Lumagen Announces 9-Point Cube Gamut (729 Color Points) for the Radiance 20XX - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 11-07-2013, 09:30 PM
Citation4444's Avatar
Quoted: 185 Post(s)
Liked: 145
Originally Posted by sillysally View Post
Originally Posted by Citation4444 View Post
fwiw, I have a 2041 and use 4:2:2. I din't see what you are describing using a 17^3 profile. I would ask if maybe you did a video scale (only use for eecolor box) in LS tools, then transferred the file to your 2042.
But it seems that if RGB and 4:4:4 are fine I don't think that is the problem.
I ended up using my eecolor box for a 17^3 LUT. I thought the 9^3 was good, but the 17^3 LUT is better.
ss
I know that video scaling is required only for the eeColor box and not for the Lumagen, so no I did not do video scaling. Have you checked the brightness patterns from Ted's disk (or another calibration disk) when using YCbCr422 output, and not the internal Lumagen brightness pattern? It's not subtle at all as the levels and colors are significantly off. It is noticable in test patterns but not so much in normal video images.
Also, like you, until this issue is resolved, I have switched back to using my eeColor box using a full 17 side LUT.
Citation4444 is online now
Old 11-07-2013, 10:04 PM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 848
No I only used the test patterns in the 2041.
It looks like I will have Ted disc tomorrow, if somebody is here to except the disc. Now where is the wife..
Let us know what you find out. Just got a killer 17^3 profile that I am installing in the eecolor box as I type.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
Old 11-08-2013, 08:03 AM
Quoted: 185 Post(s)
Liked: 145
Here are a couple of Chromapure captures that show what I'm experiencing. Before I did these runs I did a factory reset of the Lumagen 2042, did a quick profile using LS and uploaded it into CMS0. The problem reared itself again just as before. The only change in the two captures below is a change in style. In the first the style is set for RGB output. On the 2nd one the style is set for YCbCr422. Both these runs use the same meter as was used in LS. However, in LS it was profiled to my i1Pro2 while it's not in the Chromapure runs.
Here's the RGB run:
Here's the YCbCr422 run:
Again, everything is fine except when I set the Lumagen for 422 output.
Old 11-08-2013, 02:29 PM
Quoted: 185 Post(s)
Liked: 145
I have further determined that this problem only occurs when the input is 24p as the calibration disks are.
Old 11-08-2013, 04:22 PM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 848
So the issue is with the Lumagen.
I will convert last nights 17^3 profile into my 2041, then use CM5 and run the numbers. I will use a K10-A and last nights profile using a Jeti as reference meter, to take the readings.
I will update this post with what I find.
Remind me never to bet with you over a game of Golf. smile.gif.
ss
Old 11-08-2013, 05:19 PM
Quoted: 185 Post(s)
Liked: 145
When you make these calibration checks, make sure you use a 24p source for Calman. I think this means the AVS disk, Ted's disk, or another 24p disk.
Old 11-08-2013, 06:11 PM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1077 Post(s)
Liked: 1542
Bob, is this happening only when you are measuring using a pattern disk as a source? or it happens with internal pattern generator with output @ 24p?
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
Old 11-08-2013, 08:01 PM
Quoted: 185 Post(s)
Liked: 145
It also happens with the internal pattern generator when the output is 24p. If I set up the Oppo to output 60p instead of 24p this does not happen. i.e., it only happens when the source is 24p, and it shows with both the patterns from your disk as well as the internal patterns.
Old 11-08-2013, 08:33 PM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 848
I used source direct setting in the Oppo.
When I ran the profile I used 1080P24 in the 2041 for output of the 5% window, no APL.
Don't forget the pattern window in AVS is about 11%, and I used the 2041 as a pattern generator set a 5% window when I ran the Profile.
Hope this helps.
ss
btw, you may want to ask around if there are issues with using 1080p24 setting in the Oppo.
Old 11-08-2013, 09:31 PM
Quoted: 185 Post(s)
Liked: 145
Thanks ss!
Your post led me to try setting up my Oppo for source direct like yours and my problem went away! Poof, gone. I reset mine as it was before (1080p and 24p turned on) and now I can't reproduce the problem at all. So, it turned out to be a problem with my Oppo setup screwing up its 24p output. Thank you so much for steering me to try a different Oppo setup.
Now maybe I can concentrate on shooting my age! I've come close a couple times, but always choke on the last hole when I realize I'm getting close. smile.gif
Old 11-09-2013, 07:18 AM - Thread Starter
Liked: 1542
Thanks ss!
Ted's LightSpace CMS Calibration Disk is 24p: MPEG-4 AVC High Profile 4.1
AVSHD Disk is 23.976p : MPEG-4 AVC Main Profile 4.0
NOTE: The High Profile improves compression quality (up to 12 percent for progressive HD video and film sources) while adding almost no computational complexity (but a slight memory increase) over Main Profile. The profile adds switchable transform and scaling matrices to achieve the improvement. Devices such as the Sony PlayStation and all current Blu-ray disc players support the High Profile.
Old 11-22-2013, 11:06 AM
CIH USER
Franin's Avatar
Quoted: 2192 Post(s)
Liked: 1313
This is my first time I'm trying 3D Lut as I moved from Calman Control to Enthuiast. I started the autocal but I didn't realised how long it goes for ( started at midnight ) by 2am I was at 524 points. I had to cancel as I had to go to sleep for work in the morning but is that normal for it too take that long?
_________________________
Franin is offline
Old 11-22-2013, 02:17 PM
realzven's Avatar
Liked: 84
It depends on the meter and parameters from calman.
what is your colorimeter ? display pro ?
realzven is offline
Old 11-22-2013, 05:09 PM
CIH USER
Franin's Avatar
Liked: 1313
Yes the colorimeter is the I1 Display Pro
Franin is offline
Old 11-22-2013, 06:04 PM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
Just run the autocal before you go to bed. When you wake up in the morning, it should be done.
1forsnow is offline
Old 11-22-2013, 10:24 PM
CIH USER
Franin's Avatar
Liked: 1313
Thank you, did not realise it took that long
Franin is offline
Old 11-24-2013, 04:09 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
It will take anywhere between 2-4 readings per point. Usually just under 3 readings. So if you do a full 9x9x9 that 's 729 points you should expect around 2000 reads. With a C6 set on single sample that should take about an hour and a half. If you have a slower meter or your pattern delay is larger (You should be able to get away with 0.5-1.0) than it may take longer.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 11-24-2013, 10:19 PM
CIH USER
Franin's Avatar
Liked: 1313
Thanks Sotti for your reply. With a C6 set on a single sample, what do you mean by that ? Still a novice here trying to learn.
Franin is offline
Old 11-24-2013, 10:44 PM
Rolls-Royce's Avatar
Quoted: 244 Post(s)
Liked: 369
I use an I1D3. Full 9X9X9 runs with grayscale are taking about 1:35-1:45 total. That's actual reading+adjustment time not including any time that may have been lost between grayscale and cube runs.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
Old 11-25-2013, 05:11 AM
DrFaxe's Avatar
Quoted: 14 Post(s)
Liked: 84
The number of samples are the amount of readings. 1 sample means that the meter reads the pattern 1 time. With e.g. 3 samples the meter reads 3 times and the results will be avaraged. So higher sample rates are more accurate, but slower.
DrFaxe is offline
Old 11-25-2013, 06:09 AM
CIH USER
Franin's Avatar
Liked: 1313
Franin is offline
Old 11-26-2013, 10:04 AM
CIH USER
Franin's Avatar
Liked: 1313
Redid my whole calibration last night this time able to see finishing touched of the 9x9x9 729 point 3D lut performance ( first time ) and I have to say I'm very impressed. The pq really stood out, it looked absolutely stunning. I'm glad I was talked into buying the Lumagen. Best investment for pq in my HT.
Franin is offline
Old 11-26-2013, 10:37 AM - Thread Starter
Liked: 1542
Rolls-Royce likes this.
Old 11-27-2013, 05:08 AM
CIH USER
Franin's Avatar
Liked: 1313
Franin is offline
Old 11-29-2013, 01:58 AM - Thread Starter
Liked: 1542
CalMAN 5.2.1 Build 1386 Open Beta is available for download.
Release Notes
Added support for the Video Forge II HDMI
Added support for the JVC 840
Added support for APL patterns on the Lumagen Radiance
Fixed issue on the 3D cube workflow which caused no data to appear on the View 3D Luminance layout
Fixed firmware compatibility for the PR700 series meters
Auto Advance will now advance to the next color group on gamut luminance and gamut saturation run types.
Old 12-04-2013, 03:11 AM - Thread Starter
Liked: 1542
Lumagen Radiance XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D + Radiance 20XX Series (2021, 2022, 2041, 2042) New 112513 Firmware Update
Release Notes
Fixes audio issues seen that could give noise or no audio with some equipment.
Added a shorter option for audio mute length under Input: Audio Setup: Mute Control. The default is mute length is "Long" but options include Short, Medium, and Long. Previously, the options were only Short and Long which have now become the Medium and Long values.
Several small menu improvements and fixes.
Small improvement in input switching speed.
Download Link
Old 12-06-2013, 01:22 AM - Thread Starter
Liked: 1542
Lumagen has update their tech tips documents to include informations about Variable Size and APL test patterns.
Tip 5- Using test patterns Download (112013)
Old 12-06-2013, 01:20 PM - Thread Starter
Liked: 1542
Lumagen Radiance XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D + Radiance 20XX Series (2021, 2022, 2041, 2042) New 120213 Firmware Update
Release Notes
Fixed up an older bug (recently made worse in 112513) which depending on equipment and settings could intermittently (or regularly) result in delaying turn-on of video output. Could be double normal output turn-on time and feasibly even longer.
Bugfix for issue created in 112513 release causing an output to not turn on if only one output is connected.
Download Link
Old 12-09-2013, 06:15 PM - Thread Starter
Liked: 1542
Lumagen Radiance XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D New 120313 Firmware Update
Release Notes
Fix for some older HDMI/DVI displays (particular case was a DPI Titan 250) not showing video with last two firmware revisions (112513-120213).
Download Link
Old 12-11-2013, 02:45 AM - Thread Starter
Liked: 1542
ChromaPure 2.4.5 is now available for download.
Release Notes
New Features
•The 75% of Rec. 709 gamut is now available throughtout the software, including for reporting.
•We added support for 5% and APL test pattern windows to the Lumagen video processors.
•We have added support for the Video Forge signal generator. To use this you must run the free Proxy software Fiddler (http://fiddler2.com/) in the background.
Enhancements
•We have improved the methods used for Lumagen auto-cal that will especially enhance performance for displays with initial large measured errors.
•We added support for Measurement Smoothing in the Meter Correction module.
Bug Fixes
•We have fixed the Measure All macro in the Advanced Color Management module.
•We have improved the stability of the Gamma module when using Continuous mode.
