Panasonic TC-50LE64 calibrations? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-05-2013, 12:56 AM - Thread Starter
shadh's Avatar
Hi all,
New to AVS forum and I recently purchased the Panasonic TC-50LE64 from costco. I was wondering if any one had calibrations they can post or could direct me to a place to find some.
Thank you in advance
shadh is offline
post #2 of 8 Old 08-05-2013, 01:16 AM
nodixe's Avatar
Quoted: 32 Post(s)
Should probably look for a thread specific to your model in the lcd or plasma sub-forums, in your case lcd.
Sent from my Nexus 7 using Tapatalk 2
nodixe is offline
post #3 of 8 Old 08-05-2013, 01:25 AM - Thread Starter
shadh's Avatar
I searched the forums and did not find a thread.. I'm not finding any calibration information on google either. I'm feeling like maybe getting the Samsung UN50F6350AF Costco offered would have been better for getting a good calibration.. Hope i'm wrong
shadh is offline
post #4 of 8 Old 08-05-2013, 04:39 AM
Rayjr's Avatar
Quoted: 182 Post(s)
Liked: 223
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
If you really want "a good calibration"...how about getting a calibrator to adjust your display?
Copying someone else's number is far from "a good calibration"
Just my $.02
RayJr
Rayjr is offline
post #5 of 8 Old 08-05-2013, 06:31 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
As Michael from tlvexp.ca showed in a test, in most cases copying setting will actually "de-calibrate" the tv, meaning it makes it less calibrated instead of calibrated. It makes the picture worse 9 times out of 10
To clarify, components that consumer tv are made of have a tolerance of about 10%. They are stable in what they do, but the difference between two identical components might be 10%. If you realise how many components there are in a single tv, you also realise that each tv needs to be calibrated individually.
Wouter73 is offline
post #6 of 8 Old 08-05-2013, 02:39 PM - Thread Starter
shadh's Avatar
So using someone else's as a baseline and adjusting from there is not recommended?
shadh is offline
post #7 of 8 Old 08-05-2013, 03:44 PM
CooLJ92's Avatar
Every set is different. Add your viewing environment to it and some else's settings may not work for you.
CooLJ92 is offline
post #8 of 8 Old 08-05-2013, 04:29 PM
GeorgeAB's Avatar
Location: Denver, CO metro area, www.cinemaquestinc.com
Quoted: 147 Post(s)
Liked: 256
Most displays come from the factory already with a so-called "baseline." It's a preset picture mode called "Cinema," "Movie," or an equivalent. Using someone else's numbers is just a roll of the dice and may actually end up with certain image characteristics worse than the factory preset on your sample of TV. You have been influenced by a persistent, widespread myth in the home theater community, and these types of forums, that appeals to the low energy, impatient, misinformed, wishful, naive, and confused video consumer. Here are some more links that explain why copying others' work is not reliable:
'Sharing display menu settings?'
http://www.avsforum.com/avs-vb/showthread.php?t=1055906
'Why copying settings from the web won't get you a calibrated TV'
http://forums.hdtvtest.co.uk/index.php?topic=7202.0
Best regards and beautiful pictures,
G. Alan Brown, President
CinemaQuest, Inc.
A Lion AV Consultants affiliate
"Advancing the art and science of electronic imaging"
GeorgeAB is offline
Reply Display Calibration
