which components actually "age" (and the need for recailbration) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-20-2013, 10:36 AM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
With CRTs I can understand that the emmissiveness of the electron guns can change over time, and hence the need for recalibration. I suppose incremental phosphor decay also has an impact.
But what about high end LCD tv sets, or DLPs? What kind of changes occur to components that would necessitate a periodic calibration?
spacediver is offline
post #2 of 10 Old 09-20-2013, 11:01 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
The light bulb changes color as it ages.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 10 Old 09-20-2013, 11:04 AM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
ah I see, makes sense. Thanks for the response - and for your great site, which I've been devouring over the last few days smile.gif
post #4 of 10 Old 09-20-2013, 11:41 AM
HDTVChallenged's Avatar
Liked: 215
Polarizers degrade ... "Organic" components degrade ... although these aren't as much of a problem with modern LCDs as they once were. OTOH, The jury hasn't even been seated on OLED yet ... stay tuned.
HDTVChallenged is offline
post #5 of 10 Old 09-20-2013, 03:38 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
From everything I've read, managing the aging on OLEDs is the number 1 problem with the technology.
Gregg Loewen likes this.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #6 of 10 Old 09-20-2013, 07:20 PM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 565
I remember reading many years back that the blue OLEDs seemed to have the shortest lifespan
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #7 of 10 Old 09-21-2013, 07:33 AM
Gregg Loewen's Avatar
Quoted: 22 Post(s)
Liked: 68
Scotti is right on the money.
The # 2 problem is viewing angle issues.
President, Lion Audio Video Consultants Inc.
Lead THX Video Standards Instructor
Gregg Loewen is offline
post #8 of 10 Old 09-21-2013, 07:33 AM
Quoted: 22 Post(s)
Liked: 68
# 3 is burn in.
post #9 of 10 Old 09-21-2013, 10:43 AM - Thread Starter
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
I recently summarized a research review of the Sony PVM-2541 (OLED). The paper itself is open access. and can be found here. My brief summary is here.
While they didn't discuss burn in, the manual says:
Due to an OLED’s panel structure and characteristics of materials in its design, displaying static images for extended periods, or using the unit repeatedly in a high temperature/high humidity environments may cause image smearing, burn-in, areas of which brightness is permanently changed, lines, or a decrease in overall brightness. In particular, continued display of an image smaller than the monitor screen, such as in a different aspect ratio, may shorten the life of the unit.
Avoid displaying a still image for an extended period, or using the unit repeatedly in a high temperature/high humidity environment such an airtight room, or around
the outlet of an air conditioner.
To prevent any of the above issues, we recommend reducing brightness slightly, and to turn off the power whenever the unit is not in use.
and even on their top of the line OLED, the BVM E250, from the manual:
Due to the characteristics of the material used in the OLED panel for its high-precision images, permanent burn-in may occur if still images are displayed in the same position on the screen continuously, or repeatedly over extended periods.
Images that may cause burn-in
• Masked images with aspect ratios other than 16:9
• Color bars or images that remain static for a long time
• Character or message displays that indicate settings or
the operating state
• On-screen displays such as center markers or area
markers
To reduce the risk of burn-in
• Turn off the character and marker displays
Press the MENU button to turn off the character displays. To turn off the character or marker displays of the connected equipment, operate the connected equipment accordingly. For details, refer to the operation manual of the connected equipment.
• Turn off the power when not in use
Turn off the power if the viewfinder is not to be used for
a prolonged period of time.
Screen saver
This product has a built-in screen saver function to reduce burn-in. When an almost still image is displayed for morethan 10 minutes, the screen saver starts automatically and the brightness of the screen decreases.
post #10 of 10 Old 09-21-2013, 10:48 AM
jdoostil's Avatar
From my experience so far...
The LG OLED does color shift at an angle, but the blacks do not turn gray like a traditional LCD panel. I started doing some digging and it appears that the color shift is due to the 4th white subpixel. It appears that the Samsung does not have this but I have yet to lay my eyes on one.
ISF certified in 2008
ISF Level II certified in 2010
ISF instructor certified in 2012
ISF International Trainer since 2014
ISFJasonD65@gmail.com
Serving Florida
jdoostil is offline
Reply Display Calibration
