What pic mode should I be calibrating in on a 2013 Panasonic Plasma (S60)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 37 Old 09-29-2013, 09:27 PM - Thread Starter
PlasmaPZ80U's Avatar
Quoted: 1964 Post(s)
Liked: 560
Should I be using Cinema or Custom when calibrating the Panasonic TC-P50S60 Plasma (and are blacks better in one of these modes)? Is Mid Panel Brightness better than Low or High? Is the CMS worth using and does it work right?
What is the Home Theater Picture Mode for?
(As you can see, I have a lot of questions about this TV since the last Panasonic I calibrated was a 2008 model.)
Panasonic TC-P50S60 Picture Settings Cinema 9-29-13.docx 19k .docx file
File Type: docx Panasonic TC-P50S60 Picture Settings Cinema 9-29-13.docx (18.7 KB, 99 views)
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #2 of 37 Old 09-30-2013, 10:25 AM
jdoostil's Avatar
You can calibrate custom...it has everything that you need. IIRC CMS only for the primaries. make sure to turn off the AGC and black corrector, as they are both on by default in custom.
You can calibrate cinema in the SM...the gamut should be decent after a good WB
ISF certified in 2008
ISF Level II certified in 2010
ISF instructor certified in 2012
ISF International Trainer since 2014
ISFJasonD65@gmail.com
Serving Florida
jdoostil is offline
post #3 of 37 Old 09-30-2013, 10:42 AM
fairchild99's Avatar
Liked: 151
Cinema will allow the colors to line up much better. Check my link for some charts done with HCFR. Should be no difference in black levels between custom/cinema that I noticed. Also stay away from High panel brightness if you want to avoid increased dithering/noise in dark scenes.
Sony 32" EX400 calibrated settings
Panasonic 50" S60 calibrated settings
HTPC/Sony S5100 to Sony HT-CT660 to Panasonic 55" VT60, Sony 32" EX400, Panasonic 50" S60
fairchild99 is offline
post #4 of 37 Old 09-30-2013, 01:45 PM - Thread Starter
Liked: 560
is gamma non-linear in custom? because the S60 lacks 10-pt grayscale and 10-pt gamma controls
any reason for using the SM for Cinema? the 2013 models have 2-pt grayscale controls in Cinema and Custom (plus gamma presets and HSL CMS controls for red, green, and blue) all in the user menu
my current results are with an unprofiled C6 in plasma mode, but I'd say the gamut results with 2-pt grayscale and color/tint changes alone are excellent (all dE2000's under 1.5)
any difference between PB Mid and Low in dithering/noise? how does gamma in Custom compare to gamma in Cinema?
post #5 of 37 Old 09-30-2013, 02:54 PM
Liked: 151
There is no noticeable difference between Mid or Low. I always just use Mid as have others on the 2013 series of Panny plasmas. I believe gamma shows a similair behavior to Cinema while in Custom, though as you probably know, the type and size of patterns always has an impact on what the measured gamma is.
Use 4% APL window patterns vs 4% window patterns, and the measured gamma will be different. My current Cinema calibration I used 10% window patterns from the GCD disc as well as the 100%/100% color patterns from the GCD disc and as you noticed using 2.4 gamma preset gives me a measured 2.2 gamma.
post #6 of 37 Old 09-30-2013, 03:33 PM - Thread Starter
Liked: 560
I used the 15% windows (non-APL) from the AVSHD709 disc.
post #7 of 37 Old 09-30-2013, 06:59 PM
Liked: 151
Cool, I used those when I did my first few calibrations. (my set is now over 1500 hours at last check several weeks ago) I am currently using the 10% window GCD patterns primarily because with them I can also run the color checker patterns with HCFR. (currently zoyd has added color checker support for both the GCD and Mascior discs)
post #8 of 37 Old 10-01-2013, 07:49 AM - Thread Starter
Liked: 560
is that the 10% (Standard) or 10% APL patterns?
post #9 of 37 Old 10-01-2013, 09:00 AM
Liked: 151
Just the 10% standard window patterns. I have tried various APL patterns but don't like the way the results look with actual content and ended up going back to just the standard windows.
post #10 of 37 Old 10-01-2013, 10:37 AM - Thread Starter
Liked: 560
yeah, sometimes the simple/standard approach is best
post #11 of 37 Old 10-02-2013, 02:25 PM
Steve544's Avatar
Quoted: 34 Post(s)
I only have about 100 hours on my new Panasonic ZT 65". When installing I was surprised that the set was almost dead on in terms of calibration when using the Spears and Munsil Blu Ray calibration DVD. Never the less, after a couple more 100 hours I will call in a pro calibrator who has the right sensors to do the job right.
Steve Douglas
McIntosh 8207
Anthem AVM-60
Aerial Acoustics 10T, CC3 center, AA5 and SR3 dipole/bipole
Panasonic ZT 65
Velodyne Sub
Steve544 is offline
post #12 of 37 Old 10-03-2013, 04:25 PM - Thread Starter
Liked: 560
does the CMS work right on these Panasonics? does it affect grayscale? and does it affect one level of saturation more than others (75% sat vs. 100% sat)? any tips in general for 2013 Panasonics?
so far I've left it alone since color/tint gets things very close to perfect and I was afraid using the CMS wrong would do more harm than good
post #13 of 37 Old 10-03-2013, 04:27 PM - Thread Starter
Liked: 560
also, does anyone know about whether the MLL drops around the 250-300 hour mark on these sets (50" 2013 models)?
post #14 of 37 Old 10-10-2013, 11:10 AM - Thread Starter
Liked: 560
what exactly does 1080p pixel direct do? I think I remember reading it should be off but what happens when it's on?
post #15 of 37 Old 10-10-2013, 03:57 PM
Liked: 151
It's currently not useable IMO because it has built into it a very high level of sharpening. It is defeatable by changing the HDMI setting to Photos, but then you get a color gamut that is much harder if not impossible to get to Rec709 when calibrating.
It basically provides a pure RGB 4:4:4 signal which is really pointless currently with blu-rays since they are all YCBCR 4:2:0. It might be useful if you play alot of games or do some other type of work on a PC which can benefit from the RGB 4:4:4 signal.
more info if you want to learn yourself:
http://en.wikipedia.org/wiki/Chroma_subsampling
post #16 of 37 Old 10-12-2013, 08:45 PM - Thread Starter
Liked: 560
I did a comparison of grayscale and gamut readings using various sized standard and APL window patterns. I used the CMD HD, GCD, AVSHD709, and S&M HD Benchmark 2nd Edition discs.
post #17 of 37 Old 10-12-2013, 08:47 PM - Thread Starter
Liked: 560
post #18 of 37 Old 10-12-2013, 08:47 PM - Thread Starter
Liked: 560
post #19 of 37 Old 10-12-2013, 08:47 PM - Thread Starter
Liked: 560
post #20 of 37 Old 10-12-2013, 08:48 PM - Thread Starter
Liked: 560
MLL @ 100 hours (all-black screen): 0.0031 fL
post #21 of 37 Old 10-12-2013, 09:43 PM
ttnuagmada's Avatar
Quoted: 111 Post(s)
Liked: 108
Not bad, my 50 inch ST60 only reads .0024
ttnuagmada is offline
post #22 of 37 Old 10-12-2013, 09:49 PM - Thread Starter
Liked: 560
How many hours does your set have and what meter do you use?
I find running the screen wipe before measuring MLL produces a lower number than measuring during grayscale runs where IR is present. It makes about a 0.001 fL difference.
post #23 of 37 Old 10-12-2013, 10:51 PM
Andrei_VVB's Avatar
Quoted: 82 Post(s)
Liked: 29
That's because it may have a little image retention from the brighter test patterns that may raise a bit the mll reading.
Andrei_VVB is offline
post #24 of 37 Old 10-13-2013, 12:40 AM
ttnuagmada's Avatar
Quoted: 111 Post(s)
Liked: 108
It's at 200 hours, and I'm using an i1D3. I plan on playing around with it later, I'll see if I can get something lower.
post #25 of 37 Old 10-13-2013, 01:05 PM
christopher49's Avatar
Hello good people does anyone have the calibration settings for the samsung pn60e530af
christopher49 is offline
post #26 of 37 Old 10-13-2013, 01:38 PM
GeorgeAB's Avatar
Quoted: 135 Post(s)
Liked: 240
See this "sticky" topic from above:
'Sharing display menu settings?'
http://www.avsforum.com/avs-vb/showthread.php?t=1055906
GeorgeAB is online now
post #27 of 37 Old 10-13-2013, 04:35 PM
xvfx's Avatar
Quoted: 408 Post(s)
Liked: 225
That was a good read. I loved that.
Originally Posted by Doug Blackburn
Your perception is a tricky thing. You can easily fool yourself into thinking you have "good" adjustments... then you actually measure what you've done and find you are so wrong it's not even funny.
Surprisingly, when a video display is accurately adjusted with instrumentation... our perception INSTANTLY recognizes the images as accurate... though we may have THOUGHT the non-instrumented adjustments looked great, it's only when you see the instrumented/calibrated images that you think "Oh, guess I wasn't doing as well as I thought." Perception is a funny thing.
xvfx is offline
post #28 of 37 Old 10-18-2013, 01:16 PM - Thread Starter
Liked: 560
Advanced Gamut Measurements:
post #29 of 37 Old 10-18-2013, 01:23 PM - Thread Starter
Liked: 560
Current MLL:
post #30 of 37 Old 10-26-2013, 03:58 PM - Thread Starter
Liked: 560
Comparison of Pattern Types in Cinema Mode (GCD used):
Settings Used:
Panasonic TC-P50S60 Picture Settings Cinema 10-21-13.docx 19k .docx file
File Type: docx Panasonic TC-P50S60 Picture Settings Cinema 10-21-13.docx (18.8 KB, 92 views)
Reply Display Calibration
Panasonic Tc P50s60 50 Inch Plasma Hdtv
