Gamma with normal windows or with APL? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 194 Old 11-07-2013, 12:11 AM
ConnecTEDDD's Avatar
Quoted: 1671 Post(s)
Liked: 2081
Originally Posted by Barsk View Post
How did we end up with this mess? I guess the old Pioneer Kuros measured better and more linearly as they did because they did not employ ABL and let the power consumption flow freely. When Panasonic and others took over they tried combat the huge power consumptions with new techniques - ABL and possibly others that affect the panel drive which we don't have a name for. What they do however is not only lowering power by varying luminosity. They do it unfortunately in a non-linear way that cases the color shifts and color luminosity shifts at different pattern sizes. I can only see that as a bug. How the heck can they let that crap out of the lab...?
My conclusions here may be wrong. Please enlighten me if that is so!
+1, TV's Low Power Consumption Labels marathon and LifeStyle TV Slim Fashion destroyed the picture quality, so sad frown.gif
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #92 of 194 Old 11-07-2013, 05:50 AM
Quoted: 1701 Post(s)
Liked: 731
HDTVtest was the review I saw ABL mentioned in.
Looks like it's a pain to calibrate.
JimP is online now
post #93 of 194 Old 11-07-2013, 03:18 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 353
Let's hope that OLED is indeed better in this regard.
Kuro TVs had and have as much ABL as any plasma. That has nothing to do with anything. As far as I know, all those great calibrations of Kuro TVs were done with standard window patterns covering 10%-12$ of the screen area with black backgrounds. And that's the case for most plasma TVs. There has never been a plasma TV produced without ABL because the amount of heat generated would be HUGE ---- AND ---- the power supplies would have to be able to deliver more than double the amount of power in any given plasma TV model in order to NOT have ABL. And that all assumes the conductors carrying voltage/current to the plasma panel are of sufficient gauge to not current-limit the voltage supplied to individual pixels (which would also cause ABL).
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #94 of 194 Old 11-07-2013, 11:32 PM
Barsk's Avatar
Quoted: 36 Post(s)
Thanks for the clarification on ABL and Kuros!
Still, the issues with non-linear color saturation response with regard to intensity is a severe problem. At least with my european VT30 version. Saturation tracking is nowhere nere where its should be, and with different intensities the results vary. This is with the ISF settings on my VT30. I tried calibrating to a 75%/75% color pattern and ended up with too much oversaturated colors at the edges. The funny thing is that with the Cinema setting there is no CMS, but colors seems really great anyway. Will do a thorough test on saturation tracking on that setting as I speak... Sad thing about that setting is that gray scale is not as accurate as I can get it in ISF. But whatever works best all in all will be my choice...
Does anybody know of a firmware setting that may help get a more linear response out to the ISF settings?
Barsk is offline
post #95 of 194 Old 11-08-2013, 08:16 AM
ndaa75's Avatar
http://www.avforums.com/threads/panasonic-vt30-calibration-settings-thread.1463408/page-7
Post #193
Some good advice there...
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #96 of 194 Old 11-08-2013, 09:50 AM
turbe's Avatar
Liked: 97
There is an optional f/w for calibrators (only manual install available) that addresses things in regards to what you have posted. However, it was only released for North American 30 Series models.
And the 9G Kuro Monitor's ABL performance is different (for the better) than the other Kuro TV Models and any Plasma since. Regulations were also different back then.
Post #193
Steve (Bumtious) also uses ControlCAL G/VT30 Edition v2 on the Panasonics, which allows you to calibrate without the menus up, and more.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #97 of 194 Old 11-08-2013, 01:16 PM
ndaa75's Avatar
+1
ndaa75 is offline
post #98 of 194 Old 11-08-2013, 01:49 PM
Quoted: 188 Post(s)
Liked: 353
Different in what way? When they were setup for low 30s fL for a (10% area) window pattern, they still measured below 20 fL for full-screen 100% white.
THX -- ISF -- HAA
post #99 of 194 Old 11-09-2013, 02:10 AM
Barsk's Avatar
Quoted: 36 Post(s)
Post #193
I will look into that thread, thanks!
About the CMS issues with my european VT30. I have found that the non-linear response is actually reversed when using 10% APL patterns instead of using ones with black background. Instead of the lower saturation targets being undersaturated they become oversaturated. This is much more inline with the problems I see after calibration with 10% patterns. Colors in real-life images are oversaturated. Decreasing saturation clearly improves the image. Seems picking the right size APL pattern and calibrating CMS at lower saturations should possibly bring me closer to a good compromise. Need to find out what pattern to use though. I guess trying different ones and see which one comes closes to cinema or THX settings is the one to use in mys ISF setting.
Btw, the problems with saturation shifting with amplitude that I mentioned earlier was not true. Tried that with the GCD disk and tracking was Ok. Shifting is due to which patterns are used. Clearly ABL is playing in here.
Calibrating this beast seems is like shooting a moving target. It is NOT as easy as Doug suggested. Grayscale seemed Ok with 10% pattern, but gamma becomes way to contrasty. Tried in 4% apl and things gets much better. The standard uncalibrated gamma settings still seems brighter and more pleasing to the eye though. Not sure though.
It might be the case that the alternative f/w that you have in the US is actually solving the issues I have - but there is no alternative f/w for us here. Too bad.
Barsk is offline
post #100 of 194 Old 11-09-2013, 03:08 AM
ndaa75's Avatar
Have a look into that thread I linked since it contains a lot of answers to the issues you're experiencing.
ndaa75 is offline
post #101 of 194 Old 11-10-2013, 02:44 AM
Barsk's Avatar
Quoted: 36 Post(s)
I have to confess I was partly wrong in my assessments above. And an apology to Doug!
I did six different full measurments with grayscale, primaries/secondaries and full saturation sweeps with different pattern types and sizes, i.e 4% APL, 10% APL and standard 10% windows and in fact grayscale did NOT change as much as I previously thought. CMS readings with saturation sweeps pretty much was identical over all these patterns. Where I got the impression that saturation non-linearity switched from undersaturated to oversaturated I don't know. I might have been a bug in HCFR 3.0.5.2 that I was using. The latest version 3.1.0.0 has fixed some bugs in that regard.
Gamma did not change too much either with these patterns. I switched to standard display gamma instead of the Bt.1866 gamma option I was using and that evened out any differences considerably.
I ended up calibrating CMS with a 75% A/75% S pattern to find a good compromise. The TV is still non-linear in regard to saturation levels 25% - 100%. The saturation and luminosity shifts considerably here. 75 A/ 75 S seems a good spot to use for a compromise for my VT30. These errors are the main pitfalls of this set, but I think I found a working compromise here.
Will look into the mentioned thread for more info though. Thanks.
Barsk is offline
post #102 of 194 Old 11-10-2013, 05:06 AM
ndaa75's Avatar
Agree with you in respect of the saturation and luminosity shifts. I compromised by correcting the lum/sat on a 60s pattern which yielded improvements across the saturation ranges.
ndaa75 is offline
post #103 of 194 Old 11-10-2013, 07:04 AM
womanpiaola's Avatar
i agree with you, you should ask your buddy Silly Sally,I'am pretty sure he will give you the correct answer on which pattern is correct
qhWv
womanpiaola is offline
post #104 of 194 Old 11-11-2013, 02:17 AM
Barsk's Avatar
Quoted: 36 Post(s)
I see a post from you on the vt30's thread that you calibrated color with a 75A/100S pattern back in 2012. Now it seems you use a 60S-pattern. Where did you get that pattern and why did you settle on that specific pattern?
What I found with my own compromise, a 75/75 pattern from the GCD disk was that color still was off on real life video. Tried on a whim to decrease lightness on green and that did it. At least partly. That tells me I have not found the best compromise pattern. I would really like to find a "middle point" of all these non-linearities and calibrate there, knowing that color will always be off at the extremes, but at least accurate in the middle range.
Trial and error I guess...
Barsk is offline
post #105 of 194 Old 11-11-2013, 02:29 AM
ndaa75's Avatar
Well as a newbie to this type of thing, the VT30 has provided me with an excellent education in calibration with much trial and error on this set to get it looking good, and I literally have tried everything.
The patterns I use are custom made and are available on my disk that I authored for use with Calman 5.
ndaa75 is offline
post #106 of 194 Old 11-11-2013, 11:21 AM
Barsk's Avatar
Quoted: 36 Post(s)
Zoyd tipped me about his CC6 mode that is available in both the MCD and GCD disks. It is supported in latest HCFR as a special color space. Haven't tried it yet but it is supposed to cover patterns of low saturations amongst others.
Barsk is offline
post #107 of 194 Old 11-11-2013, 11:59 AM
ndaa75's Avatar
You mean colour checker right? Yes, calman has this too, in fact 24 colours. My disk covers these.
ndaa75 is offline
post #108 of 194 Old 11-11-2013, 12:40 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
No, he means that HCFR has a mode in which 6 of the color checker patterns are used as pseudo-primaries/secondaries. So you can calibrate to them like you do to 75%S patterns or 100%S patterns.
zoyd is offline
post #109 of 194 Old 11-11-2013, 12:51 PM
ndaa75's Avatar
Gotcha.
You can of course perform exactly the same task in Calman,
Nice touch nevertheless.
ndaa75 is offline
post #110 of 194 Old 11-12-2013, 01:12 AM
Barsk's Avatar
Quoted: 36 Post(s)
On the subject of the "right" pattern for calibrating CMS on the VT30 I followed Zoyd's recomendation to use 4% APL patterns from the Mascior's disk and to my surprise I found that with these patterns the saturation tracking was mostly flawless. Also luma levels was fairly even across saturation levels 25%, 50%, 75%. At 100% luma still drops a bit.
This was NOT the case with 10% windows where the lower sat colors was showing as undersaturated and luma levels fluctuated a great deal. So with 4% APL the I only needed minor adjustments to saturation and lightness and then I was done!
Also grayscale was easier to calibrate with the 4% APL. I found myself removing a lot of the 10pt adjustments I had done with the 10% windows patterns. It just became flat without effort. HCFR gave me "Awesome calibration" in both grayscale, and primaries/secondaries calbrations, and "Very nice" in the saturation tracking departments. No problems getting a flat gamma either.
I did not have time to also check with the CC6 mode, but I would expect it to fall in line nicely too.
Did only some reference video checks (too sleepy), but at least Stargate Atlantis looked great, which it did'nt before. Will have to investigate further before I can decide if I am "done" yet... smile.gif
Barsk is offline
post #111 of 194 Old 11-12-2013, 03:54 AM
ndaa75's Avatar
Couple of points. Using patterns that 'fit' your graphs do not necessarily mean they're accurate for your set.
If I use 1% windows I get a completely different calibration! likewise if I use 7.5% windows, so on and so on. Which are correct?
Grayscale will differ with different pattern types, additionally trying to calibrate gamma on this set to a flat line In fact most plasmas I believe) Is like chasing a moving target - what does achieving a flat line gamma mean in real terms?
Did you read bumtious recommendations in the thread I linked? As I said some very helpful advice there which shouldn't be overlooked IMHO.
Anyways the most important thing here is that if you're happy with you're calibration then you're done!
ndaa75 is offline
post #112 of 194 Old 11-12-2013, 11:36 AM
Barsk's Avatar
Quoted: 36 Post(s)
I know all of that, i.e learnt during the last two weeks...
Regarding the way that the patterns fitted the default settings in my TV I believe that I am somewhat close to the methods that the Panasonic engineers have used when they made the generic calibration for all the VT30s. If I am using a pattern or methodology that makes me use extreme settings to calibrate a display then for me it is a signal that I am on the wrong track. Most often in the past these attempts has been futile with banding and other ill effects.
I didn't claim that my calibration is perfect. I am still evaluating. For grayscale it seems pretty much perfect. For color. Hmm. Still off with orange-tinted faces... It may be that I will never hit the target here. I am beginning to feel this TV is flawed. I have never gotten proper colors off this beast regardless of patterns...
My LG LCD with IPS panel in the upper room has so much cleaner colors and great PQ even without calibration that it is rediculous to compare. And the LG is 1/3 of the price of the panny... Of course LCD has other problems that the plasma has not, but still. In the color department it shines!
Well, haven't given up yet on the plasma. Will look into that thread you mentioned to see if I can find anything. Remember though that the US and the european f/w differs so all may not apply.
Barsk is offline
post #113 of 194 Old 11-12-2013, 12:23 PM
ndaa75's Avatar
You have a euro set right?
Oh yes, the thing with this set is that you think you have everything right until you realise it's not! As I said read that post by bumtious - the advice given is the valuable yet I have seen on this particular display.
ndaa75 is offline
post #114 of 194 Old 11-12-2013, 02:05 PM
Barsk's Avatar
Quoted: 36 Post(s)
A euro set yes.
Rechecked on my Apple TV with Netflix and it does look quite nice so far actually. On the DVB-T input however it looks plain bad with orange faces. Yes I know the TV broadcasts are extremely off at times. But the channels I check is normally of high quality. Strange it differs that much. Still evaluating though... Have some reference stuff to look through on BD.
Barsk is offline
post #115 of 194 Old 11-12-2013, 02:27 PM
ndaa75's Avatar
A euro set yes.
On mine, blu ray is stunning - freesat HD though has a clear pinkish hue to it which I need to look at when I have some time.
ndaa75 is offline
post #116 of 194 Old 11-12-2013, 11:37 PM
Barsk's Avatar
Quoted: 36 Post(s)
Thinking of calibrating REC 601 or PAL standard and using that on DVB-T input only. I guess it is better to have slightly undersaturated on the HD channels than have overblown colors on SD channels. In theory the differene is minor, but with this set it might be worthwile.
Barsk is offline
post #117 of 194 Old 11-13-2013, 07:35 AM
Light Illusion's Avatar
Quoted: 502 Post(s)
Liked: 794
Do remember that virtually all SD material today is actually mastered in Rec709, and is not colour-space converted when the image is changed from HD (or 2K, etc) to SD.
I would actually recommend for home cinema calibration Rec709 is used for all formats.
I say this as I have owned my own own post-production company in Soho, and today the majority of our customers are the professional post facilities and broadcasters.
Steve
anta1974 likes this.
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #118 of 194 Old 11-13-2013, 07:45 AM
ndaa75's Avatar
As my curiosity is starting to get the better of me again im going to have to have a go at using 1% APL's this weekend and do a visual comparison to the 10% windows calibration.
Again, I will not be touching any 10pt gamma controls as there appears to be absolutely no point.
ndaa75 is offline
post #119 of 194 Old 11-14-2013, 02:15 AM
Barsk's Avatar
Quoted: 36 Post(s)
Steve
Thanks Steve!
Good to hear that clarification from a Pro! Rec 709 it is then!
Barsk is offline
post #120 of 194 Old 11-14-2013, 02:49 AM
Liked: 2081
Steve
Thanks Steve!
BTW, the list of Post-Production Studios that are using LightSpace is huge, take a look here.
Reply Display Calibration
Panasonic Tc P65vt60 65 Inch 3d Smart Plasma Hdtv , Samsung Pn64d7000 64 Inch 1080p 600 Hz 3d Plasma Hdtv Black
