Lumagen Announces 9-Point Cube Gamut (729 Color Points) for the Radiance 20XX - Page 5 - AVS Forum
post #121 of 147 Old 12-11-2013, 12:12 PM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 120313 Firmware Update
Release Notes
Small fix for some older HDMI/DVI displays not showing video. (If you see video then you can skip this update) (Update time ~3 minutes @57k)
Download Link
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS + CalMAN ColorChecker
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, CalPC, ControlCAL
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #122 of 147 Old 12-17-2013, 12:42 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 120413 Firmware Update
Release Notes
Fix for an error in 112513-120313 updates which doesn't always get the input colorspace set up completely correct causing greens to be a little off and reporting incorrectly on the Info screen. (Update time ~3 minutes @57k)
Download Link
post #123 of 147 Old 12-19-2013, 11:33 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
LightSpace CMS 6.4.7.1790
A new version of LightSpace is now available.
This version includes:
-- Fixed occasional crash on first install
-- Improved Lumagen force re-set
-- Updated i1 Pro 2 SDK
-- Added additional warning for multiple probe connection
-- Overcome error in IS-Mini SDK
-- Fix occasional crash when disconnecting i1 Pro 2
-- Multiple Delete of Colour Spaces from library
DOWNLOAD LightSpace CMS Demo or Upgrade for Licensed Users
DOWNLOAD LightSpace DPS (Display Profiling System) Free Version License Request
post #124 of 147 Old 01-03-2014, 10:33 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
CalMAN 5.2.2 Build: 1404 Released @ 03 January 2014
New Features
Added support for the Video Forge II HDMI.
Added support for the JVC 840.
Added support for APL patterns on the Lumagen Radiance.
Added support for APL patterns on the Accupel 5000 (Grayscale only).
Added pattern size and APL sliders for pattern sources which support them.
Added a Reconnect Hardware on Startup option under Application preferences. When unchecked, CalMAN will not attempt to reconnect to any hardware upon application startup.
Changes
At the end of a series read or AutoCal, we will now go to a 10% full screen pattern instead of black.
Added black to the default run on the ColorChecker workflow.
Added support for the ColorChecker workflow for all license levels which have the Quick Analysis workflow.
Resolved Issues
Fixed issue on the Color Cube workflow which caused no data to populate into the Check Linearity and Verify Linearity layouts.
Fixed firmware compatibility issue for the PR 700 series meters.
Fixed connection issues with the PR 600 series meters.
AutoAdvance will now properly move on to the next color group on the Gamut Luminance and Gamut Saturation run types.
Resolved issue when creating 3D Cubes where CalMAN would just exit during the calibration process.
Fixed Quick Analysis workflow so the Targets button is now functional.
Made performance improvements which could cause errors when flipping through layouts.
Resolved issue where x-axis would always display on RGB Balance and Gamma charts when set to line.
Horizontal target line no longer shows up on CCT chart when set to Bar. Vertical target line is not currently displaying.
Download CalMAN 5 for Business 5.2.2 (Build 1404)
Download CalMAN 5 for Home Video Calibration 5.2.2 (Build 1404)
post #125 of 147 Old 01-08-2014, 12:15 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 110404 Firmware Update
Release Notes
Audio fix for no audio on initial power up. Audio fix for sometimes getting no audio when source changes audio formats. (Update time ~3 minutes @57k)
Download Link
post #126 of 147 Old 01-16-2014, 09:44 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
CalMAN 5.2.3 Build: 1415 Released @ 16 January 2014
Changes
Added the ColorChecker report (Display Calibration Certificate) at all Business level licenses.
Added Client 3 as a pattern source for the Basic and Control licenses.
Updated APL for finer control on supported devices.
Resolved Issues
Fixed issue where only 100% saturations were available for the DPGs and AVS disc.
Fixed issue with the new firmware for the DPG-2000. This version of CalMAN now requires at least firmware version 2.0.1.86. This new firmware can be downloaded here.
Fixed issue that was causing Collection Average for Gamut Saturation and Gamut Luminance sweeps to not update properly.
Fixed issue where Luminance Sweeps were reading 100%s twice for each color.
Fixed varied stability issues.
Download CalMAN 5 for Business 5.2.3 (Build 1415)
Download CalMAN 5 for Home Video Calibration 5.2.3 (Build 1415)
post #127 of 147 Old 01-16-2014, 03:42 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
CalMAN 5.2.3 Build: 1416 Released @ 17 January 2014
Changes
Added a check box for Check for updates under Application Preferences. Unchecking this will reduce the timing for updates to every 90 days.
Resolved Issues
Fixed issue with Saturations AutoCal.
Download CalMAN 5 for Business 5.2.3 (Build 1416)
Download CalMAN 5 for Home Video Calibration 5.2.3 (Build 1416)
post #128 of 147 Old 02-12-2014, 02:22 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 020114 Firmware Update
Release Notes
Fixed an issue when switching between 4k and 2k output modes where output style was not correctly used (2041/2042 only). Fixed an audio loss issue when changing between DTS-HD multi channel and DTS-HD 2 channel. (Update time ~3 minutes @57k)
Download Link
post #129 of 147 Old 02-19-2014, 12:55 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 020314 Firmware Update
Release Notes
Fix for an occasional frame stutter for 4K video output (so only applies if using 4K output of 2041/2042).
Eliminated test pattern blink for window patterns used by calibration software to allow for somewhat speedier calibrations. (Update time ~3 minutes @57k)
Download Link
post #130 of 147 Old 02-21-2014, 04:09 AM
Franin's Avatar
Quoted: 64 Post(s)
Liked: 181
Release Notes
Download Link
Thank you
ConnecTEDDD likes this.
_________________________
Frank
Franin is online now
post #131 of 147 Old 02-27-2014, 12:33 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New *BETA* 021814 Firmware Update
Release Notes
NEW Image Based Auto Aspect
We've expanded on the current input auto-aspect feature (in menu under "Input: HDMI Setup: Auto Aspect") to automate aspect selections based on the image as well as HDMI information.
So, for example, if you play a 2.40 BluRay the Radiance20XX can automatically select a 2.40 input aspect for you thus eliminating the top & bottom bars without you lifting a finger.
The new image detection will pick up letterbox and pillarbox formats so no more need to select the source aspect on the remote.
Works great now but more to be added. Give it a try and let us know how it works for you and what improvements to this feature you'd like to see.
This feature will only be available on the Radiance20XX and not older Radiance models due to hardware constraints.
NEW 2.40 Input Aspect
You can select a source aspect ratio of 2.40 now with 2 button presses on the remote, Alt- 2.35.
Soft Edge
Rounds the outside edges of the video off which gives movies a bit more of a theater look and can hide some issues at edges of displays.
This setting now available in the menu under "Output: Styles: Soft Edge".
(Update time ~15 minutes @57k)
Download Link
post #132 of 147 Old 02-27-2014, 03:46 PM
Franin's Avatar
Quoted: 64 Post(s)
Liked: 181
Release Notes
Soft Edge
Download Link
Frank
post #133 of 147 Old 02-27-2014, 03:58 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Soft Edge feature mainly is for projector screens; to soften the brightness of the overscan area to minimize the chance of noticing the overscan area on the screen border. (As Jim Peterson from Lumagen posted)
post #134 of 147 Old 02-28-2014, 04:54 AM
Franin's Avatar
Quoted: 64 Post(s)
Liked: 181
Ive updated the firmware so I'm curious to see how it works.
Frank
post #135 of 147 Old 02-28-2014, 05:55 AM
Franin's Avatar
Quoted: 64 Post(s)
Liked: 181
I just want write I've just tried it and it works !! Put on kick ass which has an aspect ratio of 2:40:1 and it automatically removed the black bars. cool.gif
Frank
post #136 of 147 Old 03-14-2014, 02:24 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 21XX Series (2123, 2124, 2143, 2144) New 041514 Firmware Update
Release Notes
Bugfix for HDMI inputs 5-8 sometimes not showing video.
Download Link
post #137 of 147 Old 05-13-2014, 12:12 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 050114 Firmware Update
Release Notes
Bugfix for some sources not showing video when switching to them.
Fix for missing colorspace change from Integra.
Fix for not getting lock on PCM output over coax output with Yamaha AVR. (Update time ~3 minutes @57k)
Download Link
post #138 of 147 Old 05-16-2014, 04:24 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2022, 2042) New 050914 Firmware Update
Release Notes
Bugfix for composite inputs (2022,2042 only) not working in 050114-050814 firmware. (Update time ~3 minutes @57k)
Download Link
post #139 of 147 Old 06-19-2014, 02:35 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 060414 Firmware Update
Release Notes
Precision improvements were made for color accuracy including test patterns. (Update time ~15 minutes @57k)
Download Link
post #140 of 147 Old 06-24-2014, 02:09 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 061014 Firmware Update
Release Notes
Fixes up a few bugs in some of the test patterns in the previous release. (Update time ~3 minutes @57k)
Download Link
post #141 of 147 Old 07-11-2014, 03:39 AM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070114 Firmware Update
Release Notes
Adds capability (for 2041/2042) to Auto output selection to select 4K output modes when appropriate based on the displays 4K EDID information---works with 4K Sony projectors.
A couple of APL test pattern fixups.
Speeds up test patterns.
Fix for sometimes incorrectly disabling a video output when changing between sources. (Update time ~3 minutes @57k)
Download Link
post #142 of 147 Old 07-12-2014, 12:22 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070214 Firmware Update
Release Notes
Bugfix for issue that can blank output video to an output when switching memories in some cases. (Update time ~3 minutes @57k)
Download Link
post #143 of 147 Old 07-14-2014, 05:24 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070314 Firmware Update
Release Notes
Fix for issue with rs232 test pattern usage that would often give a corrupted picture. (Update time ~3 minutes @57k)
Download Link
post #144 of 147 Old 07-15-2014, 04:43 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070414 Firmware Update
Release Notes
Another rs232 test pattern problem fixed.
An issue with screen being blank fixed.
Problem with using left arrow on remote for aspect changes fixed. (Update time ~3 minutes @57k)
Download Link
post #145 of 147 Old 07-16-2014, 11:22 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070514 Firmware Update
Release Notes
One more fix for an issue with rs232 test pattern usage via calibration software. (Update time ~3 minutes @57k)
Download Link
post #146 of 147 Old 07-18-2014, 11:40 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070714 Firmware Update
Release Notes
Found 2 other issues with rs232 test pattern usage via calibration software.
Fixed timing issue causing video corruption on output1 on some units. (Update time ~3 minutes @57k)
Download Link
post #147 of 147 Old 07-21-2014, 11:42 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 424
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 070814 Firmware Update
Release Notes
A fix for exiting test patterns when using vertical shift (bottom of screen left uncleared). (Update time ~3 minutes @57k)
Download Link
Reply Display Calibration
User Tag List
