Can't get my i1 Display Pro to lay flat on the screen... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 10-18-2013, 07:48 PM - Thread Starter
earwicker7's Avatar
As the title says, I'm trying to use my i1 Display Pro for my first calibration. Is there a trick to not having it bounce around all over the place? No matter how I set the counterweight, it will not lay flat.
I have a feeling that purchasing the OEM probe might have left something critical out of the bargain... I've used the Spyder3 in a similar way on my monitor, but it has the benefit of tilting backwards, so gravity does the trick.
earwicker7 is offline
post #2 of 12 Old 10-18-2013, 08:05 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Painters tape ...
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 12 Old 10-18-2013, 08:23 PM - Thread Starter
earwicker7's Avatar
D'oh! So obvious, but I never even considered it. Thanks!
post #4 of 12 Old 10-18-2013, 08:35 PM - Thread Starter
earwicker7's Avatar
One question... am I taping it to the edges with 4' long strips, or to the screen with 6" strips? The numbers are approximates, of course.
post #5 of 12 Old 10-18-2013, 09:38 PM
Quoted: 40 Post(s)
Liked: 142
Greetings
Up to you. I do it to the screen ... when I need to do it. It doesn't stay long enough to leave any residue.
regards
post #6 of 12 Old 10-19-2013, 01:06 AM
fredman2005's Avatar
I put a weight on the downwards leading cable. But my TV stands on a board. If your TV hangs at the wall you can try to clip a weight at the cable.
fredman2005 is offline
post #7 of 12 Old 10-19-2013, 08:57 AM - Thread Starter
earwicker7's Avatar
So you have the counterbalance weight in back, and an additional weight up front?
post #8 of 12 Old 10-20-2013, 06:20 PM
buzzard767's Avatar
Quoted: 1621 Post(s)
Liked: 2395
Furry paint roller on an adjustable length stick. No problems, no tape.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #9 of 12 Old 10-20-2013, 06:24 PM - Thread Starter
earwicker7's Avatar
How does that work? Are you putting the end of the stick on the floor, then having the weight of the roller hold the probe against the screen?
post #10 of 12 Old 10-20-2013, 06:38 PM
LastButNotLeast's Avatar
Quoted: 1494 Post(s)
Liked: 1097
I use a tripod. I just rotate the "arm" to press (gently ;)) against the i1.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #11 of 12 Old 10-20-2013, 10:18 PM
buzzard767's Avatar
Liked: 2395
Yes. Adjust the stick angle so that it only applies enough pressure to hold the meter flush to the display.
Buzz
post #12 of 12 Old 10-21-2013, 06:20 AM
PeterLewis's Avatar
Quoted: 129 Post(s)
Liked: 65
Painters 2" tape from edge to edge,no harm no foul.
Sony OLED XBR-65A1E (In my Future )| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
Reply Display Calibration
