Colorimeters and Spectrographs, Questions - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 56 Old 08-31-2013, 02:47 PM
PlasmaPZ80U's Avatar
Quoted: 1963 Post(s)
Liked: 559
reference spectro > affordable spectro > high end colorimeter > affordable colorimeter
for example:
JETI 1211 > i1Pro2 > Klein K-10 > D3
are there cases where the colorimeter outperforms the spectro? probably, but then there are cases where even the 'cheap' spectro outperforms the high end colorimeter
generally speaking, spectros are more consistently accurate than colorimeters
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #32 of 56 Old 09-23-2013, 11:03 AM
Liked: 559
here's a new article focused on FOV alone (based on the meter tables article):
http://www.tlvexp.ca/2013/09/field-view-dreams-matter-hosed/
post #33 of 56 Old 09-28-2013, 01:36 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
I would like to provide some more data to this discussion. I compared the response of a brand new out-of-the-box i1Pro 2 with a brand new out-of-the-box stock D3 OEM. I used 5 different display types.
CRT
LED
LCD
Plasma
Projector (UHP)
Then I compared WRGB measurements of the i1Pro 2 and the uncorrected D3 with my JETI 1201. Here's what I got.
The i1Pro 2 does better on the plasma and slightly better with the CRT, but with the LCD, LED, and projector the errors are essentially the same. Overall, the error rates between the i1Pro 2 and stock D3 are almost exactly the same. Given that the sensitivity of the D3 is vastly superior to the i1Pro 2, I am a little puzzled by this repeated insistence that modern colorimeters simply cannot be trusted and you are generally better off with a budget spectro. With a properly calibrated D3, even the color accuracy would have been better than the i1Pro 2.
I know of only two other published examples looking at this. One is Michael's, which has been discussed here. However, this is not really an evaluation of the D3's accuracy. It is an evaluation of one of the correction tables on his C6, which is clearly defective. The other comparison I know of was published here. As with my test, it also failed to show any real advantage when using budget spectros.
I have an open mind about this, but I have personally measured hundreds of D3s on multiple displays prior to calibration. The errors I see are very small. I have also tested the i1Pro repeatedly throughout the years. It, too, shows small errors. However, unlike the D3, its relatively poor signal-to-noise ratio affects it performance with low light sources.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
post #34 of 56 Old 09-28-2013, 01:40 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
I completely agree with this. Unless you are measuring a display with extremely poor uniformity or have moved the sensor so far back that its read area exceeds the display area, FOV shouldn't make much difference.
Tom Huffman
Springfield, MO
post #35 of 56 Old 09-28-2013, 09:17 AM
Quoted: 1393 Post(s)
Liked: 587
Tom .... nice right up.
Is there a way to calculate whether or not these differences from your Jeti are visible?
JimP is offline
post #36 of 56 Old 09-28-2013, 10:33 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
Sure. In CIE94 units.
Tom Huffman
Springfield, MO
post #37 of 56 Old 09-28-2013, 10:23 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
thanks for sharing this data Tom. My i1 pro just arrived today, and a selfish part of me was hoping that these results would show that the i1 display pro wasn't as good when not profiled to a particular display. Though I'm sure it'll be handy considering I have an old DTP 94.
Quick question: in that last table you posted, what do the different rows represent?
spacediver is offline
post #38 of 56 Old 09-29-2013, 02:05 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
WRGB in each of the display types (4 colors x 5 display types).
Tom Huffman
Springfield, MO
post #39 of 56 Old 09-29-2013, 02:13 AM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
got it, thanks
post #40 of 56 Old 09-29-2013, 04:05 AM
Andrei_VVB's Avatar
Quoted: 82 Post(s)
Liked: 29
Are these results for i1displaypro with spectral corrections for each display type?
Andrei_VVB is offline
post #41 of 56 Old 09-29-2013, 11:23 AM
rahzel's Avatar
Liked: 148
No, the measurements Tom has taken with the D3 were done with no corrections at all.
rahzel is offline
post #42 of 56 Old 09-29-2013, 07:58 PM
Andrei_VVB's Avatar
Quoted: 82 Post(s)
Liked: 29
Since disp 3 offers this opportunity in the actual driver, to load a correction for each type of display, it will be interesting to see if the differences are even smaller or if these corrections are not suitable for use.
post #43 of 56 Old 09-29-2013, 09:18 PM
Liked: 559
perhaps there is plenty of variation between different LCD/LED samples, which could explain the difference between your results and Michael's... just a guess
post #44 of 56 Old 09-29-2013, 10:42 PM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
Again, Michael tested a specific C6 profile, not the D3 meter itself. Apples and oranges. Both his results and my results can be valid at the same time.
Tom Huffman
Springfield, MO
post #45 of 56 Old 09-29-2013, 11:07 PM
sillysally's Avatar
Quoted: 827 Post(s)
Liked: 848
Thanks Tom, how does the K10-A compare with your JETI when calibrating a Plasma. ?
Would profiling a K10-A with a I1Pro 2 be helpful when calibrating a Plasma. ?
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #46 of 56 Old 09-30-2013, 02:47 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
The K-10 is no better in the color accuracy dept. It's strength is speed and low light sensitivity, which is truly awesome.
Yes, it probably would.
Tom Huffman
Springfield, MO
post #47 of 56 Old 09-30-2013, 05:11 AM
ConnecTEDDD's Avatar
Quoted: 1053 Post(s)
Liked: 1517
ss
Klein is using a Panasonic Model TC-P42GT25 at their labs to create the Plasma Table using a Konica Minolta CS-2000 Spectroradiometer as a reference.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #48 of 56 Old 09-30-2013, 06:42 AM
Liked: 1517
Tom, since you are using JETI 1201 to create the correction tables, can you provide some data of how many time it takes with 1201 to read each one of the WRGB patches, by measuring a display with peak white of 100 cdm/2 ?
with JETI 1211, measuring a Plasma display with 102cd/m2 peak white it takes (using LightSpace):
For White: 102 cd/m2 - ~1249 ms per read,
For Red: 25 cd/m2 - ~1232 ms per read,
For Green: 71 cd/m2 - ~1249 ms per read,
For Blue: 10 cd/m2 - ~ 1747 ms per read.
post #49 of 56 Old 09-30-2013, 07:12 AM
Liked: 559
aren't some of the C6's tables directly from X-Rite (same as the D3 OEM/retail version)? like the LCD Direct View (White LED) and LCD Direct View (CCFL)?
post #50 of 56 Old 09-30-2013, 08:50 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Yes they are, and I believe at the time of the test, only the stock xrite white LED table was in the meter. Since then we've added an additional white LED table and a RGBY white LED table.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #51 of 56 Old 09-30-2013, 09:30 AM
Liked: 559
is the 'additional white LED table' the wide gamut one?
post #52 of 56 Old 09-30-2013, 11:07 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Yes and it's more of a standard gamut than truly wide, just much wider than the standard PC under-saturated white LED which the OEM table was developed for.
Joel Barsotti
SpectraCal
sotti is offline
post #53 of 56 Old 10-01-2013, 11:39 PM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
See below. This is integration time, so read time is roughly double this.
Tom Huffman
Springfield, MO
post #54 of 56 Old 10-02-2013, 01:24 AM
Liked: 1517
Thank you Tom, for running this test.
post #55 of 56 Old 10-29-2013, 03:31 PM
MonarchX's Avatar
Liked: 31
I own an X-Rite i1 Display Pro colorimeter. It is good enough for your average home non-pro calibration? Is it better or worse than Spyder3? I own Samsung LN40B550K HDTV, which is just your average S-PVA panel. I hope that my colorimeter provided me with enough accurate data.
MonarchX is offline
post #56 of 56 Old 10-30-2013, 01:16 AM
realzven's Avatar
Liked: 84
The i1 display pro is better than the spyder 3 :
- better repeatability
- more acurate
- more stable
- faster
ConnecTEDDD likes this.
realzven is offline
Reply Display Calibration
