BluRay players - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-21-2013, 01:08 PM - Thread Starter
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
a couple years ago there was a list of BR players tested to be accurate
enough for using to calibrate panels.
Is there a new list?
I can't swing a pattern machine but want that piece of mind.
so, is there a new list and where can I find it?
thank you
Loving D65
CalWldLif is offline
post #2 of 9 Old 10-21-2013, 01:21 PM
fairchild99's Avatar
Liked: 151
Generally Oppo's are usually top of the line including for color accuracy. Don't know if others are now producing equally good results. I was personally thinking of picking up one of the 2013 Sony S3100 or S5100. Oppo's are kind of expensive, think the cheapest is around $500
Sony 32" EX400 calibrated settings
Panasonic 50" S60 calibrated settings
HTPC/Sony S5100 to Sony HT-CT660 to Panasonic 55" VT60, Sony 32" EX400, Panasonic 50" S60
fairchild99 is offline
post #3 of 9 Old 10-21-2013, 01:41 PM - Thread Starter
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
I have heard good things about Oppo.
The list I saw had all the brands and some where quite resonably priced.
Loving D65
post #4 of 9 Old 10-21-2013, 02:04 PM
ElectronicTonic's Avatar
Quoted: 63 Post(s)
Liked: 103
I've tested the PS3, with good results. It loads faster than most players too.
ElectronicTonic is offline
post #5 of 9 Old 10-21-2013, 02:10 PM
Chad B's Avatar
Quoted: 495 Post(s)
Liked: 1190
There's really not much difference between players of respected brands, once the HDMI output is set up correctly, with the exception of LG. LGs have inaccurate black and white levels, and their picture adjustments are far too coarse to make good corrections.
Oppos, Sonys, Panasonics, etc, will all measure very similarly if not identically in most situations, once set up optimally.
Chad B is offline
post #6 of 9 Old 10-21-2013, 02:29 PM
ConnecTEDDD's Avatar
Quoted: 1055 Post(s)
Liked: 1521
Once I will have free time, i will compare 5-10 different Blu-Ray Players using Lumagen as a Pattern Source (as a reference) vs. my Disk as a Pattern Source, as my disk has exact the same pattern size of Lumagen Large Windows Patterns. wink.gif
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #7 of 9 Old 10-21-2013, 02:52 PM
willieconway's Avatar
Quoted: 121 Post(s)
Liked: 130
I calibrated my Samsung D7000 using a Panasonic DMP-BDT220 as source. All dEs below 1, a nice looking picture etc. Then, just for the fun of it, I measured everything again using my old fat PS3 as source. I found exactly zero difference between the two players.
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D. Currently boxed up: Denon 1713, Klipsch SW-450,
NHT Absolute Center, Energy Veritas 5.1s, 5.2C, V-Mini-C.
willieconway is online now
post #8 of 9 Old 10-21-2013, 02:56 PM
Liked: 1521
Hello, Check xy differencies next time, dE doesnt mean anything, becasue you can have for example 2 reds with 1dE that have different hues, but they will report the same dE number. wink.gif
post #9 of 9 Old 10-21-2013, 03:00 PM - Thread Starter
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
thanks guys.
the test is going the distance, thank you for the effort.
I remember the ps3 was on the list with the DMP-BDT220
I am going 1000 miles north to oregon were my brother
has a new ZT60 to work on.
He is in the market for a Bluray so I just want to make sure it(new one) will
be good to use for a cal.
and yes, I ill want something for myself too.
Loving D65
Reply Display Calibration
