What is the best free monitor calibration software? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-13-2013, 07:14 AM - Thread Starter
l1l2l3l4l5l's Avatar
T4R
If there are not any, what is the best that is cheap?
l1l2l3l4l5l is offline
post #2 of 5 Old 10-14-2013, 02:38 AM
AV-Freak's Avatar
All monitor worth a calibration have the software included. (Eizo, Nec, ...)
Aren't you pleased with the result or why are you seeking additional software?
AV-Freak is offline
post #3 of 5 Old 10-14-2013, 08:41 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
That's not true at all. There are a number of Dell and ASUS monitors that have great color accuracy out of the box and don't have calibration software packed in. Also a slightly off monitor can be made extremely accurate with calibration.
That said in order to calibrate you'll need a meter and nobody sells the meter without software.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #4 of 5 Old 10-14-2013, 11:59 AM
AV-Freak's Avatar
He wanted to calibrate the Monitor and not to bend the graphic card LUT which will give you inferior results.
Especially the Asus monitors can't be calibrated right. Either you use the factory presets or forget it. Just try it yourself or read one of the many test.
And by the way Dell includes a calibration Software called "Color Calibration Solution".
AV-Freak is offline
post #5 of 5 Old 10-14-2013, 01:21 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Being that I write the calibration software for SpectraCal, I think it's safe to say that I have tried it and believe the results are far better than you state. Granted everyone has different bars for what they consider good enough. But the entire calibration industry is based around "increasing" accuracy.
Putting the bar at, the display must have an internal LUT to be worth calibrating, is an awfully high bar. If that's what you believe, we'll just have to agree to disagree.
Joel Barsotti
SpectraCal
sotti is offline
Reply Display Calibration
