Lumagen Announces 9-Point Cube Gamut (729 Color Points) for the Radiance 20XX - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 166 Old 08-31-2014, 11:30 PM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1672 Post(s)
Liked: 2083
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 081614 Firmware Update
Release Notes
Added option to enable Darbee enhancement for just 2d or just 3d sources. (Update time ~15 minutes @57k)
Download Link
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #152 of 166 Old 09-02-2014, 11:35 PM - Thread Starter
Liked: 2083
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 081714 Firmware Update
Release Notes
The audio configuration menu had lost the spdif/coax selectable options from 050114-081614 in 20xx models only. (Update time ~3 minutes @57k)
Download Link
post #153 of 166 Old 09-03-2014, 06:31 PM - Thread Starter
Liked: 2083
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 081814 Firmware Update
Release Notes
Location values displayed for 9x9x9 gamut adjustment via the menu were off by 1 for a couple locations due to a rounding error. (Update time ~3 minutes @57k)
Download Link
post #154 of 166 Old 09-22-2014, 11:32 PM - Thread Starter
Liked: 2083
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 091114 Firmware Update
Release Notes
Fix for a bug which under rare circumstances could give strange colors in grayscale that a user may have remedied by turning off and back on. (Update time ~15 minutes @57k)
Download Link
post #155 of 166 Old 09-25-2014, 10:19 AM - Thread Starter
Liked: 2083
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 091214 Firmware Update
Release Notes
Fix for an issue in 091114 having problems with 480/576p reinterlacing giving blank screen or green/pink colors.
Fix for an issue with the test pattern color when editing the color gamut via the menu. (Update time ~15 minutes @57k)
Download Link
post #156 of 166 Old 10-06-2014, 12:01 AM
Franin's Avatar
Quoted: 2399 Post(s)
Liked: 1493
what happens if you put the 2041 after the receiver ? so all sources go to pre amp then to lumagen which outputs to projector.
_________________________
Franin is online now
post #157 of 166 Old 10-06-2014, 12:07 AM
Gordon Fraser's Avatar
Quoted: 166 Post(s)
Liked: 180
It works fine...just like the way a mini3d would. If you need to have different settings for different sources that are not covered by the input resolution differences you can use the "virtual" input capabilities....ie you tell the scaler that when input 2 code is received it should look at input 1 for video but load all the settings on the Input2 memory you are using
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #158 of 166 Old 10-06-2014, 12:17 AM
Franin's Avatar
Liked: 1493
Thanks Gordon so no lip sync issues?
post #159 of 166 Old 10-06-2014, 02:20 AM
Quoted: 166 Post(s)
Liked: 180
The lumagens process video very fast all things considered. I've installed hundreds and the only time i come across lip sync issues is not to do with processing delays, it's to do with some weird auto lip sync correction or hdmi interface issue between devices...ie you need over 200 ms delay but it varies during a film or with different content....which has nothing to do with actual processing time but something to do with other stuff. I'm not saying you wont run in to this problem but i think it's uncommon
Convergent-AV
post #160 of 166 Old 10-09-2014, 03:30 PM - Thread Starter
Liked: 2083
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 100514 Firmware Update
Release Notes
Fix for not being able to power up on an analog input. This update is only helpful for units with analog inputs (2022/2042). (Update time ~3 minutes @57k)
Download Link
post #161 of 166 Old 10-09-2014, 05:36 PM
Rolls-Royce's Avatar
Quoted: 371 Post(s)
Liked: 543
It works fine, just as Gordon says. That's how I have my 2021, after the receiver. No lipsync issues.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #162 of 166 Old 10-09-2014, 07:37 PM
Franin's Avatar
Liked: 1493
Thanks Rolls-Royce.
post #163 of 166 Old 10-24-2014, 02:24 PM - Thread Starter
Liked: 2083
Today Lumagen is annoucing the Radiance 2020 video processor.
The Radiance 2020 is essentially the (now retired) Radiance 2021, minus the COAX audio output and in a smaller case.
It has exactly the same video setup, processing and calibration feature set as the Radiance 2021.
Highlights:
4 HDMI 1.4a inputs (max 1080p60)
2 HDMI 1.4a outputs (max 1080p60)
9x9x9 Linear-Gamma RGB CMS
Darbee DVP(TM) enhancement
Image-based auto input aspect selection
RS232 command port
Wired IR command input
12 VDC power supply
Case: 11 x 1.7 x 5 inches
Note that the Radiance 2020 is not rack mountable.
The US retail price for the Radiance 2020 is $2495.
post #164 of 166 Old 11-04-2014, 12:12 PM - Thread Starter
Liked: 2083
Lumagen Radiance 20XX Series (2021, 2022, 2041, 2042) New 103114 Firmware Update
Release Notes
Fix for output setup issue with being unable to select desired Style after being previously set.
Fix for auto aspect when "Letterbox Zoom" was set to off and would do a zoom step for 2.40 and 1.85 sources.
Added 24 Hz to the direct vertical rate command ("menu 04"). (Update time ~3 minutes @57k)
Download Link
post #165 of 166 Old 11-05-2014, 03:48 PM - Thread Starter
Liked: 2083
Lumagen Radiance 20XX Series (2020,2021, 2022, 2041, 2042) New 110114 Firmware Update
Release Notes
Fixed issue where setting hotplug to always on could result in video not turning on for output. (Update time ~3 minutes @57k)
Download Link
post #166 of 166 Old 03-07-2015, 02:51 PM - Thread Starter
Liked: 2083
Lumagen Radiance 20XX Series (2020,2021, 2022, 2041, 2042) New 030115 Firmware Update
Release Notes
Fix for test patterns with 3D signal and 2.35 output.
Fix for 2022/2042 analog component input when source switches from higher resolution to 480i and the 20XX loses the 480i picture. (Update time ~3 minutes @57k)
Download Link
Reply Display Calibration
