What is the Point of Buying a Consumer Level Colormeter ... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-20-2013, 02:33 AM - Thread Starter
Tangled Cable's Avatar
Quoted: 115 Post(s)
Liked: 36
... gven that most seem to themselves require regular calibration otherwise they give faulty results?
I have a Spyder2 and an Eye One and neither one of them seem to be able to get me anywhere near 65k.
The Spyder2 is the better meter in my experience, especially with laptop monitor calibration, but with my front screen projector it has an obvious red misread, in that it tells me I need more red in my grayscale to the point that people's faces are tinted an obvious crimson ...
Why do we bother to buy these meters if they're just going to lose their accuracy in a relatively short amount of time?
My follow up question, is, of course: is there a relatively affordable meter that doesn't itself need to regularly be re calibrated?
Tangled Cable is offline
post #2 of 5 Old 07-20-2013, 02:53 AM
nodixe's Avatar
Try i1pro spectrophotometer....
Sent from my Nexus 7 using Tapatalk 4 Beta
nodixe is offline
post #3 of 5 Old 07-20-2013, 06:07 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Same reason we go to Harbor Freight to buy a hammer drill that will only work for 1 project if you are lucky.. the cost of a quality product is less than the amount of money we are willing to spend so we buy the cheap stuff. Only thing wrong with that is when we thing the cheap stuff is supposed to be like the good stuff and get all upset when it won't drill the hole in the reinforced concrete and then breaks 2 days after warranty is up or is DOA out of the box before the project starts. People are suckers for Cheap especially if they think they will only use a tool once or twice..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 5 Old 07-20-2013, 06:12 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
No, even the $8000 spectros need to be checked and re-certified. If you don't do that how do you know they are accurate? The current i1 Display Pro, is the follow on to the entry level colorimeter and has sealed optics that as supposed to last much longer than what you currently have. However you still need to profile against a spectro for the most accurate results. A used i1pro spectro can be had now for about $300, have it certified (not sure what that costs) and you can profile your current meters if they are not to far gone and they will be much more accurate.
Do a forum search on meter profile for more info, there are many many many posts on this very subject.
Doug
post #5 of 5 Old 07-20-2013, 11:07 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
The i1 Pro Spectrophotometer is incredibly durable as are the new i1 Display Pro.
If you are just a hobbiest either of those choices should give you years of reliable calibrations. For a professional you want to get your meter certified every year, but that's because you are staking your reputation and taking money based on the fact that you have accurate gear.
PlasmaPZ80U likes this.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Reply Display Calibration
