I have already performed a lot of motion resolution tests using reference 1080p Blu-Ray Disks, With Impulse Mode Enabled, the motion resolution is clearer vs any other LED/LCD I have ever seen, and it's better from LG 1080p Plasma which I did direct comparison becasue i have a media streamer here with 5 HDMI Outputs.
The negative thing I noticed is that the Impulse mode leaves one long trail, (no multiple trails) one trail at a long distance from the moving object, but the resolution of the object remain superior and very accurate at motion - no details loss. It's like you see a copy of the original image with ~20% opacity, far from the original object....the distance maybe is 3cm long from 1.5m viewing distance.
I will perform a lot of new test soon.
As for Static Resolution Performance using 1080p Patterns, it's failed to reproduce any 1-Pixel White or Black Checkboard, with various background colors, Like AVSHD Sharpness Pattern or my Disk's Advanced Sharpeness Pattern:
I believe that is an upscalling problem, but soon i will try to upscale the image from a 2160p Blu-Ray Player, bypassing the internal upscalling...
In a few days I will have the Samsung 4K Ultra HD here to do direct comparisons.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
Old 09-10-2013, 12:44 PM - Thread Starter
PlasmaPZ80U's Avatar
Quoted: 1970 Post(s)
Liked: 565
So, are you an early adopter for 4K displays or is this more of a review/evaluation?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
Old 09-10-2013, 01:44 PM
Liked: 1607
Sony UltraHD arrived to my workplace and I will have it here for months, we can't sell it, it's a display model. wink.gif
Early next month I will have the Samsung UltraHD Model also there.
For the history, I'm working to a company which is distributor here of some Hi-End Audio Companies but we have a separate place with Video Division with almost 80 different TV's, which I have access to them daily. wink.gif
Old 09-11-2013, 10:23 AM - Thread Starter
Liked: 565
cool, that explains how you have access to such a wide range of displays... have you seen any OLED displays up close yet?
