Help! Can't find the white balance settings on my Sony - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 10-18-2013, 10:04 AM - Thread Starter
Mark Winston's Avatar
Hey guys, I can't seem to find the white balance settings on my Sony Bravia KLV-40EX43B... it's not in the advanced option. Where can I find it? Need to bring the reds down cuz the red is really screwing up the whites in Cinema / Warm mode. Any help would be great. Thanks in advance guys!
Mark Winston is offline
post #2 of 21 Old 10-18-2013, 10:14 AM
realzven's Avatar
Liked: 84
are you calibrating with a colorimeter and a soft or by eye ?
realzven is offline
post #3 of 21 Old 10-18-2013, 10:49 AM
dschlic1's Avatar
Quoted: 73 Post(s)
Liked: 27
There is a color temperature setting you can try.
LG OLED65B6P TV, Yamaha RX-V665 AV receiver, Sony BDP_S1700 Player, Klipsch F-30 speaker system
dschlic1 is online now
post #4 of 21 Old 10-18-2013, 11:24 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Looks like it is in the service menu somewhere. You will have to go there to fix it ... but be sure you know what you are doing or you can kill your tv in there too.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #5 of 21 Old 10-18-2013, 03:49 PM - Thread Starter
The Cinema/Warm mode is the closest to 6500... so I will stick to that, but the whites are red tinted, making whites look brownish. I have entered the service menu but there are no white balance controls there, which I find is weird. Does every Sony screen have a white balance control? Im tuning it by eye, while waiting for the DVE disc to arrive. It is known that most Sony panels are red biased, especially in Warm... btw, the screen has only 3 colour temperature settings, which is Cool, Neutral and Warm.
post #6 of 21 Old 10-18-2013, 04:11 PM
xvfx's Avatar
Quoted: 408 Post(s)
Liked: 225
Sounds like my JVC LT-32DR9BJ. Just a shame I can't find any information on the JVC service menus to familiarise myself like I did with my old 2006 Samsung to calibrate.
xvfx is offline
post #7 of 21 Old 10-18-2013, 10:10 PM - Thread Starter
Do all Sony screens have white balance controls? Mine is fairly a new model, around 1 year plus...
post #8 of 21 Old 10-18-2013, 10:21 PM
Quoted: 40 Post(s)
Liked: 142
Greetings
Most do, but the budget level units might not have it ... or the ones that sony farms out for others to build.
regards
post #9 of 21 Old 10-19-2013, 12:50 AM
ConnecTEDDD's Avatar
Quoted: 1055 Post(s)
Liked: 1521
In EU Models ,the White balance controls are only available in Custom Picture Mode.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #10 of 21 Old 10-19-2013, 01:32 PM - Thread Starter
Cant find it even in custom mode... not in advance settings and not in the service menu... im screwed now...
post #11 of 21 Old 10-19-2013, 01:35 PM
Liked: 1521
Thats too bad frown.gif Sorry to hear.
post #12 of 21 Old 10-20-2013, 12:09 AM - Thread Starter
I just thought there would be white balance controls in every new Sony... frown.gif besides the advance settings and service menu, could the white balance controls be anywhere else?
post #13 of 21 Old 10-20-2013, 12:12 AM - Thread Starter
Another quick question, if its in the service menu, what would it be under? Is it written White Balance there?
post #14 of 21 Old 10-20-2013, 12:40 AM
Liked: 1521
See if you can find these:
R_DRV
G_DRV
B_DRV
R_BKG
G_BKG
B_BKG
post #15 of 21 Old 10-20-2013, 03:46 AM - Thread Starter
All right... just a confirmation, do I get into the service menu with (i+) (5) (volume up) (power on)?
post #16 of 21 Old 10-20-2013, 03:49 AM - Thread Starter
post #17 of 21 Old 10-20-2013, 04:37 AM
Liked: 1521
Download or Buy the Official Service PDF Manual of your Display.
I don't recommend you to do anything without official instructions.
Maybe the Factory Calibration Controls are available only via Sony's Service PCMCIA Card Slot Connection, and not at the menu you have access at your attached picture.
post #18 of 21 Old 10-20-2013, 07:13 AM - Thread Starter
This might sound stupid but where do I download the PDF Manual of my screen? Thanks....
post #19 of 21 Old 10-20-2013, 07:46 AM
Liked: 1521
Your Service Manual
Don't try anything at this menu, a wrong entry will damage your TV.
I don't see the White Balance Controls to be available to your Service Menu. frown.gif
post #20 of 21 Old 10-20-2013, 04:05 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
Why would you think that? Sony doesn't even make all the TVs they sell. When you contract another factory to build your TV, they are often quite different than the ones you make yourself -- and that's exactly what happens with Sony and just about every other manufacturer. In fact, it is common to see calibration controls in the "best" models a company sells, and those controls tend to disappear as you move down the model line, even if the manufacturer makes their own less expensive models.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #21 of 21 Old 10-20-2013, 04:08 PM - Thread Starter
Thanks bro...! Wow... it hasnt crossed my mind that certain Sony models dont have a white balance control. So much for setting up my screen...
Reply Display Calibration
