Bias light and switching options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-22-2013, 10:06 AM - Thread Starter
slvrM3's Avatar
I want to add a bias light to my LCD and have started reaching my options. I came to the conclusion that Ideal-Lume was a pretty good product, BUT I need a "remote" or automatic way of turning it on. I see they offer accessories using x10 or insteon but I think that's a bit overboard and more expensive then the product in the first place. Are there modification options I can look into, or another product that could be more helpful. Ideally I would like it to be either remote or just turn on with the TV itself. I appreciate any ideas!
slvrM3 is offline
post #2 of 5 Old 10-22-2013, 11:23 AM
monvo's Avatar
monvo is offline
post #3 of 5 Old 10-22-2013, 11:44 AM
praz's Avatar
Liked: 26
praz is offline
post #4 of 5 Old 10-22-2013, 11:48 AM
GeorgeAB's Avatar
Quoted: 136 Post(s)
Liked: 240
The X10 device is no longer available. The SmartStrip is what will turn on with the TV, and costs about half as much as the lowest priced bias light model.
GeorgeAB is offline
post #5 of 5 Old 10-22-2013, 11:52 AM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
I use this for my bias light.
http://www.walmart.com/ip/Woods-32555-Woods-Outdoor-Weatherproof-Wireless-Remote-Control-with-3-Conductor-Outlet-Black-32555/21682994
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
Reply Display Calibration
