Questions on Calibrating a VT60 with HCFR and i1 Display 2 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 10-24-2013, 09:49 AM
chunon's Avatar
Quoted: 2112 Post(s)
Liked: 1851
http://www.avsforum.com/t/1463980/masciors-calibration-disc
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #32 of 39 Old 10-24-2013, 10:02 AM
turbe's Avatar
Liked: 95
You should also calibrate the set without having the on VT60's menus up on screen during the session.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #33 of 39 Old 10-24-2013, 04:19 PM - Thread Starter
Sittler27's Avatar
Quoted: 710 Post(s)
Liked: 63
Ok downloaded Mascoir's and goign to use the 6-10% APL windows to recalibrate again.
Basically I'm not going to start from scratch, but going to take the Cinema setting I got to perfect calibration with using 15% windows, and goign to adjust grayscale/CMS/gamma from there using 6-10% APL windows from Mascoir.
Sittler27 is offline
post #34 of 39 Old 10-24-2013, 05:58 PM
fairchild99's Avatar
Liked: 151
I'd stick to the 10% standard windows and see if the visual results match the graphs by watching actual content.
Sony 32" EX400 calibrated settings
Panasonic 50" S60 calibrated settings
HTPC/Sony S5100 to Sony HT-CT660 to Panasonic 55" VT60, Sony 32" EX400, Panasonic 50" S60
fairchild99 is offline
post #35 of 39 Old 10-24-2013, 06:14 PM - Thread Starter
Sittler27's Avatar
Quoted: 710 Post(s)
Liked: 63
So you would still recalibtate using the 10% std windows?
Visual content looks fantastic right now after I had used15% std windows to calibrate. Wondering if I'm going to need to recalibtate with 10% ones of the same! or will my results be roughly the same?
post #36 of 39 Old 10-24-2013, 06:57 PM
Liked: 151
they'll probably be roughly the same on the grayscale. you might need to tweak the cms a bit, and possibly the gamma.
post #37 of 39 Old 10-24-2013, 06:59 PM - Thread Starter
Sittler27's Avatar
Quoted: 710 Post(s)
Liked: 63
And in your opinion, for a plasma, it would provide a more accurate image using the 5% smaller patterns?
post #38 of 39 Old 10-24-2013, 08:06 PM
Liked: 151
As other's have said, it varies from panel to panel but generally 10-15% standard patterns is where it's at for plasmas and especially the 2013 panasonics. If you are happy with your picture and your larger patterns, I'd just call it a day. Though if you feel things are looking off for some reason then there is no harm in doing another calibration run.
post #39 of 39 Old 10-24-2013, 08:08 PM - Thread Starter
Sittler27's Avatar
Quoted: 710 Post(s)
Liked: 63
Yeah, I'm pretty happy. I just got other crap to do. Lol
Reply Display Calibration
