Spectrophotometer and Colorimeter--Which gets used in which situation? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-16-2013, 04:22 PM - Thread Starter
earwicker7's Avatar
My colorimeter is waiting at home according to FedEx, and my spectrophotometer is shipping tomorrow, so I'll soon be doing my first calibration on Calman 5.
I know that I'm supposed to calibrate my colorimeter to my spectrophotometer, but will there be any other times that I use the spectrophotometer, or is it purely there for reference?
earwicker7 is offline
post #2 of 11 Old 10-16-2013, 05:03 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
If you're just interested in measuring color (chromaticity coordinates), then a profiled colorimeter should serve your purpose well. Might be a good idea to profile your colorimeter before each major calibration (definitely if you switch displays), but other than the purposes of profiling, you shouldn't need the spectro, unless you want to examine the actual spectral power distribution of your display (which is a different form of information than color information).
spacediver is offline
post #3 of 11 Old 10-16-2013, 09:39 PM
<^..^>Smokey Joe's Avatar
Quoted: 61 Post(s)
Liked: 91
Some of realities and reasons why you profile has been lost in translation.(pun intended)
In the world of absolutes and reference, you can only use a specto device, the caveat is to do it accurately you need a CS2000 or similar.
It was found in research that a Tristimulas Colormeter can produce as accurate results, but only if the CMF matched the model CMF that the spectro uses to convert the spectral data.
When the colormeter does not natively match, the correction profile produced by the differences between the reference and the colormeter can fix the vast majority of the problem, the caveat though is no correction is perfect. There is always error.
However, reality.
Most are not measuring for reference sake of absolutes, displays and course controls means that method and device error differences are not important enough to show up in real world differences.
However, the limited nature of consumer spectros means that some improvement can be made to a consumer colormeter for both speed and accuracy on most given display types.
Many still use just an i1pro or i1D3 or many other basic devices, some have a life span of usefulness some don't.
In the end, the Spectro will give you reasonble accuracy for a longer life span.
A colormeter will degrade, but has a speed advantage, where the profiling will adjust for the degradation as time passes, thus gaining the speed and spectro accuracy.
As new devices, you will probably not find a large difference between the devices.
Masterpiece Calibration Ltd
Christchurch NZ
<^..^>Smokey Joe is offline
post #4 of 11 Old 10-17-2013, 02:54 PM
daMaster's Avatar
The i1D3 is just a sealed colorimeter, right? For $229 it seems like a bargain. Does it have limited life span of usefulness like the i1D2 colorimeter that had exposed filters? My i1D2 LT is useless right now because it has drifted so much.
Now I can't decide if I should spend $1k on a i1Basic Pro 2 or $229 on a i1D3. Certainly not the latter if the i1D3 is going to have a very limited life span of usefulness...
daMaster is offline
post #5 of 11 Old 10-17-2013, 03:09 PM
rahzel's Avatar
Liked: 148
Yes the D3 is a colorimeter with sealed optics. It will be more accurate and will last much longer than the D2/LT. A spectro will be more accurate on a wider range of display types than a colorimeter, and you can use your spectro to profile your D2/LT, so it's not completely useless.
rahzel is offline
post #6 of 11 Old 10-17-2013, 03:10 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
The i1D3, is much, much better than the i1D2 in regards to drift. OTOH having a spectro is a really nice sanity check.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #7 of 11 Old 10-17-2013, 04:17 PM
fairchild99's Avatar
Liked: 151
You could also purchase a spectro such as the i1pro or colormunki photo/design and then use that to profile your i1d2, it will benefit from the corrections of the spectro and benefit from faster reads and higher accuracy at lower light levels. It's the route I chose to go. At first I tried shopping around on ebay for a used i1pro, but never had luck winning any auction at a reasonable price, so I just opted for a brand new Colormunki Photo off of Amazon.
Sony 32" EX400 calibrated settings
Panasonic 50" S60 calibrated settings
HTPC/Sony S5100 to Sony HT-CT660 to Panasonic 55" VT60, Sony 32" EX400, Panasonic 50" S60
fairchild99 is offline
post #8 of 11 Old 10-25-2013, 03:39 PM
turbe's Avatar
Liked: 95
I found a used i1Pro Rev D spectro at a decent price for sale.. PM for link
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #9 of 11 Old 10-25-2013, 03:52 PM
ndaa75's Avatar
Me too. I'm after a rev d and like you have not been able to source one at a reasonable price.
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #10 of 11 Old 10-25-2013, 06:05 PM
fallengt's Avatar
I bought my Used i1 pro Rev D for ~$300. Took a lot of time though, I missed out like 15 of them .
fallengt is offline
post #11 of 11 Old 11-02-2013, 05:41 AM
ndaa75's Avatar
Got one this week - i1 basic rev d, for 200 Gbp - had to be quick though, i1 pros regularly go for 275 - 300 here.
ndaa75 is offline
Reply Display Calibration
